Results 1 to 13 of 13
Thread: Black emblems
    Sep 15 2017
    2017 S6, 2016 MBZ E400, 2022 Acura MDX
    Huntington Beach, CA
    Black emblems
    Hello All -
    Since my car came with the Black Optics package, I'm finally getting around to replacing the crappy chrome emblems with black ones. I've read that TAG sells painted OEM emblems, and also that non-OEM emblems can be had on Ebay, but has anyone ordered the black OEM emblems from Audi (rear trunk lid rings and S6 front/rear emblems) for the C8 cars and made them fit the C7.5's? Since I presume the emblems are only affixed with double stick tape, I would assume that they will fit but didn't know if the sizing/look was different than the C7.5 emblems.
    Also, any other options besides TAG/Ebay for black emblems?
    Larry
    Veteran Member Four Rings Audisthesia's Avatar
    Aug 14 2019
    Tampa
    Quote Originally Posted by DaddyO View Post
    Hello All -
    Larry
    C8 wont fit on C7.5/
    18 S6
    Nov 06 2021
    Singapore
    Hello All -
    Larry
    Buy it from Aliexpress, got mine from this vendor. All measurements and models listed clearly for correct size.
    https://www.aliexpress.com/item/1005...d=dZUfqvRBNgeO
    Established Member Two Rings snowfree52's Avatar
    Aug 19 2019
    here
    Quote Originally Posted by Audisthesia View Post
    C8 rear emblems will fit, they are just glued to the car
    But front needs to be painted or bought via aliexpress/ebay
    RS6 C7.5 Performance - DS1 - SRM TCU tune - TS1 - SRM intake - LOBA HPFP - fuel lines - ethanol sensor - TS actuators - 4 bar map sensors - TB spacer - Eurocode sway bars - ER10S - Cwa 100-3 - RSnav S4 12.3"
    Tesla 3 Performance
    Aug 14 2019
    Tampa
    Quote Originally Posted by snowfree52 View Post
    The one on the grill isn't glued....
    18 S6
    Sep 15 2017
    Here's what I've found since I originally posted:
    1) Audi sells black front and back rings: ZAW-098-010-Q-DSP
    2) Audi also sells the rear S6 badge in black: 4K0071804 (it's technically for the C8 cars, but the non-black C8 emblem is the same part # for the C7, so the black badge should work)
    3) The front S6 badge for the C8 does not cross-reference to the C7 cars, so I'm not sure if the C8 black badge will fit. Still looking to see if it will work.
    4) Audi does not sell black V8T badges; if I decide to keep them, looks like I'll either have to paint OEM badges or look on Ebay.
    Appreciate if anyone has any ideas for the front S6 badge.
    Feb 15 2011
    Northern VA
    Did you click on the link I posted above?
    https://www.enthusiastbrand.com/coll...39691159240877
    Front rings for the S6 are 285mm x 99mm.. I installed them on my car two weeks ago without issue. They also have the black V8T badges
    Aug 14 2019
    Tampa
    jzwecker sells black badges also, a user here on the forum. Just another alternative option for you, and he can do the V8T black as well as everything else.
    Be careful with the front grill rings. Just because they are the same dimensions, does NOT mean the mounting tabs are the same pattern. Ask me how I know.....
    18 S6
    Veteran Member Four Rings ANMS4's Avatar
    Dec 18 2012
    Framingham MA
    May want to check here :)
    https://theplategram.com/
    I did all mine Gloss Black and mirror purple S8. They look amazing. I haven't them installed yet though. Going on this week
    2014 S8*SMR Intakes*HMD Exhaust*DS1 tuned by SLEEPERTUNED*E50* MELEN TCU TUNE
    SOLD 2014 A6-IE STG2 DP+ TB E40 tune and Melen TCU Flash, RS7 Airbox, AWE Touring Catback+Resonated DP, Ported SC By Shane
    Feb 15 2011
    Northern VA
    Some require you snap off two tabs that aren't needed.. doesn't affect how they fit in the slightest
    Aug 14 2019
    Tampa
    Quote Originally Posted by Yeoman View Post
    Yeah, I'm sure you could, but I snapped no tabs and mine fits.
    18 S6
    Sep 15 2017
    Confirmed that 4K0-071-805 (the black S6 emblem that snaps on to the grille) fits C7.5 (part # is for a C8 but the badge fits perfectly). Therefore, it appears that you can get all front/rear badges (except the V8T badges which you can either delete or buy on Ebay) directly from Audi.
