Results 1 to 11 of 11
    Junior Member Two Rings NavBlue19's Avatar
    Jul 31 2022
    2003 Cadillac Escalade EXT
    Washington State
    Help! I've looked everywhere! Apple Car Play Won't Connect
    Hi guys.* This is for a 2019 SQ5 Prestige
    I've searched this forum, Audiworld, my FB groups and also called my Audi Service department and still can't figure out what is going on with my Apple Car Play.* It was working fine on Sunday, then on my way to drop her off at the Detailers for paint correction and ceramic coat, the Car Play just stopped working and I couldn't get it to reconnect.* When I picked her up on Tuesday evening, same issue.* When I plug it in, the phone makes the "battery charging" chime but Car Play doesn't kick on.* The Audi Smartphone Interface screen pops up that says "to use Apple Car Play, please connect a compatible smartphone using USB port...blah blah blah" then you have the optioni to change to connection manager or cancel.* Clicking on "change to connection manager" was how I was able to get Car Play to pop up.* Now it just takes me to the Connection Manager settings screen that shows primary phone, secondary phone, MMI connect app, BT Player etc.* I've tried resetting my MMI, checking all Car Play settings I can think of on my phone, "forgetting" the phone on the car, reinstalling, forgetting the MMI on the phone and reinstalling, different USB cables, all to no avail.* Anyone have this issue?
    Established Member Two Rings billspudman's Avatar
    Jul 15 2013
    B8.5 S5, B8 S4, C5 A6 avant
    Plymouth, MA
    Have you tried rebooting your phone?
    Established Member Two Rings nerdybeard's Avatar
    Jan 17 2015
    B9 SQ5
    East Bay, CA
    A few random things to consider:
    - Try a different phone to isolate the issue to your phone vs the MMI
    - Reboot the phone
    - Check the USB port on the phone. Oftentimes a bit of lint can get in there and ruin connections that require more than just charging
    - If you have a MDM installed by your work, that could potentially affect how it connects to external sources
    B9 SQ5 Navarra Prestige | 034 Stage 3+ TTE810, Wagner FMIC, CTS catted downpipe, 034 HPFP upgrade, 034 X34 Intake, 034 Inlet, 034 Trans insert, 034 ZTF-01 Forged 21x10 et32 + 5mm rear spacer, 295/35, CETE Module, Fuel-it, Maxton body kit,
    Past: B9 S5 Sportback, B8.5 S4, 4M Q7, B7 S4, B8.5 SQ5, mk4 R32, mk6 R, mk4 gti, '95 90 Quattro sport
    IG: @dom_quattro
    Apr 08 2011
    '21 SQ5 & '16 Golf R
    NoVA
    My 2021 has two USB ports that can connect to the MMI, do you have 2 as well? If so, try the other one in case it's a problem with the port itself.
    iain
    Junior Member One Ring
    Apr 22 2022
    San Antonio TX
    I would also try a different cable, I had one that would charge, but didn't work with CP, changed cable, and it worked.
    2018 RS5 Coupe Mythos Black
    2020 SQ5 Ibis
    2021 RS5 Ascari Edition Sportback
    Apr 08 2011
    NoVA
    Quote Originally Posted by piperman View Post
    I’ve also had cables that did work with CarPlay for a year or 2 just randomly stop working with CP but would still charge.
    iain
    Apr 08 2011
    NoVA
    Dude posted over at AudiWorld that it’s fixed. He didn’t have CarPlay enabled on for his phone in the MMI.
    iain
    Jul 31 2022
    Washington State
    Thanks for all of the suggestions! I tried them all prior to posting. It wasn’t that Car Play wasn’t enabled in my MMI, it was that my phone was showing up under Audi Smartphone and I had no idea to look there. I simply saw it under primary phone with no option to select anything but Bluetooth. So now I know that in order to change settings, I have to look both places.
    And I’m not a dude. But thanks for not assuming I’m some helpless girl! Cuz I am. Lol.
    Jan 13 2021
    San Diego, CA
    I have a 2018 Audi A4 and have had frustrating connectivity issues with my iPhone via USB cable with CarPlay. 80% of the time it works fine. But 10% of the time the system says to use CarPlay, connect a smartphone. Usually by unplugging the phone and plugging it back in several times I can get it to connect. The other 10% of the time, it connects successfully, but the screen goes completely blank and then comes on and off every few seconds. In this case it appears to go blank when my speed falls below 20mph and returns to normal when my speed increases above 20mph. This has been consistently happening with multiple phones and multiple cables. My phone connects normally in my wife’s Audi Q5. The dealer’s mechanics have been no help as the computer says there are no faults. Anyone have any ideas?
    Senior Member Two Rings robb1887's Avatar
    Apr 24 2021
    Virginia
    Anyone know if this was an over-air update to the MMI that got pushed? I was frustrated the week prior to this comment as my AA stopped connecting via my AAwireless dongle and cable connections that had zero issues prior for weeks. Just seems odd it got "disabled" randomly. I didnt think over-air updates were a thing in this platform?
    18 SQ5 Prestige
    EPL, ForgedOne, CETE
    Build Thread
    Apr 08 2011
    NoVA
    I had an OTA update yesterday on the MMI. No clue what it did though.
    iain
