Not to beat a dead horse, I got my rosstech hex-v2 today and here is my scan after clearing stored docs. It looks like I need a steering module. The scan reveals 2 part numbers one ending in r and one in s. Does it matter which one I get, and will they be up and play. My research suggests the donor car had to have the same options as my car. How detailed do those options have to be? Are they referring to mldel, package, or even more detailed than that. If I get the right part and the options don't match then I have to code it to the car, right. And then do adaptation so it is calibrated correctly. Can vcds do this if the part numbers match exactly? Thanks again for everybody's input
Tuesday,23,August,2022,13:34:18:24361
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 22.3.1.4 (x64) *HEX-V2 CB: 0.4615.4
Data version: 20220407 DS337.0
www.Ross-Tech.com
VIN: WAUB8GFF8G1065461 * License Plate: LNT7926
Mileage: 151439km-94099mi * Repair Order:
Chassis Type: FF-AU37 (5Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 22 42 44 52 55 5F 6C BB BC
VIN: WAUB8GFF8G1065461 * Mileage: 151439km-94099miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
22-AWD -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
6C-Back-up Cam. -- Status: OK 0000
BB-Door Rear Drv -- Status: OK 0000
BC-Door Rear Pass -- Status: OK 0000
Address 01: Engine (J623-CNTC) * * * Labels:. 06K-907-425-V1.clb
* *Part No SW: 5G0 906 259 D * *HW: 06K 907 425 B
* *Component: 2.0l R4 TFSI *H13 0002 *
* *Revision: --H13--- * *CVN: 5FAD45A3
* *Coding: 0A1D00124426000F2000
* *Shop #: WSC 06385 790 00016
* *ASAM Dataset: EV_ECM20TFS0205G0906259D 001003
* *ROD: EV_ECM20TFS0205G0906259D.rod
* *VCID: 2F3B1E505798BEE3665-807A
* *VINID: 9D1952217596217040185106046B55D7B7
1 Fault Found:
17178 - Databus
* * * * * U1123 00 [032] - Received Error Message
* * * * * Intermittent - Not Confirmed - Tested Since Memory Clear
* * * * * * *Freeze Frame:
* * * * * * * * * * Fault Status: 00000001
* * * * * * * * * * Fault Priority: 6
* * * * * * * * * * Fault Frequency: 1
* * * * * * * * * * Mileage: 151221 km
* * * * * * * * * * Date: 2022.08.18
* * * * * * * * * * Time: 06:57:56
* * * * * * * * * * Engine RPM: 0.00 /min
* * * * * * * * * * Normed load value: 0.0 %
* * * * * * * * * * Vehicle speed: 0 km/h
* * * * * * * * * * Coolant temperature: 61 °C
* * * * * * * * * * Intake air temperature: 58 °C
* * * * * * * * * * Ambient air pressure: 970 mbar
* * * * * * * * * * Voltage terminal 30: 12.558 V
* * * * * * * * * * Unlearning counter according OBD: 35
* * * * * * * * * * Drivetrain coordinator: ACC fault status-ACC is active despite
EPB deceleration: No
* * * * * * * * * * Drivetrain coordinator: ACC fault status-ACC active: although
TSK passive: No
* * * * * * * * * * Drivetrain coordinator: ACC fault status-Start off or stop
request at stopping speed not set: No
* * * * * * * * * * Drivetrain coordinator: ACC fault status-Start off and stop
request sent simultaneously: No
limiter active: No
* * * * * * * * * * Drivetrain coordinator: ACC fault status-ACC reactivates
itself after locking: No
* * * * * * * * * * Drivetrain coordinator: ACC fault status-ACC sends undefined
signals: No
* * * * * * * * * * Drivetrain coordinator: ACC fault status-ACC active although
main switch off: No
driver braking: No
ESP/ASR passive sampling: No
* * * * * * * * * * Drivetrain coordinator: brake fault status-Deceleration sensor
not available: No
malfunction: No
* * * * * * * * * * Drivetrain coordinator: brake fault status-ESP system error:
No
malfunction due to inaccurate engine torque: No
* * * * * * * * * * Drivetrain coordinator: brake fault status-ESP indicates TSK
message consistency error: No
* * * * * * * * * * Drivetrain coordinator: brake fault status-TSK/ESP handshake
error: No
* * * * * * * * * * Drivetrain coordinator: brake fault status-ESP automatic
engagement malfunction: No
* * * * * * * * * * Drivetrain coordinator: brake fault status-Brake light
implausible: No
Readiness: 1000 0000
Address 02: Auto Trans (J743) * * * Labels: 0D9-927-770.clb
* *Part No SW: 0D9 300 013 B * *HW: 02E 927 770 AQ
* *Component: DQ250-6A MQB *H53 4902 *
* *Revision: 06253104 * *Serial number: TFK01511040147 CVN: 000019E2
* *Coding: 0014
* *Shop #: WSC 04742 780 00200
* *ASAM Dataset: EV_TCMDQ250021 001001
* *ROD: EV_TCMDQ250021.rod
* *VCID: 1675CBB4C8026F2B053-8042
No fault code found.
Address 03: ABS Brakes (J104) * * * Labels: 5Q0-907-379-IPB-V1.clb
* *Part No SW: 3Q0 907 379 AA * *HW: 3Q0 907 379 F
* *Component: ESC * * * * * H42 0623 *
* *Revision: 00000000 * *Serial number: 63175000002121
* *Coding: 13FF6A9234260A71017B030681C429C8562C5080C08194B602 4100548208
* *ASAM Dataset: EV_Brake1UDSContiMK100IPB 034036
* *ROD: EV_Brake1UDSContiMK100IPB_034_VW37.rod
* *VCID: 79AFE008D95CA053881-802C
1 Fault Found:
0128 - Function Restricted due to Insufficient Voltage
* * * * * U1400 00 [008] - -
* * * * * [undervoltage]
* * * * * Intermittent - Confirmed - Tested Since Memory Clear
* * * * * * * * * * Fault Priority: 1
* * * * * * * * * * Reset counter: 91
Address 08: Auto HVAC (E87) * * * Labels:| 8V0-820-043.clb
* *Part No SW: 8V0 820 043 C * *HW: 8V0 820 043 C
* *Component: AC Automat * *H14 0060 *
* *Revision: 20028000 * *Serial number: 00000000798095
* *Coding: 03000014010000000000000000001400
* *ASAM Dataset: EV_AirCondiFrontVaAU37X 008020
* *ROD: EV_AirCondiFrontVaAU37X_008.rod
* *VCID: 323D172444AA930B09B-8066
* *Humidity sensor: exterior:
* *Subsystem 1 - Part No SW: 4H0 907 658 * * HW: 4H0 907 658
* *Component: AQ_Hum_Sensor *H03 0003
* *Serial number: 9C084BD7000000000001
Address 09: Cent. Elect. (J519) * * * Labels:| 5Q0-937-08X-MV1.clb
* *Part No SW: 5Q0 937 085 AH * *HW: 5Q0 937 085 AE
* *Component: BCM MQBAB MNA H24 0175 *
* *Serial number: 01061531800705
* *Coding: 04141A42C04122F541C0400451100700000000000000000000 0000000000
* *ASAM Dataset: EV_BCMMQB 015001
* *ROD: EV_BCMBOSCH_015.rod
* *VCID: 7F5B0E10C7788E63B65-802A
* *Wiper motor control module:
* *Subsystem 1 - Part No SW: 8V1 955 119 C * *HW: 8V1 955 119 A *Labels: 5QX-955-
119-V1.CLB
* *Component: WWS371 151109 *043 0585
* *Serial number: * * * * 151118003933
* *Coding: 0A47F7
* *Rain/Light Recognition Sensor:
* *Subsystem 2 - Part No SW: 8U0 955 559 C * *HW: 8U0 955 559 B *Labels: 8U0-955-
559.CLB
* *Component: G397_RLFS *H06 0004
* *Serial number: 60958145 * * * * * *
* *Coding: 00006C
* *Light switch:
* *Subsystem 3 - Part No SW: 8V0 941 531 AD * *HW: 8V0 941 531 AD
* *Component: E1 - LDS MQB *H05 0032
* *Serial number: 12 09 2015 *00000512
* *Alarm horn:
* *Subsystem 4 - Part No SW: 5Q0 951 605 A * *HW: 5Q0 951 605 A
* *Component: Sirene, DWA *005 0312
* *Serial number: 00000000000064276536
* *Sunroof control module:
* *Subsystem 5 - Part No SW: 8V3 959 591 A * *HW: 8V3 959 591 A
* *Component: J245 PS73.404 *H03 0004
* *Serial number: 0000FST000NY2OB00000
* *Coding: 101F00
2 Faults Found:
395273 - Control Circuit for Signal Horn
* * * * * B1344 14 [008] - Open or Short to Ground
* * * * * * * * * * Fault Priority: 2
* * * * * * * * * * Reset counter: 85
* * * * * * * * * * Mileage: 151120 km
* * * * * * * * * * Date: 2022.08.15
* * * * * * * * * * Time: 22:27:53
* * * * * * * * * * Terminal 15 status: OFF
* * * * * * * * * * Terminal 50 status: OFF
* * * * * * * * * * CAN-Bus_aktiv: OFF
* * * * * * * * * * Status Bremslichtschalter (HW): OFF
* * * * * * * * * * Status Bremslichtschalter (CAN): OFF
* * * * * * * * * * OFF: operated
* * * * * * * * * * Position lamps: Not operated
* * * * * * * * * * Automatic high beam assist: Not operated
* * * * * * * * * * Low beam: Not operated
* * * * * * * * * * Parking light left: Not operated
* * * * * * * * * * Parking light right: Not operated
* * * * * * * * * * last_wakeup: no cause for fault protection
* * * * * * * * * * Voltage: 12.8 V
* * * * * * * * * * Outside temperature: 24.0 °C
545300 - Databus
* * * * * U1123 00 [009] - Received Error Message
* * * * * Confirmed - Tested Since Memory Clear
* * * * * * * * * * Reset counter: 40
* * * * * * * * * * Mileage: 150908 km
* * * * * * * * * * Date: 2022.08.14
* * * * * * * * * * Time: 00:25:55
* * * * * * * * * * Terminal 15 status: On
* * * * * * * * * * CAN-Bus_aktiv: On
* * * * * * * * * * OFF: Not operated
* * * * * * * * * * Automatic high beam assist: operated
* * * * * * * * * * Voltage: 12.1 V
* * * * * * * * * * Outside temperature: 26.5 °C
Address 10: Park/Steer Assist (J446) * * * Labels:| 5Q0-919-294.clb
* *Part No SW: 5Q0 919 294 K * *HW: 5Q0 919 294 A
* *Component: PARKHILFE 8K *H03 0054 *
* *Revision: -------- * *Serial number: 39391531508713
* *Coding: 0010150011
* *ASAM Dataset: EV_EPHVA18AU3700000 002026
* *ROD: EV_EPHVA18AU3700000_002_VW37.rod
* *VCID: 43D342E0EB102A8392D-8016
1 Fault Found:
13637426 - Databus
* * * * * U1123 00 [008] - Received Error Message
* * * * * [ESP - ESP_21.ESP_Systemstatus - Fehlerspeicher auslesen]
* * * * * * * * * * Reset counter: 89
Address 15: Airbags (J234) * * * Labels:| 5Q0-959-655.clb
* *Part No SW: 5Q0 959 655 J * *HW: 5Q0 959 655 J
* *Component: AirbagVW20 * *010 0830 *
* *Serial number: 003GCR04127T
* *Coding: 9DCCFCC0000000005000001AC24800000065
* *ASAM Dataset: EV_AirbaVW20SMEVW37X 002144
* *ROD: EV_AirbaVW20SMEVW37X_VW37.rod
* *VCID: 47CB56F0DF2806A34E5-8012
* *Left seat belt tensioner:
* *Subsystem 1 - Part No SW: 5G0 980 945 B * *HW: 5G0 980 945 B
* *Component: BeltPretRevFL *H36 0350
* *Serial number: 34230167A23111551404
* *Coding: 333135
* *Right seat belt tensioner:
* *Subsystem 2 - Part No SW: 5G0 980 946 B * *HW: 5G0 980 946 B
* *Component: BeltPretRevFR *H36 0350
* *Serial number: 34230168A24111540267
* *Coding: 333135
* *Seat occupied recognition passenger side:
* *Subsystem 3 - Part No SW: 5C6 959 339 B * *HW: 5C6 959 339 B
* *Component: BF-Gewichtss.* H10 0046
* *Serial number: 694000000000001F0L2F
* *Coding: 303332
* *Crash sensor for side airbag: driver side:
* *Subsystem 4 - Part No SW: ----------- * *HW: 480 000 311 15
* *Component: SideSensor_Df *001 0887
* *Serial number: 35700000000264147714
* *Coding: 2D2D2D
* *Front Passenger's Side Airbag Crash Sensor:
* *Subsystem 5 - Part No SW: ----------- * *HW: 480 000 311 15
* *Component: SideSensor_Pf *001 0887
* *Serial number: 35800000000554147717
* *Coding: 2D2D2D
* *Rear Side Airbag Crash Sensor (on driver's side):
* *Subsystem 6 - Part No SW: ----------- * *HW: 480 401 111 15
* *Component: SideSensor_Dr *001 6149
* *Serial number: 3510002C71D3F984A28H
* *Coding: 2D2D2D
* *Passenger side rear thorax airbag crash sensor:
* *Subsystem 7 - Part No SW: ----------- * *HW: 480 401 611 15
* *Component: SideSensor_Pr *001 6149
* *Serial number: 3520002AD1E34433530W
* *Coding: 2D2D2D
* *Crash sensor for front airbag: driver side:
* *Subsystem 8 - Part No SW: ----------- * *HW: 480 401 808 15
* *Component: FrontSensor_D *001 6149
* *Serial number: 3550002A51CB0C04723$
* *Coding: 2D2D2D
* *Crash sensor for front airbag: front passenger side:
* *Subsystem 9 - Part No SW: ----------- * *HW: 480 401 708 15
* *Component: FrontSensor_P *001 6149
* *Serial number: 3560002B71D1B624D0ED
* *Coding: 2D2D2D
1 Fault Found:
9483008 - Seat Occupied Recognition
* * * * * B10B3 00 [008] - Function Restriction due to Implausible Message(s)
* * * * * * * * * * Time: 06:58:14
Address 16: Steering wheel (J527) * * * Labels:| 5Q0-953-549.clb
* *Part No SW: 8V0 953 521 EP * *HW: 5Q0 953 549 E
* *Component: Lenks. Modul *003 0120 *
* *Revision: -------- * *Serial number: 17111508490172
* *Coding: A018
* *ASAM Dataset: EV_SMLSKLOMQB 020001
* *ROD: EV_SMLSKLOMQB_009_AU37.rod
* *VCID: 0C41A9DC86CEA5FBA37-8058
1 Fault Found:
617752 - Selector Lever Park Position Lock Switch
* * * * * B1162 29 [024] - Signal Implausible
* * * * * Intermittent - Confirmed - Not Tested Since Memory Clear
* * * * * * * * * * Reset counter: 86
* * * * * * * * * * Mileage: 151131 km
* * * * * * * * * * Date: 2022.08.16
* * * * * * * * * * Time: 01:59:08
* * * * * * * * * * Operating time: 185929 min
* * * * * * * * * * Terminal 30 power supply: 14.1 V
* * * * * * * * * * Vehicle speed: 10 km/h
* * * * * * * * * * Voltage at switch: 4.98 V
* * * * * * * * * * Terminal 15 status: active
* * * * * * * * * * System status: 30
Address 17: Instruments (J285) * * * Labels:| 5G0-920-XXX-17.clb-SRI3
* *Part No SW: 8V0 920 960 M * *HW: 8V0 920 960 M
* *Component: KOMBI * * * * H03 6423 *
* *Coding: 0BF418092B80D7050200A8001800000000000000
* *ASAM Dataset: EV_DashBoardVDDMQBAB 009051
* *ROD: EV_DashBoardVDDMQBAB_009_VW26.rod
* *VCID: 45D75CF8E52414B3BC9-8010
Address 19: CAN Gateway (J533) * * * Labels:| 5Q0-907-530-V1.clb
* *Part No SW: 5Q0 907 530 AJ * *HW: 5Q0 907 530 M
* *Component: GW MQB High * 212 2246 *
* *Revision: -------- * *Serial number: 11111510520540
* *Coding: 0101000830085A005B00020C180B0000000101000000000000 0000000000
* *GVL: 01D43C0000000000400C10000002C800000000000000000000 00000000000000
* *ASAM Dataset: EV_GatewConti 013020
* *ROD: EV_GatewConti_013.rod
* *Generator:
* *Multifunction steering wheel control module:
* *Subsystem 2 - Part No SW: 8U0 951 528 A * *HW: 8U0 951 528 A
* *Component: E221 - MFL *H02 0014
* *Serial number: 13 11 2015 *C0036786
Address 22: AWD (J492) * * * Labels:* 0CQ-907-554.clb
* *Part No SW: 0CQ 907 554 H * *HW: 0CQ 525 130
* *Component: Haldex4Motion H52 7083 *
* *Serial number: HA1-00031.05.17
* *Coding: 0001
* *Shop #: WSC 00000 000 00000
* *ASAM Dataset: EV_AllWheelContrHA1VW37X 004013
* *ROD: EV_AllWheelContrHA1VW37X_004.rod
* *VCID: 4ACD6FC4CC3AFBCB51B-801E
Address 42: Door Elect, Driver (J386) * * * Labels:| 5QX-959-X93-42.clb
* *Part No SW: 5Q0 959 393 E * *HW: 5Q0 959 393 B
* *Component: TSG FS * * * *020 0041 *
* *Serial number: 031015BJ218338
* *Coding: 00100B204000048000000002
* *ASAM Dataset: EV_DCUDriveSideEWMINKLO 006003
* *ROD: EV_DCUDriveSideEWMAXCONT.rod
* *VCID: 41DF48E8F10C3893801-8014
Address 44: Steering Assist (J500) * * * Labels:| 5Q0-909-144.clb
* *Part No SW: 5Q0 909 144 S * *HW: 5Q0 909 144 R
* *Component: EPS_MQB_ZFLS *126 1063 *
* *Coding: 0102
* *ASAM Dataset: EV_SteerAssisMQB 012140
* *ROD: EV_SteerAssisMQB_012_VW37.rod
* *VCID: 44D141FCEE1E2DBBAB7-8010
2 Faults Found:
4868 - Internal Fault
* * * * * B200F F0 [008] - Unknown Error Elaboration
* * * * * [Fehler im Abschaltpfadtest 2nd current check (PWM: 35/65/50)]
* * * * * * * * * * Fault Frequency: 3
* * * * * * * * * * Mileage: 150904 km
* * * * * * * * * * Time: 00:00:11
* * * * * * * * * * Motor status: 00
* * * * * * * * * * System status: Reset
* * * * * * * * * * Supply voltage: 14.75 V
* * * * * * * * * * Temperature: 22.0 °C
* * * * * * * * * * KFC: 13
* * * * * * * * * * KFA: 00 04
* * * * * * * * * * Freeze frame conditions: 71
* * * * * * * * * * nApplI_RotorSpeedFilt_xds16: 37 /min
* * * * * * * * * * mApplI_LimitedMotorTorque_xds16: 0.000 Nm
* * * * * * * * * * icuCurrentPhase_U_IRQ_xds16: 21.75 A
* * * * * * * * * * icuCurrentPhase_W_IRQ_xds16: -24.00 A
* * * * * * * * * * mApplI_TorsionBarTorque_xds16: 0.00 Nm
* * * * * * * * * * wrsCurrRotorPosIRQ_xdu16: 69.7 °
229504 - Internal Control Module Memory Check Sum Error
* * * * * B2000 00 [153] - -
* * * * * [Steuergerät defekt - Interne Störung]
* * * * * MIL ON - Confirmed - Not Tested Since Memory Clear
Address 52: Door Elect, Pass. (J387) * * * Labels:| 5QX-959-X92-52.clb
* *Part No SW: 5Q0 959 392 E * *HW: 5Q0 959 392 B
* *Component: TSG BFS * * * 020 0041 *
* *Serial number: 300815BHT13339
* *Coding: 001003204000048000000002
* *ASAM Dataset: EV_DCUPasseSideEWMINKLO 006003
* *ROD: EV_DCUPasseSideEWMAXCONT.rod
* *VCID: 40D94DECFA06319B8FF-8014
Address 55: Headlight Range (J431) * * * Labels:| 5Q0-907-357.clb
* *Part No SW: 5Q0 907 357 * * HW: 6R0 907 357 A
* *Component: LWR-ECU * * * 005 0080 *
* *Revision: -------- * *Serial number: --------------
* *Coding: 012A000101000000
* *ASAM Dataset: EV_HeadlRegulVWLWRMQB 001110
* *ROD: EV_HeadlRegulVWLWRMQB.rod
* *VCID: 75B7EC38F544C433EC9-8020
Address 5F: Information Electr. (J794) * * * Labels:| 8V0-035-MIB-STD1.clb
* *Part No SW: 8V0 035 844 C * *HW: 8V0 035 844
* *Component: MU-S-S-US * * 014 0660 *
* *Serial number: A7A02011150405
* *Coding: 01730100FF0A000011220001001A00002F0001440100010002
* *ASAM Dataset: EV_MUStd6C3PASE 002020
* *ROD: EV_MUStd6C3PASE.rod
* *VCID: 392F200899DC6053C81-806C
* *Multimedia System 1:
* *Subsystem 1 - Part No SW: 8V0 919 603 C * *HW: 8V0 919 603 C
* *Component: DU Std *H49 0014
* *Serial number: AUZ8Z9FY30ENMZ * * *
* *Multimedia system control head:
* *Subsystem 2 - Part No SW: 8V0 919 614 P * *HW: 8V0 919 614 P
* *Component: ControlUnit_B *H41 0054
* *Serial number: C1000008101500010091
1 Fault Found:
0020 - Tuner for Satellite Radio
* * * * * B11CF 53 [009] - Deactivated
* * * * * * * * * * Fault Priority: 4
* * * * * * * * * * Time: 00:26:21
* * * * * * * * * * Voltage terminal 30: 12.1 V
* * * * * * * * * * Satellite radio tuner status-Satellite radio antenna status:
electrically OK
* * * * * * * * * * Satellite radio tuner status-Channel selection for satellite
radio: 0
* * * * * * * * * * Satellite radio tuner status-Audio Signal: Not available
* * * * * * * * * * Satellite radio tuner status-Antenna current: 0 mA
* * * * * * * * * * Satellite radio tuner status-Reception quality: Not available
* * * * * * * * * * Satellite radio tuner status-SDARS Flash Regional code:
US_Audio_Traffic_Travellink
Address 6C: Back-up Cam. (J772) * * * Labels:| 5Q0-907-441.clb
* *Part No SW: 5Q0 907 441 A * *HW: 5Q0 907 441 A
* *Component: MQB RVC Mid * H07 0140 *
* *Coding: 027300010201000300
* *ASAM Dataset: EV_2CamSysRearPASE 006016
* *ROD: EV_2CamSysRearPASE.rod
* *VCID: 30391D2C4AA6A11B7FF-8064
Address BB: Door Rear Drv (J388) * * * Labels:* None
* *Part No SW: 5Q0 959 395 E * *HW: 5Q0 959 395 B
* *Component: TSG HFS * * * 020 0041 *
* *Serial number: 161015BJE0527C
* *Coding: 000003204000048000000002
* *ASAM Dataset: EV_DCURearDriveMINKLO 006003
* *ROD: EV_DCURearDriveMAXCONT.rod
Address BC: Door Rear Pass (J389) * * * Labels:* None
* *Component: TSG HBFS * * *020 0041 *
* *Serial number: 161015BJE05275
* *ASAM Dataset: EV_DCURearPasseMINKLO 006003
* *ROD: EV_DCURearPasseMAXCONT.rod
End----------(Elapsed Time: 01:31, VBatt start/end: 12.2V/12.3V)-----------
Sent from my SM-N960U using
Audizine Forum mobile app
