I just did mine last weekend using a Motive pressure bleeder:
1. bleed order goes from farthest from reservoir to closest (RR,RL,FR,FL).
2. Fill Motive up with 1 liter of new fluid
3. Pressurize to 10 psi
4. rears crack bleeders (11mm)
5. front, 2 bleeders per caliper, do inside ones first then outside ones
Just periodically check the pressure in the Motive stays around 6-10 psi, might need to pump it up a few times.
My tool list was
1. Motive Power Bleeder (or similar)
https://www.amazon.com/Motive-Produc...0002KM5L0?th=1
2.Fluid catch can (or similar)
https://www.arestool.com/products/1l...servoir-bottle
3. Pentosin super dot 4
https://www.fcpeuro.com/products/sup...iABEgJvG_D_BwE
4. 11 tubing wrench or similar
5. CRC brake clean or similar
Wont need Vag-Com unless you are changing the rear pads, super easy, will take you longer to jack the car up and get wheels off then bleed, just make sure you leave a little fluid in the Motive, i used liked 800ml.
Cheers
