So i had a little oil seeping out of the right side valve cover, which I suspect the leaking is/was caused from pcv going bad (which i'm also replacing).
Got a missing bolt now, no idea how as the bolts don't usually come off the cover on their own unless you push them out. It looks like the bolts are not sold and you must buy the whole valve cover!
I ordered 03G128773A thinking i could simply remove the rubber grommet and it would work, but the bolt is literally too short despite it showing up on most part sites for the RS4.
Planning to just buying the left side valve cover (it's an 07 with early "defective" cover which isn't even leaking) and using one of the old bolts from that cover on the missing right side cover.
Unless of course someone can source me a spare bolt from under their pillow.
