Results 1 to 9 of 9
    Oct 23 2015
    Australia
    Anyone cleaned their coolant exp tank ? if so how ?
    I seem to recall years ago on some car I used hydrochloric acid,I know I know seems extreme but it is plastic and worked iirc.
    Any other thoughts as mine is pretty gungy considering the low mileage and coolant replacement done,it drags the look of the otherwise clean engine bay down.....
    Heidi - Audi A4 B8.5 T Q S-line,7 DSG,-Ibis white- E-tuners stage 1 ecu/tcu, lowered on Vogtlands ,19"rotors,quad exhaust,S4 diffuser,full Maxton skirt kit,AEM intake,10" Android auto screen
    Veteran Member Four Rings RPMtech147's Avatar
    Apr 05 2014
    Texas
    https://www.ecstuning.com/b-uro-part...k0121403q~uro/
    You can get a new tank for $20. Just saying. If it's that discolored it's a leak waiting to happen.
    To directly answer your question I have had luck with straight cooling system cleaner from the parts store for getting sludge out of tanks. Pour it in, shake, rinse, repeat.
    B6 S4, B8 A4, 8P A3, and something, something.
    Oct 23 2015
    Australia
    Quote Originally Posted by RPMtech147 View Post
    $20,not in Australia though, basically only genuine here for parts like that but good thought about the system cleaner...
    Oct 23 2015
    Australia
    I'm wondering how vinegar would work.I've only just discovered what an effective rust remover it is and it works de-scaling coffee machines for sure.Way more user friendly than H.acid.
    Veteran Member Three Rings SNice's Avatar
    Aug 06 2019
    Philadelphia
    +1!
    OP - definitely try and determine what caused the discoloration. Mine was discolored as well when I purchased. I thought the PO might have used the wrong coolant or tried some additive. My coolant reservoir was stained with a brown/orange hue. It wouldn’t come out. I discovered a heater core leak shortly after that.
    Once I fixed the heater core problem, my coolant remained pink. I then just replaced the reservoir and it has been fine ever since!
    2014 A4 B8.5 - AUDI _ EFR 6758 / WPT Stg. 3 Flex-Fuel TUNE / WM Injection / Custom HFC / JHM D-Pipe / AWE FMIC & EXHAUST / APR INTAKE / KW V3
    2002 SV650 - SUZUKI
    1989 nt650 HAWK GT - HONDA
    1972/4 r5/rd350 Hybrid (WIP) - YAMAHA
    1971 r5 350 (basket case) - YAMAHA
    Oct 23 2015
    Australia
    Quote Originally Posted by SNice View Post
    +1!
    Interesting as my coolant has the same colour hue,no leaks so far touch wood.
    Apr 20 2020
    '04 allroad 2.7T, '07 A4 2.0T qt, '10 A4 2.0T, '10 TT 2.0T qt, '02 Ford Ranger 3.0L.
    Chino, CA
    After 10+ years, genuine stock tanks can crack. I have replaced more than 3 original tanks over the years in different Audi(s).
    Oct 23 2015
    Australia
    Quote Originally Posted by mc_hotmail View Post
    They can,our B7 cracked then the aftermarket cracked a year after install.Hairline crack near cap took a bit of finding...
    Dec 01 2020
    2014 Q5 2.0T
    I replaced the coolant reservoir in my 2014 last year. Wasn’t leaking yet but I could see the start of a crack from the heat cycling of the polymer. Good friend’s 2015 had the same issue but his was very slowly starting to leak around the same mileage (he is down in Florida so the car is generally seeing higher temps year round than mine). Pretty easy to replace just have some extra coolant on hand
