I'm adding a pre-oiler to my car and wanted an easier connection option than the oil pressure sender location. There's a large hex plug on the front of the valley cover that connects directly to the oil filter. I want to use that plug to connect the pre-oiler.
In reading this thread, it looked like the consensus was that the filter flow was from inside to out, which if true, would be opposite to most (every?) filters I've ever seen. So I did some analysis on my engine and my conclusion is the opposite for the following reasons:
- the oil pump outlet is via a tube to the upper pan, through the side-mounted oil cooler and back into the upper pan where it then connects to the block at the corner nearest the water pump
- the oil then flows up to the valley cover via a check valve. That check valve only permits flow in this direction, from the block into the valley cover
- the valley cover gallery with the large hex plug then travels to the driver's side inlet of the oil filter housing which directs the oil to the outside of the filter element
- oil flows through the element and back down the center of the housing and out to the oil filter outlet on the passenger side
- oil then flows into the main block gallery which feeds the crank and has outlets to various other places
- those places include the piston cooling sprays via a check valve, and the timing assembly and camshafts also via a check valve. This check valve can only permit flow from the main gallery through teh check valve and thence to the camshafts/timing chain adjusters via smaller galleries in the block that head up to the cylinder heads and rear timing cover
If all that is correct, then pre-oiling at that large plug is ideal because:
- the check valve in the block prevents the pre-oil running back to the oil pump
- the pre-oil will have to go through the filter, which is a good thing
- I don't have to mess with the oil pressure sender which is not easy to get to, relatively speaking
With that in mind, I had my guy make up a replacement plug, tapped for an M24x1.5 banjo which has a 5/8 JIC spigot which will connect to the pre-oiler which I plan to install behind the grill with an appropriate length of hose.
