As a follow up - car's reassembled but no boost and EPC light with numerous codes listed below. Unless someone knows of a software/sensor issue that resolved this, it's most likely coming apart again
4 Faults Found:
14944 - Magnetic Clutch for Supercharger
P25EB 00 [175] - Implausible Signal
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 89468 km
Date: 2022.08.03
Time: 20:04:29
Engine RPM: 693.00 /min
Normed load value: 8.6 %
Vehicle speed: 0 km/h
Coolant temperature: 90 °C
Intake air temperature: 59 °C
Ambient air pressure: 1000 mbar
Voltage terminal 30: 14.062 V
Unlearning counter according OBD: 40
Engine status: Idle
STATE_LS_SAE[1]: OL_INTR
T_AST_SAE: 0 s
Charge press.: average: 0.336 bar
Oxygen sensor before cat bank 1 (LSB) voltage: 2.172 V
FAC_TPS_1_SAE: 20.703125 %
FUP_H_SAE: 7410.0 kPa
24771 - Magnetic Clutch for Supercharger
P25E9 00 [175] - Stuck Open
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 89468 km
Date: 2022.08.03
Time: 20:06:13
Engine RPM: 1291.00 /min
Normed load value: 22.0 %
Vehicle speed: 6 km/h
Coolant temperature: 92 °C
Intake air temperature: 60 °C
Voltage terminal 30: 14.082 V
Engine status: Part throttle
Accelerator pedal position: 16.60 %
Compressor speed: 0 /min
Engine torque: 131.34375 Nm
Throttle valve angle: 7.520 °
Compressor magnetic clutch: current: 2.9 A
FUP_H_SAE: 4510.0 kPa
24596 - Current Sensor for Magnetic Clutch for Supercharger
P10AE 00 [047] - Elect. Malfunction
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 89468 km
Date: 2022.08.03
Time: 20:06:13
Engine RPM: 1095.00 /min
Normed load value: 23.5 %
Vehicle speed: 4 km/h
Voltage terminal 30: 14.101 V
Accelerator pedal position: 15.82 %
Engine torque: 139.06250 Nm
Throttle valve angle: 7.666 °
FUP_H_SAE: 4840.0 kPa
24653 - Turbocharger Speed Sensor 1
P2580 00 [175] - Short to GND
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 89468 km
Date: 2022.08.03
Time: 20:06:14
Engine RPM: 1367.50 /min
Normed load value: 20.8 %
Vehicle speed: 9 km/h
Voltage terminal 30: 14.042 V
STATE_LS_SAE[1]: CL
T_AST_SAE: 104 s
Charge press.: average: 0.618 bar
Oxygen sensor before cat bank 1 (LSB) voltage: 1.767 V
FAC_TPS_1_SAE: 25.781250 %
FUP_H_SAE: 4300.0 kPa
