Results 1 to 27 of 27
    Veteran Member Four Rings arjun90's Avatar
    Dec 27 2014
    2013 Audi Q5 3.0T
    Front Sway Bar Upgrade, Yes or No?
    I already settled for the Rear Sway Bay offering from 034. However, has anyone considered upgrading their front sway bars?
    Current:
    | Audi Q5 (B8) 2013 (3.0T, Quattro) |
    70,xxx Miles
    | Audi A6 (C6) Avant, 2010 (3.0T, Quattro) |
    182,xxx Miles
    Gone But Not Forgotten:
    | Audi A6 (C5) Avant, 2004 (3.0L, Quattro) |
    221,386 Miles [April 2014 - March 2022]
    New genuine Audi/VW parts for cheap within the US - audiusaoemparts.com
    New genuine Audi/VW parts for cheap if you can afford the wait - oemVWshop
    Veteran Member Four Rings SDV325's Avatar
    Jan 20 2014
    Calgary, AB
    I went ahead with Eurocode's USS front and rear sway bar setup, very happy with the results. The front bar definitely help absorb some bumps and smoothen out the suspension slightly. Corners much flatter too, the effects of the heavy pano roof has been reduced.
    Can't speak for the SQ but when I installed the rear a few weeks before the front on my B8 S4, while the understeer was greatly reduced the initial turn in and nose heavy problems were all still there. With the front bar installed a lot of that was reduced and the initial turn in was much flatter.
    2016 Audi SQ5 | Technik | Glacier White | Magma | Black Optics | Beaufort Inlays | Roc-Euro | Revivify Graphene Pro | EPL Stg 2 | Eurocode USS | MOOG Endlinks |
    2014 Audi SQ5 Estoril- STOLEN / RIP
    2015 Toyota Rav4 - Family Wagon
    Veteran Member Three Rings Clun9's Avatar
    Oct 09 2008
    B8.5 S4, SQ5 & Unicorn 337
    Quote Originally Posted by SDV325 View Post
    Stiffening up the front would give you quicker steering response but also induce more understeer as to running a stiffer RSB only. The reason why 034 opted for a RSB only instead of a full front and rear is so that the vehicles that run them have more rotation and less understeer. A lot of other companies make stiffer front and rear sways which really help with the roll rate of the car in proportion to OEM.
    MK4 337 GTi (custom widebody) | Bagged B6 S4 (SOLD BUT NOT FORGOTTEN) | B8.5 S4 (STOLEN & TOTALED) | Dual Pulley B8.5 SQ5
    Jan 20 2014
    Calgary, AB
    Quote Originally Posted by Clun9 View Post
    Agreed, when the front bar went it the understeer came back a little bit.
    Best of both worlds is to have coilovers or B8/new springs and a rear sway to really improve the handling properly (on my short list to do here shortly)
    Dec 27 2014
    2013 Audi Q5 3.0T
    Thank you for the feedback, I am definitely going with 034’s rear sway bar along with their end links for the Q5.
    A little off topic, do you think I may reap the same benefits for my A6 station wagon by doing just the rear sway bar or should I do the front as well? I feel like the Avant is very nose / front heavy
    Oct 09 2008
    Quote Originally Posted by arjun90 View Post
    Most VAG products with the exception of Porsche are similar in that a RSB and suspension does a LOT to liven up the car and driving dynamics. Most Audi's are still nose heavy but active suspension has changed that a bit.
    In your case, an RSB would def help.
    Junior Member Two Rings
    Jun 25 2022
    Los Angeles, CA
    What are the advantages to coil overs vs springs, struts, and shocks?
    Jun 25 2022
    Los Angeles, CA
    What does changing out the end links do?
    Veteran Member Three Rings bluebull's Avatar
    Aug 28 2014
    2017 R8 Nardo boosted with VF; 2017 SQ5; F250
    Portland, OR
    Do it
    I did Eurocode F & R with endlinks during a Black Friday sale
    TVS1320 APR, TTX36 Ohlins coils, DXD Flywheel + Clutch, JHM Shift Goodies, Euro Sport Reacecloth Seats, 034 mounts, Stern UCA, JHM full (resonated) exhaust with v-band test pipes and HF cats, JHM short shifter, Rotiform 19x10 with 275 PS4S, Fender to ground is 25.5", ceramic coated and PPF.
    Dec 27 2014
    2013 Audi Q5 3.0T
    Thanks for the suggestions, does the front strut brace (034 Motorsport) help with the alleviating under steer? I noticed they don't have a front sway bar upgrade option as they see it differently. I do admire their solid sway bar options though versus Eurocode's welded design
    Current:
    70,xxx Miles
    182,xxx Miles
    Sep 24 2014
    2015 Audi Q3 Quattro, 2017 Corvette M7 Grand Sport, 2017 Audi SQ5, 2019 Porsche Macan, 24 Jetta GLI
    Central NJ
    The chassis braces will not help understeer, they only improve steering precision. Swaybars, tire size, tire pressure, springs, and camber alter understeer characteristics
    Sep 24 2014
    Central NJ
    I upgraded both front and rear swaybars (Eurocode) on my B8 S4 (essentially the same chassis as the Q5), and have been very happy with the results.
    The only B8 Q5 swaybar sets (front and rear), are Eurocode EC0202-0401R (32mm hollow, 25.5mm hollow) and H&R 72092 (32mm solid, 26mm, solid).
    I bought the H&R set for my Macan, and I will put the factory Macan bars (31.5mm hollow, 24.5mm solid) on my B8 SQ5 (30mm hollow, 22mm solid). Two upgrades for the price of one!
    Tirerack.com has the best price ($617 plus tax, free shipping) on the H&R 72092, but I had to wait 2 months for them to ship (backordered).
    Established Member Two Rings slumber12's Avatar
    Jul 18 2014
    Audi Q5 3.0T
    West Burbs of CHI
    Quote Originally Posted by S4'ed View Post
    I know this post was from a minute ago but were the macan bars a direct fit for the B8 Sq5?
    2015 A3 2.0t Prestige S-Line
    Senior Member Three Rings supremedk's Avatar
    Dec 14 2009
    B8 SQ5
    Gilbert AZ
    Quote Originally Posted by Gillesper View Post
    I didn’t look at the 034 pieces, if they are harder rubber or sphericals they will transfer the load from the suspension movement quicker, basically the bar will respond a tiny bit faster without the deflection of a softer rubber.
    If they are length adjustable you can use that feature to remove any pre load from the bar.
    For a street car neither of these handling feature will be an “OMG” feeling if you even notice at all. Aftermarket units may be built a bit better and possibly last longer.
    Established Member Two Rings serg72's Avatar
    May 19 2021
    Kharkiv, Ukraine
    I want to share my experience of upgrade the front and rear sway bars.
    After reading the message from S4'ed about the replacement of sway bars from Macan to Q5, I started to study this issue.
    Information sway bars Audi Q5, SQ5 Front 8R0411309C - 29.7mm, rear 8R0311305Q - 22.5mm.
    Macan sway bars information and what is needed for installation:
    Front sway bar
    — 95B411309A
    — 95B411309C
    — 95B411309E - the maximum rigidity - 31.5 mm
    - Sway Bar Bushings 4D0411327J x2
    Rear sway bar
    — 95B511305
    — 95B511305A - 25.7 mm
    — 95B511305H – 24.5 mm
    — 95B511305J – 25mm – not sure
    — 95B511305E - the maximum rigidity - 26.2 mm
    - Sway Bar Bushings 95B511035 x 2
    - Clamps 95B511439 x2
    - Bolts N10695701 x4
    - Sway Bar End Link 95B505465 x 2
    The best setting is E+E, but I did not find rear sway bar E available on the secondary market. I will say right away that I considered buying only on the secondary market, so front E+ rear A was purchased in excellent condition. I installed it myself without any problems.
    What I got in general is a faster and clearer reaction to the steering wheel, got rid of insufficient steering and reduced body roll during sharp turns. I am satisfied with the obtained result in terms of car handling and considering the cost of this upgrade, I consider it an excellent price/result ratio.
    2014 Q5 3.0T S-Line | Glacier Grey |034 Stage 2+ 93 octane tune | CTS Crank Pulley 192mm / APR SC Pulley 57.75 | BG HPT ZF8 Tune | 2 CWA-50 pump / Custom HX + custom reservoir (Divorced Coolant Loop) | K&N filter/mod stock box intake /4" Intake Tube/ TB 84mm | 034 HPFP piston | Long tube headers/custom exhaust 2,5" | tires 265/45/20 |
    Jun 06 2014
    Washington, D.C.
    Quote Originally Posted by serg72 View Post
    Front sway bar
    — 95B411309A
    — 95B411309C
    Rear sway bar
    — 95B511305
    This is awesome information, thanks. Just picked myself up the same E + A setup on ebay for cheap. Can't wait to install. Has this mod increased NVH for you?
    B8 S4 6MT | GIAC Stage II | Milltek Non-Resonated | Hotchkis Sway Bars | ECS Intake | Roc-Euro Short Shifter | Eurocode Alu Kreuz | 034 Transmission Mount | 034 Rear Diff. Mount | RS4 Grille | CR-15 Brace | P3 Gauge | USP SS Clutch Line | ECS Rear Carrier Mounts | 034 Subframe mounts | ECS Street Shield | Moog Endlinks | MercRacing HX | B12 Pro Kit
    B8.5 SQ5 | 034 Stage II | MercRacing HX | RKX Transmission Mount | P3 Gauge
    Jun 21 2023
    As far as the rear A vs E…
    A is hollow, thought to increase surface area translating to increased stiffness. Is E solid or hollow?
    Veteran Member Four Rings 03TLSinCO's Avatar
    Feb 02 2018
    '16 S5 Prem Plus; '13 Q5 Prem Plus S-Line; '09 Honda Odyssey (The Wife's, in the driveway)
    CO
    Curious about just doing a rear sway bar upgrade. Made a world of difference on my S5 (front upgrade isn't considered necessary on the S). What about on the Q?
    2016 S5 Prem+, Moonlight Blue Metallic/Lunar Silver, Sport Diff, Black Optic Plus, B&O, Adaptive Damping Suspension. 034 Stage 2 ECU/TCU, RS5 grill, AWE S-FLO Intake, 034 X-Brace, 034 Rear Sway Bar, CR-15, Magnaflow non-resonated X-Pipe
    2013 Q5 Prem Plus S-Line, Moonlight Blue Metallic, 034 Stage 1 ECU/TCU
    May 19 2021
    Kharkiv, Ukraine
    Quote Originally Posted by Black&Blue View Post
    According to the information I found online, E is solid.
    Jun 21 2023
    So A&E may just be equivalent in rigidity, being A is only slightly smaller. I remember back in the day getting hollow away bars for my GTI VR6 on the claim that a hollow away bar has more surface area, compared to the solid Neuspeed at the time. Great informative post my man. Thank you…
    Junior Member One Ring
    Apr 01 2024
    Spain
    I’ve just bought the Macan rear one: 95B511305E.
    Does it fit in an Audi A4 B8?
    Sep 24 2014
    Central NJ
    Quote Originally Posted by AntonioL View Post
    No, the B8 Q5 / Macan bars do not fit a B8 A4/S4, as the A4/S4 bars are shorter in length.
    The longer Q5 / Macan bars are the same length as the C6 A6/S6 bars.
    Mar 17 2023
    Gainesville, FL
    Front sway bar
    — 95B411309A
    — 95B411309C
    Rear sway bar
    — 95B511305
    I just got the 95B411309E / F and 95B511305E for the rear, can't wait to put them on.
    Veteran Member Three Rings PassionForAudi's Avatar
    Aug 10 2016
    4M.5 SQ7, B8.5 A4 (hey, I keep it clean, though!) and 5th gen’ Ram 3500 Limited Mega Cab (DRW).
    Orange County/Inland Empire, C
    Absolutely NO LOVE for the SQ7 clique.
    Dec 14 2024
    UK
    Front sway bar
    — 95B411309A
    — 95B411309C
    Rear sway bar
    — 95B511305
    So I have purchased the 95B511305J – 25mm – rear sway bar. I have measured it to be 25.45mm
    I have the front version coming with an E. I have ordered all the other fitting parts from Porsche.
    I will try to fit them all Monday and report back on the E front J rear configuration on my SQ5
    Thank you for posting this useful info. It seems no one in the UK is doing this.
    - - - Updated - - -
    How did it go? Have you fitted these?
    Feb 02 2018
    CO
    Most people seem to be doing front and rear sway bar upgrades. Anyone just do the rear? That was all I needed in my S5. Since I've gone to an 034 Stage 1 tune in my Q5, I really need to upgrade the handling. Anyone just do the rear sway bar or are both absolutely necessary due to the weight of these cars?
    Dec 14 2024
    UK
    From what I have read over the past month its important to do both due to the weight of these cars. I am doing both to be sure. its only cost my less than £300 for both bars and all the fittings.
