There’s a great thread/document on Audiworld but it’s mostly B9 or different cars and nothing is confirmed working for the newer models, without scrolling through hundreds of pages at least.
https://docs.google.com/document/d/1...mG4MjDUXM/edit
Here is what I have done. So far I’ve not tried anything that failed, so all of these are tried and successful:
Scandinavian DRLs
Description: Tail lights on with DRLs.
Disable DRL Wink
Description: Instead of turning off the respective side DRL when turn signals come on, it will dim them. Side effect is that the taillights are always on. Example here.
Easy Entry
Description: Moves the seat back to help enter and exit the vehicle
Note: I did not do the additional or optional coding, I only did the first main section and have so far had it work 100% of the time with 0 issues
Changing Comfort Turn Signal Count
Description: This will change the number of times the blinker flashes when lightly pressing down on the turn signal stalk. By default, it blinks 3 times. Max value: 5.
Adjust the volume of the Lu Soundaktor
Description: Volume adjustment for the Soundaktor engine inside the car. To mute, use value: 0
Welcome sound
Description: Startup sound plays when MMI/vehicle is turned on
Adjust audio in MMI ‘Sound’ > ‘Welcome sound’ settings.
Note: I also changed an additional value, I now have the welcome tone on entry and the heartbeat on exit
Disable Head Lamp / Light Wash
Description: Disable head lamp / light wash
I’ve also had my lasers and matrix headlights activated, orange side markers removed and added the acceleration timer, this was not with OBDEleven but I have had no issues with this and the other changes I’ve made at all.
Instagram: @daytonars5
