Originally Posted by
AldermanToffee
At that point though you're better off with running VCDS given that it can decode the long coding and actually tell you what 90% of the individual bits in long coding specify.
The only other argument for that is "but you can use OBD11 on your phone".. in which case you can buy the new WiFi version of VCDS which has a mobile interface but still full functionality on your desktop as well.
100%, I was just trying to point out that the "you must pay for every change" was inaccurate.
It's also $100 for obdeleven pro vs $450 for vcds mobile so there is the price point too. Also obdeleven works on unlimited cars vs limited VIN's with vcds.
I recommend owning both if you own vw/audis. That being said, I haven't had to pull out the VCDS laptop in ~3 years, last time was to chase down a fueling issue on our mk7 gti.
VCDS does everything
OBDEleven does most things and is super convenient and much cheaper.
Do with that info as you will.
