Results 1 to 12 of 12
    Senior Member Four Rings
    Jun 08 2021
    PA
    Clean brake pads
    My brake pads on my S4 are the dirtiest pads I’ve ever owned. What kind of brake pads are you guys running that help keep wheels clean? I can detail my car and by the end of the day they are dirty with black dust. They are oem pads. I live in a rural area of PA so my trip to work and back is up and down a mountain with very curvy roads and almost no straight areas so i use the brakes a lot.
    Veteran Member Three Rings BucDan's Avatar
    Jul 19 2017
    San Diego, CA
    Ceramic brakes are the cleanest. Less bite, but linear braking feel. Semi metallics will stop you 60-0 sooner than ceramics, but if you're not a bad driver, you'll be ok.
    OEM are semi-metallics.
    I use Akebono ceramic pads. ATE are also ceramic.
    Aug 16 2020
    Q
    Akebono ceramic on every car I have.
    Jul 16 2018
    Atlanta
    The 8K 345x30 pads are only semi-metallic (PR-1LD and PR-1LJ (red)). The 8K 320x30 pads started out only semi-metallic (PR-1LA), but they added a ceramic later (PR-1LB).
    I'm using Akebono Euro ceramic pads currently and have liked them. Looks like they say they have a set for the S4, EUR1322. I forget the exact difference between EUR1322 and EUR1322A; it's some hardware but I forget which has it and which doesn't. Maybe the caliper guide bolts.
    But being ceramics, they give up some performance for the quiet and neutral color dust.
    Senior Member Three Rings Slvrbul8's Avatar
    Apr 14 2021
    300zxTT and E46 BMW 330i
    Roanoke, Va
    Akebono Euro ceramic pads for me as well.
    IE Stage 2 Dual Pulley, APR HX, APR 187 and 57mm pulleys, Milltek Resonated Exhaust, Deval CF Diffuser, 034 Lowering Springs, 034 Rear Sway Bar, Eurocode AK.
    Veteran Member Four Rings Neil F's Avatar
    Jan 13 2017
    marlton/nj/usa
    Akebono. No dust, not grabby like the OEM and they last. I put mine on over 4 years ago. I have over 70k and there is still a lot of pad left
    2014 Estoril blue Cab Chestnut brown interior
    Dec 10 2012
    1983 Honda CB1000 Custom
    granville ohio
    Another vote for Akebono
    2013 S4 Premium Plus, 6MT, Brilliant Black, Sport Diff, Red & Black Leather, B&O, APR Stage 1, AWE S-flo
    Veteran Member Three Rings SouthernBoy's Avatar
    Jun 03 2014
    Virginia
    Akebono all around several years ago on my 2016 S4 because I got so tired at all of the dusting. Even the OEM Brembos on my 2004 Acura TL didn't dust as much as the stock S4 pads did. HUGE improvement in dusting, as in hugely less of it, and much better braking, in my opinion. The stock pads are too grabby, whereas the Akebono's are much more predictable and progressive in their braking. Big improvement. And no squealing or any other sort of noise regardless of the weather.
    In the final seconds of your life, just before your killer is about to dispatch you to that great eternal darkness, what would you rather have in your hand? A cell phone or a gun?
    Sep 24 2014
    2015 Audi Q3 Quattro, 2017 Corvette M7 Grand Sport, 2017 Audi SQ5, 2019 Porsche Macan, 24 Jetta GLI
    Central NJ
    Akebono Euro Ceramic...
    Veteran Member Four Rings B72.0T's Avatar
    Dec 18 2009
    2015 Q7 TDI S-Line Prestige, B8 S4 6MT
    Pennsylvania
    Put me down for Akebono pads.
    Veteran Member Three Rings Midnight_Rider's Avatar
    Jan 25 2015
    VA
    I've been using TSW and they work fine, and it's cheap. Brake dust is there, but not bad - cleans off easier than the semi-metallic pads. But I've noticed that they do stain the wheels a bit after a while. TSW along with that other company on FCP Pro are the OEM manufacturer for brake pads for BMW, Merc, and Audi... but it's cheaper.
    Use to run Hawk and Ferodo. Their Ceramic pads are good, but too expensive. not tracking my car.
    C7 Z06 3LZ - AMR Long tube header and exhaust, Halltech Intake, tune.
    B8.5 S4 - Daily commuter. IE Stage 2 ECU/TCU, IE intake
    AP1 S2k (glass rear window) Black with full red interior - all suspension mods - SCCA car
    Evo VIII - AEM EMS, Cosworth Cams, intake, Whiteline front and rear sway bars, exhaust, etc., etc., etc..
    Senior Member Three Rings JRYtheS4's Avatar
    Sep 08 2020
    I'm running ebc red stuff. Haven't washed my wheels in almost 2 months and they're still pretty clean.
    Sent from my SM-G991U1 using Audizine Forum mobile app
    2011 Audi S4 Prestige 6MT|Full ADS w/ sport diff|Meteor Grey Pearl|Black/silver alcantara|Aluminum trim
    Bone stock except intake
