I figured there should be a thread for this platform like they have for C7 platform, one place to post all the known VCDS mods/how-tos for this platform. People usually make a new post for each mod and there ends op being information in 50 different threads. Lets use this to put them all in one spot. Perhaps if multiple users contribute, the forum mod can make it a sticky reference.
Please, If possible, create your post with pictures and/or detailed steps to perform whatever mod you are adding to this thread to help others, as that is the goal. If you perform a mod and have additional info to share, please do. Perhaps there's a different way to do it, it doesn't work for some reason, etc...
Please keep in mind that not all of these mods will work on all B9. Many things will depend on trim level and equipment the vehicle actually has.
I will check back from time to time for new posts and index the mods with links here in the OP.
Window Auto Drop
HVAC recirc memory
Display Gear Number in Virtual Cockpit
Rear Brake Pad Change
Disable Orange Side Marker (Non-Matrix Headlights)
Disable MMI lock-out functionality when moving
Enable Laptimer
Comfort Turn Signals
Disable Seat Belt Warning
Enable Needle Sweep
Deactivate Start/Stop
Active Lane Assist - Steering Vibration Adjustment
Auto parking brake with ignition off
Enable Emergency braking lights
Adjust Steering Wheel Heater Temp
Increase range for Comfort window operation
Enable Ability to lock car with Engine running
Enable/Disable Auto Lock When Driving
Enable Beep On Unlock
Change number of "Indicator Flashes" when locking/unlocking
Enable/Disable Lock/Unlock Chirp
Change number of beeps on opening (none/single/double)
Increase time required to open trunk lid with remote key
Change heated seat temps, ventilated seat fan settings
Enable Coming home/welcome light
Turns on low beam as well as high beam when you flash high beams with headlights off
Disable rear wiper
Enable Sports Computer
Switch off speed for park assist
