Results 1 to 7 of 7
    Sep 02 2016
    Wix (57204) oil filter vs mann
    Hi, I can get wix oil filter cheaper locally than the mann 7029z supposedly the same company now !??! What u guys think of using these wix ?
    Sent from my SM-G975W using Audizine Forum mobile app
    Senior Member Four Rings
    Jun 08 2021
    PA
    Use the man or go to the dealership. I posted a thread on why the correct filter design is needed. The stepped design on many aftermarket filters do not put sufficient pressure on the anti drainback spring. The needs to be flat on the ends and 155mm length. Audi even has a tsb on this cause it is an issue with many aftermarket filters.
    Jul 03 2018
    SC
    How cheap do you want it to be? The Mann at my local parts store is about $10.
    Veteran Member Three Rings 3.0ss's Avatar
    Jul 26 2019
    S4, Q7, Q5
    Cumming, GA
    FCP oil change kit >
    2010 S4 Prestige 6MT - Brilliant Red | 034 Stage 2 | 034 190mm | Merc HX | Milltek Resonated Exhaust | Gutted/Reinforced Cats | S34 Intake | JXB Short Shifter Kit | AG M580's | Bilstein B8s | H&R Sport Springs
    2018 Q7 Prestige - Orca Black/Cedar Brown Valcona | Luxury Pack | Driver Assistance Pack | Cold Weather Pack | Towing Pack
    2014 Q5 P+ - Lava Gray Pearl | 3.0T | B&O | MMI+
    Sep 02 2016
    Quote Originally Posted by SSMOKE-U View Post
    I didn't want to post a big long story but the mann filters are $30 here in Canada I found a wholesaler that actually has them for 18 the Wix filters that I'm asking about are only 10 locally there's also purolator ones for 12
    Sep 02 2016
    Quote Originally Posted by Nillious View Post
    Thankyou I ll read the thread
    Veteran Member Four Rings MSq5's Avatar
    Feb 14 2017
    Toyota Highlander, Nissan Armada, Kubota M4030, Scag Tiger Cat 2
    Gulfport, MS
    I use Mann. Its commonly available here. However, Wix is excellent quality. I've used its oil filters for decades on other applications. I'd buy one and compare to OEM. If its flat on tbe end and 155mm long, I'd not hesitate to use it if I could not get Mann at a decent price. As stated, it should not be much higher than Wix. Don't cheap out to save a few pennies.
    BTW I order 4 packs of Mann through Amazon Prime with free delivery.
    2017 Q5 3.0T S-Line | Brilliant Black | 034 Stage 2+dual pulley 93 octane tune | JHM 187mm crank pulley w/ EPL 57.6mm s/c pulley - 3.247 total ratio | Red Star shielded test pipes | Magnaflow high flow downstream ceramic core bottle cats | Vibrant Ultra Quiet Resos in place of OEM baby resos | aFe Pro 5R (part#10-10121) filter in "modified" stock air box | 034 silicone throttle body hose | HP Tuners custom TCU tuned ZF8 | Merc Racing HX | Michelin Pilot Sport A/S 3+ 255/45/20.
