    Oct 29 2015
    NC
    Anyone used the wireless HEX-NET VCDS?
    Looking for some real world feedback if anyone owns the wifi HEX-NET. I'd like to be able to use VCDS without a windows PC (or on a phone/tablet), but there is a pretty big price jump from $200 to $450.
    Veteran Member Four Rings Audisthesia's Avatar
    Aug 14 2019
    Tampa
    Quote Originally Posted by rabbitarmy View Post
    I have HEX-NET Pro (unlimited VIN version). The wifi works great, and it also can be used wired.
    However, be aware that not all functions are available using the wireless VCDS mobile, and it requires internet access. So keep those things in mind when deciding what you need.
    http://wiki.ross-tech.com/wiki/index.php/Functions
    18 S6
    Sep 16 2020
    West Michigan
    It connects to your computer using wifi from what I understand
    Which means your internet connection will not work when using your VCDS.
    2012 A6 Prestige - APR single pulley via Fluidampr 189, Injen intake+RS7 airbox, IE HPFP, EPL TCU, JHM HX, 034 motor mounts, Eurocode drivetrain inserts, gutted cats - 034 tunes purchased, not installed.
    Veteran Member Four Rings gk1's Avatar
    Aug 06 2014
    NJ->CO
    Quote Originally Posted by sepheroth86 View Post
    It works in infrastructure mode too.
    "WiFi Requirements:
    To use the HEX-NET wirelessly, it needs to communicate via 802.11 b/g at 2.4 GHz. This means that for Access Point mode, the client device with the web browser (laptop computer, tablet, etc.) needs to support 802.11 b/g at 2.4 GHz. To use the HEX-NET in Infrastructure mode, both the client device and the router that is connected to the Internet need to support 802.11 b/g at 2.4 GHz. Specifically, 5 GHz WiFi is not supported nor are channels 12 and 13 supported."
    https://www.ross-tech.com/vcds/hex-net.php
    2023 e-tron GT Daytona Gray
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    2014 SQ5 Glacier White
    2012 S4 S-Tronic Monsoon, Stage II [email protected] 4275lbs
    2008 A6 3.2Q S-Line Daytona
    2007 A4 2.0T S-Line Ice Silver
    2001 S4 Nogaro Blue, Stage I [email protected] 3944lbs
    Oct 29 2015
    NC
    Quote Originally Posted by Audisthesia View Post
    Thanks for that feedback! Being unable to access full functionality without a PC is a bit of a downer, so I'm going to stick with the "regular" wired only version.
