Mileage 133,000
I have to sell the Allroad due to buying a mini-van for the family. Needed more room for all the activities. It has been a blast to own and modify the way I wanted to. It has been well maintained over the past 5 years. The car has some scratches on the paint and wear and tear as this was my daily driver to get me around the town. Car was bought 9/23/2017 in Harrisburg PA with 71,000 miles on it.
It does burn oil as most of these do. It is about a quart of oil every 5000 miles or so.
Oil is changed every 6000 to 8000 miles with ECS kit Molgen 5w-40 with Hengst filter
I have had the car detailed by a close friend of mine and it is ready for a new home. Below is a list of mods. I have most of the stock parts that will go with the purchaser.
·*******BFI shifer
·*******Carbon fiber trim( quattro piece is cracking)
·*******Magnsflow cat-back exhaust part number 15369.
·*******20x10.5 Rennline wheels with et50, 12mm spacers to clear the upper arms. 255/35/20
·*******St suspension Part number 90618
·*******K&N intake*
·*******Weather Tech floor liners front and rear
·*******20% tint all around. The rear window is bubbling. Will need to be removed and replaced.
·*******Turbo delete pipe and intercooler pipeing
Maintenance and installed mods
·*******72,973 milage Front wheel bearings
·*******75,000 Rear wheel bearings, St suspension, Oil change
·*******75,300 alignment and carbon clean at Induktion Motorsports
·*******82,424 oil change and turbo delete pipes
·*******86,000 magnflow exhaust
·*******88,055 Oil change
·*******96,658 Coil packs and plugs
·*******97,180 Oil change
·*******Recall for the secondary water pump
·*******105,830 Oil change
·*******115,000 Oil change
·*******119,560 Cam Follower
·*******122,245 oil change
·*******133,233 Timing chain service and oil change preformed by Induktion Motorsports
$11,500 odo. I'm willing to negotiate.
Sent from my SM-N970U using Tapatalk
