Originally Posted by
akhlo.ca
Thanks Ninjaman. I'm actually very happy with the pedal feel of the APR tune (it is even punchier than stock in S mode) so if the 034 tune doesn't provide that same feeling then that's definitely a no-go for me. As for the gains - if my research is correct:
034 Stage 1 = 514HP / 537TQ
APR Stage 1 = 498HP / 556TQ
I guess if I were to make a switch I'm trading 16HP for 19TQ, which at the end of the day is probably not even noticeable... but maybe the 034 TCU tune makes a big difference?
Does anyone have experience / knowledge about the VR Stage 2 tune? Their website says +85WHP / +100WTQ. Assume 15% drive train loss that's +100HP / +118TQ at the crank, making it about 550HP/561TQ? Now that's a bit more significant.
Generally speaking, the APR will provide more low end grunt than 034 but it runs out of steam as the rpms climb. The 034 tune does not jack up low end torque in the same way but it pulls strong all the way to the redline.
But, I would like to point out that you can't directly compare horsepower figures from the APR and 034 websites. As we all know, dyno figures can vary a lot from one dyno to another, so you can't directly compare the top number. You should look at the delta.
Audi claims 444 hp for the stock RS5:
- APR's dyno was calibrated such that stock horsepower was measured at 458, and a 93 octane tune gives you 498, for an increase of 40 hp.
- 034's dyno was calibrated such that stock horsepower was measured at 441, and a 93 octane tune gives you 514, for an increase of 73 hp.
So the difference is 33 hp, not 16.
Audi claims 443 ft lbs of torque:
- APR's dyno measured stock torque at 469, and a 93 octane tune gives you 556, for an increase of 87 ft lbs.
- 034's dyno measured stock torque at 467, and a 93 octane tune gives you 537, for an increase of 70 ft lbs.
So the difference is 17 ft lbs, not 19 ft lbs.
I think the real difference shows up in the shape of the curves for the dyno charts on both websites. APR increased low end grunt and 034 focused more on horsepower and extending the usable rpm range.
So, if you are happy with the throttle response and low end power with the APR tune, there is probably not much reason to change. If you prefer to have a engine that pulls strong all the way to the redline, and more overall horsepower, 034 does that. And, if you really want to get aggressive, the Stage 2 TCU tune from 034 does that. In the end, both tunes deliver performance increases, but with different personalities.
