Originally Posted by
n0ferz
Maybe I was not clear in my answer. The code is in cyl #2 even after I switched the coil from #1 to #2.
Do you think this has something to do with injectors because the car was running perfectly fine for some time?
So the problem existed before replacing spark plugs and coils?
Did the check engine light come on?
What other codes are present?
What year is the S3? What country is it located in?
USA S3 don.t have the second set of injectors on the intake manifold....
It could be injectors...
Could be a sensor related to ignition...cam sensor...crank sensor...
Could be wiring...
What mods does the engine have? Totally stock?
Stage 1 tune? State2? Bigger turbo?
Might need a carbon cleaning...
