Results 1 to 13 of 13
    Junior Member Two Rings PigDaddyF15E's Avatar
    Jul 24 2020
    Niceville, Fl
    Unable to reset Inspection with OBDeleven
    I bought an OBDeleven to reset the inspection interval since you can only reset the oil change interval through the car. It's annoying that I get the "Inspection Due" beep every time I turn the car off. Hooked up my shiny new OBDeleven...app...Inspection Reset....FAILED.
    Found an article somewhere that they had installed some type of software protection on the 2020+ Audi's....found several youtube videos...but they were on models prior to 2020
    Anyone been able to reset the Inspection due on a 2020+ RS3? If so...what am I missing...being new to obdeleven...it's a little overwhelming with all the features.
    2020 Ara Blue Crystal RS3: Navigation Package, Black Optic Package, Side Assist & Driver Assistance Package (Adaptive Cruise Control), Dynamic Package, Audi Sport Carbon Fiber Inlays, Black Audi Rings and Badges.
    Unitronic Stage 1+ ECU (93 Octane) Stage 2 TCU
    Previous: 2008 Z51 Corvette, 2006 BMW 335i, 2000 Camaro SS
    Apr 17 2022
    Henderson, NV
    I had the same issue on my 2020 RS3. Basically none of the functions worked for me on OBD11. Went VCDS, no problem resetting.
    Jul 24 2020
    Niceville, Fl
    Well crap...guess I'm going to be looking into returning this OBDeleven
    Veteran Member Four Rings o1turbo30v's Avatar
    Feb 06 2012
    Cars, guns, nuts and bolts
    Allentown, PA
    Yup, VCDS /end thread
    Stage 1 more than you RS3
    Jul 24 2020
    Niceville, Fl
    I'm hoping someone pipes in with "oh yeah...this is how you do it"
    I don't see it being "easy" to return a product I've already "used"....registered
    Aug 19 2021
    Orlando
    I had a similar issue with my 2019. Reached out to support and they suggested to ensure the hood was open, and parking brake engaged. Tried again and it worked. Hoping you have the same luck!
    Senior Member Two Rings ZTTRS's Avatar
    Jul 26 2018
    TEXAS
    I reset mine 2019 TTRS, make sure your hood is open and up before you connect BT
    - - - Updated - - -
    I reset mine 2019 TTRS, make sure your hood is open and up before you connect BT ODB11 has been great! havent had a need for vcds
    Jul 24 2020
    Niceville, Fl
    Quote Originally Posted by Droeck View Post
    That was the issue. I didn't see any "documentation" that said you needed the hood open to do these things.
    Jul 24 2020
    Niceville, Fl
    Quote Originally Posted by ZTTRS View Post
    - - - Updated - - -
    Since the app asks you to put in your make/model...I wonder why it doesn't say "Oh...you might want to make sure the hood is open before you do anything". I'm assuming not all cars need the hood open.
    Jul 26 2018
    TEXAS
    Quote Originally Posted by PigDaddyF15E View Post
    18's and below didnt require it, I made the same mistake until I saw a tuning post about flashing. But otherwise ODB11 has been great, was able to do all the IROZ mods and everything
    Mar 09 2018
    2018 RS3
    obd11 works as it should but sometimes it lacks details or instructions for doing certain things.
    Florett RS3+DS1+034TCU
    Jul 24 2020
    Niceville, Fl
    Quote Originally Posted by tegxsi View Post
    Yeah...that's my 'issue' with it...not much detail. The "instructions" are basically. Download the app...hook this up...do things.
