Results 1 to 15 of 15
Thread: Strut bar
    Veteran Member Three Rings Midnight_Rider's Avatar
    Jan 25 2015
    VA
    Strut bar
    I'm little confused on why there isn't so much strut bars available for Audi S4? I think it drives very well, but is it because of the supercharger that they don't offer it or what is it?
    C7 Z06 3LZ - AMR Long tube header and exhaust, Halltech Intake, tune.
    B8.5 S4 - Daily commuter. IE Stage 2 ECU/TCU, IE intake
    AP1 S2k (glass rear window) Black with full red interior - all suspension mods - SCCA car
    Evo VIII - AEM EMS, Cosworth Cams, intake, Whiteline front and rear sway bars, exhaust, etc., etc., etc..
    Jul 08 2020
    Calgary
    Cr15 and call it a day
    Mar 31 2008
    eS-4
    CAL*SO
    i have the ecs carbon fiber strut bar if you are interested.?
    Sep 24 2014
    2015 Audi Q3 Quattro, 2017 Corvette M7 Grand Sport, 2017 Audi SQ5, 2019 Porsche Macan, 24 Jetta GLI
    Central NJ
    https://www.ebay.com/itm/18389781832...EAAOSwXpFbxroJ
    I have this UltraRacing strut bar if you are interested, brand new, never installed,....$150 includes shipping to anywhere in continental USA.
    Sep 17 2005
    Fremont, California
    Most "strut bars" on the market simply tie one or two bolts on the shock tower to the other side. While it may look cool, they certainly are not truly connecting the shock towers.
    The 034Motorsport Front Strut Brace is made from a piece of solid billet aluminum and truly ties the front strut towers. Our Strut Brace wraps around the entire shock tower and requires you to add additional holes through your shock tower for additional strength and support.
    This brace fits with all aftermarket throttle body options currently on the market (APR Ultracharger, 034 SüperDüper, etc) and is a great modification if you're looking for a true strut brace.
    It also fits with a 4.0t swap!
    https://store.034motorsport.com/034m...-aluminum.html
    -Sean@034
    Veteran Member Three Rings ALAN12186's Avatar
    Mar 30 2016
    Brick, NJ
    lol you're brace takes 8 hrs to install or i would own one
    13 S4/6mt/SDiff/MMI/B&O/Black Ops/APR Stg2+ Ultra,SC & 187MM Crank Pulley,TB & CPS V2/APR Intake/Milltek Res GT100/TA HF Cats/FF103 19x9.5/ Vorsteiner Front Lip/E Codes/ECS Diffuser/P3-Vidi Track Pack/Bilstein B12 & H&R OE Springs/EBC Red Pads & Slotted Rotors & SS Lines F&R/Brembo Calipers/CR15/APR 7MM F&R/034 Sway/Moog Links/ECS Drivetrain Mounts/Eurocode Krez/ECS Clutch Line/034 Trans, Motor & Sub Mount/SB STG 3 Clutch/USP Slave/Enlaes Spoiler/ECS SS/Autotech HPFP/Jokerz Blower/Killer Chill
    Mar 31 2008
    eS-4
    CAL*SO
    Quote Originally Posted by ALAN12186 View Post
    lmaoooooo
    Established Member Two Rings poloshirt's Avatar
    Apr 06 2022
    Oregon
    lol not only that but $436, front alignment, and drilling holes into the chassis? No thanks...
    I've heard good things about the CR15. Considering its price ($120) and install time (15 minutes), it might be the best bang for your buck. I'm also curious if anyone is running BOTH CR15 and the ECS strut bar? Looks like they can be installed simultaneously.
    Mar 30 2016
    Brick, NJ
    cr15 is great cant go wrong also get the front X brace
    Veteran Member Four Rings Ashtonts's Avatar
    Jan 17 2015
    CR-15 does next to nothing. 034 is right in that they’re actually offering a true strut tower brace. These two products aren’t even close to being in the same league. Spoken as a CR-15 owner.
    2007 Porsche Cayman | 5MT
    Jan 25 2015
    VA
    I don't think that's S4 B8.5. Do you have a picture of S4 B8.5?
    Jan 17 2015
    Quote Originally Posted by Midnight_Rider View Post
    That’s their 4.0T swapped B8.5 S4
    Jan 25 2015
    VA
    Quote Originally Posted by Ashtonts View Post
    ohhhhhhhh.... I don't have that.
    So, is this it?
    https://eurozonetuning.com/products/...4-s4-a5-s5-rs5
    Looks similar to ECS one: https://www.ecstuning.com/b-ecs-part...hoCzTUQAvD_BwE
    I guess the days of $30 strut bars that work are over, hmmmm... lol
    Mar 31 2008
    eS-4
    CAL*SO
    well i have this one: https://www.ecstuning.com/b-ecs-part...008049ecs01kt/
    if you are interested. let me know.
    Jan 25 2015
    VA
    Quote Originally Posted by Fresh.S4 View Post
    Yeh, I saw that there. Not sure if it does anything with a bend like that though...
