Update: SOLD
Hey Audizine,
Due to moving, I'm selling my tastefully modified B7 A4. The car was set up to do everything, from daily highway driving to canyons and has been a dream to drive throughout my ownership. Car was in storage and on PNO recently and therefore needs some minor work, but had an oil change, smog test done, and was re-registered last week. Some of the parts will be included for the next owner, and others are available for sale. Below are the details:
2006 Audi (B7) A4 Quattro S-Line 6-Speed Manual
•150,500 miles
•Clean Title
•Brilliant Black
•Brushed Aluminum Trim
•2 Keys Included
•Folder full of service records from myself and previous Audizine-member owner included
•Meticulously maintained throughout its 4 owners, no expenses spared
Basics:
•Full S-Line Package (Visual and Suspension)
•Premium Package (Leather Seats and Sunroof)
•Convenience Package (Homelink, Rain/Light Sensors, Come Home Function, AFS Bi-Xenons, Memory Seats, Dimming Rear View Mirror w/ Compass, Power Folding Mirrors)
•Technology Package (RNS-E Nav, Color Driver Display, Bluetooth Handsfree, Bose Audio System, AUX Input Added)
•2.0T Quattro
•6-Speed Manual
History:
•Originally a Colorado Car (Underbody/Panels in great condition)
•Was in a fender bender in 2010 (Front bumper and driver's headlight replaced)
•Original Engine/Trans/Drivetrain
Recent Maintenance (in past 3 years):
•Spark plugs
•New CV boots
•Trans and diff fluids changed
•Brake fluid flushed
•New Brake and Clutch switches
•New ECU Relays
•New driver’s window switches
•Sunroof clips replaced
•New EVAP purge (N80) valve
•New N75 valve
•New fuel filter
•Low Pressure Fuel pump (LPFP)
•Sway bar bushings and brackets
•Suspension bushings refresh
•New Inner/Outer tie rods
•Cabin air filter replaced
•Valve cover and related gaskets
•Breather tube
•Alignment
•Cam Follower every 15k miles
•Oil changes every 5k miles
•150k oil and filter change done
Cons:
•Needs front rotors/pads (wear sensor on)
•A/C needs to be recharged
•Some oil burning
•Outer glove box hinge has cracked (still operable, damper replaced then disconnected to avoid further damage)
•Sway bar end-links clicking
•Front right-rear upper control arm bushings is on its way out
•Very small oil leak from timing cover
•Could use a detail or paint correction
Mods:
•APR (Early) K04
•APR HPFP
•APR K04 Tune (Proper early K04 file for TP and HPFP) - APR Mobile Dongle Included
•Carbonio Intake - Stock Intake Included
•Thermal R&D Cat-Back Exhaust
•JHM HFC - Stock Cat Included
•Southbend Stage II Clutch and Lightweight Flywheel
•H-Sport Sway Bars
•034 Front Sway Bar End-links
•AWE Tuning Boost Gauge
•Red-Top Coil Packs
•NGK BKR8EIX Spark Plugs (Gapped to APR spec)
•APR Snub Mount
•Stasis Ohlin SL (Challenge) Coilovers w/ Hyperco Springs
•Fender liner slightly shaved and mild fender roll (no rubbing)
•034 Density Line Engine Mounts
•034 Billet Catch Can
•034 Turbo Inlet Hose
•034 Intercooler Hoses
•GFB DV+
•Apikol Rear Diff Mount
•RS4 Grille
•S4 Door Blades
•S4 Recaro Seats - DTM fronts, leather rears - All heated, but rear controls not retrofitted.
•Matt Devo's (Audizine) A8/GTI Headlight switch
•OSIR Design Pedals
•LED DRLs and City Lights (w/ resistors - no bulb error)
•Ziza Color Matched Fog Light (no bulb error)
•Ziza LED License Plate Lights (no bulb error)
•Ziza LED Interior Lights
•OEM Audi A4 All-Weather Floor and Trunk mats
•DieselGeek Panzer Skid Plate
•Tints on all but windshield
•Partial clear bra on hood, front fenders, and mirror caps.
Note:
•Stock S-Line Suspension is available if buyer isn't interested in the coil-overs.
•New Valve Cover will be provide since it went bad during storage and is causing the oil burning.
•New Spark Plugs will be included due these needing to be replaced once the Valve Cover is changed.
•Car was on S5 Peelers but is now back on the Stock 5-Spokes
•Car is currently on personalized plates and will need temp/new plates for the next owner.
•Car is being cleaned and I'll upload more recent pictures.
Parts Available for Sale - Buyer can get first dibs before they're posted in the classifieds:
•CSR/DTH/Relak Replica Fiberglass side skirts
•DTM S-Line carbon spoiler
•18Z Front calipers/B7 S4 Rear calipers (rebuilt/refreshed and recently powder coated vampire red with white Quattro decals)
•Slotted/Drilled Brake Performance rotors (CLA45 AMG Front, B7 S4 Rear)
•StopTech RS4 front and S4 rear stainless brake lines
•EBC Red Stuff brake pads
•Porsche brake pad wear sensors
•ECS Porsche to Audi brake sensor adapter
•JHM 18Z caliper mounting bolts
•OEM S5 Peelers (No tires)
Thank you for reading!
