Results 1 to 7 of 7
    Established Member Two Rings TLR_0125's Avatar
    Apr 23 2019
    East Coast
    Rear View Mirror Assembly
    Would anyone happen to know if the B8 and B8.5 rear view mirror assembly is the same? They look the same visually from what I see online. Not sure if the connector is different. The plastic on the front side of the mirror has a crack, doesn't look very nice. My other option was just buying one off ebay, and swapping that plastic cover and hoping I don't crack the new one. Looks like a brand new rear view mirror with the dimming feature and compass is around $1000.
    Jul 16 2018
    Atlanta
    They are definitely different part numbers, due to the humidity sensor change and its wiring change.
    8R0 857 511 C is the B8.0 all features one.
    8T0 857 511 AC is the B8.5 all features one.
    The 8-pin plug is the same part number. But again, the included humidity sensor and wiring are changed.
    Now, could you swap over the humidity sensor and rework the wiring? Probably. But couldn't guess to your options until both were laying on the operating table.
    Veteran Member Three Rings DrGER's Avatar
    Aug 31 2014
    '17 Audi A4Q 6MT CYMC/RJN, '11 VW GOV TDI 6MT CJAA/LHD
    NW OH USA
    Short answer: No.
    All B8.5 mirrors have the 8-pin connector, while some B8 mirrors use the 6-pin connector. ETKA doesn't differentiate the 6- and 8-pin connectors with mirror P/Ns, that I can tell. What year and options codes (e.g., 4L7+6NQ+8N1,8N6+9AQ) are you looking to replace ? More options info here: https://audi.7zap.com/en/usa/audi+a4.../8/857-857045/ --g
    2017 B9 A4Q P+ 2.0T 6MT Daytona Gray. Previous: 2014 B8.5 A4Q P+ 2.0T 6MT Monsoon Gray; 2009 B8 A4Q P+ 2.0T 6MT Brilliant Red; 2005 B6 A4Q 1.8T 6MT Cambridge Green; 1995 B4 A90Q V6 5MT Pearl White; 1990 B3 A80Q I5 5MT Crystal Silver; 1984 C3 5000S I5 5MT Montego Black; 1978 C2 5000 I5 4AT Helios Blue; 1977 C1 100LS I4 4AT Signal Green; 1974 B1 Fox I4 4AT Sahara Sand.
    Veteran Member Four Rings RPMtech147's Avatar
    Apr 05 2014
    Texas
    Quote Originally Posted by TLR_0125 View Post
    You can find them on Ebay used for about $300 but be aware of what you're looking at. The mirrors are all very similar starting from the early 2000's across many models, and most will fit, but the wiring/connectors are all different, as Smac said.
    The compass mirror broke on mine; the joint inside cracked and the mirror just flopped around. I installed one from a 2008ish A6 I had in a drawer. The connectors don't match, but it functions as a mirror and looks nearly identical. I didn't feel like paying $300-1000 for a compass. I was going to try and re-pin the connector to get it working, but meh.
    B6 S4, B8 A4, 8P A3, and something, something.
    Apr 23 2019
    East Coast
    So I was thinking of buying something like this and then just taking that front plastic off. This listing says 06-09, but the shape looks identical. If those years are different, then I was thinking this one. It's listed as A5/S5, but also looks identical. Just needs to be cleaned.
    Now I'm wondering how hard it would be to take off that front plastic around the brim of the mirror without damaging it...
    Apr 05 2014
    Texas
    Thats the older Gen(B7). Once again, itll fit, the car but the harness is different. The mirror housing itself is also different. The only thing actually the same is the cover over the wire and the mount to the glass. Visually they're similar. The mirror for your car won't be less than $300.
    Jul 16 2018
    Atlanta
    Quote Originally Posted by DrGER View Post
    Short answer: No.
    It's easy enough to differentiate the 6-pin applications and 8-pin applications for B8.0 by cross-referencing the relevant sections in the wiring diagrams document. 6-pin is used on those without the humidity sensor and without high beam assist (which no US B8 has HBA, iirc).
    4L2 = manual dim mirror
    4L6 = auto dim mirror
    4L7 = auto dim mirror with compass
    8N1 = no RLS
    8N6 = with RLS
    8N7 = with RLS
    9AK = basic climate system, single zone, no humidity sensor
    9AQ = comfort climate system, three zone, with humidity sensor
    6NJ vs 6NQ refer to interior trim material, and have no net impact on parts, at least for US market
    7L1, L7L = without stop/start
    7L8 = with stop/start, meaning no US B8 (except B8.5 Q5 without the 2.0T engine).
    But again, once you say "with compass", there's only the single-zone climate system version (with no humidity sensor, would have the 6-pin; this is the 8R...A) and the three-zone climate system version (with the humidity sensor, would have the 8-pin; this is the 8R...C), for B8.0. B8.5 has only the with humidity sensor version, with 8-pin.
