Available Now: https://store.034motorsport.com/034m...uspension.html
The 034Motorsport Dynamic+ Sway Bar Kit is available for B9/B9.5 Audi Q5/SQ5 with OEM Air Suspension. The 034Motorsport Dynamic+ Sway Bar Kit features perfectly-matched front and rear sway bars made from high-quality spring steel for maximum rigidity and durability.
Designed to reduce body roll, improve turn in, reduce understeer and enhance steering feel, 034Motorsport's Dynamic+ Sway Bar Kit is the ideal upgrade for those in search of confidence-inspiring handling on the street and track.
TRACK-PROVEN HANDLING PERFORMANCE:
The Dynamic+ Sway Bar Kit was thoroughly evaluated on the street and track with the 034Motorsport B9 Audi SQ5 before release.
FRONT SWAY BAR FEATURES:
- 2-Way Adjustable
- Soft Setting - 21.3% Increased Sway Bar Rate
- Firm Setting - 39% Increased Sway Bar Rate
- (Rate Comparisons to Factory SQ5 32mm Hollow Front Sway Bar, 3.7mm Wall Thickness)
- 32mm Diameter
- Hollow Design with Thicker Walls Compared to Factory Bar
- Black Powder Coating for Durability and Stealthy Appearance
REAR SWAY BAR FEATURES:
- 2-Way Adjustable
- Soft Setting - 130% Increased Sway Bar Rate
- Firm Setting - 158% Increased Sway Bar Rate
- (Rate Comparisons to Factory SQ5 24.6mm Hollow Rear Sway Bar, 3.8mm Wall Thickness)
- 30mm Diameter
- One-Piece Design with Solid Spring Steel Construction
WHAT'S INCLUDED:
- 034Motorsport 32mm Adjustable Front Sway Bar Upgrade
- 034Motorsport 30mm Solid Adjustable Rear Sway Bar Upgrade
- Polyurethane Sway Bar Bushings
- Billet Aluminum Sway Bar Brackets with Integrated Zerk Fittings
- Installation Hardware Kit
FITMENT:
- 2018+ Audi SQ5 3.0T with Air Suspension
- 2018+ Audi Q5 2.0T with Air Suspension
OE PART INTERCHANGE:
- OE front bar: 80A 411 305 B (32mm)
- OE rear bar: 80A 511 305 S
