Results 1 to 9 of 9
    Mar 22 2019
    Clarksville, TN
    Rear Subframe Rust
    I was under my car investigating some rear alignment issues (alignment shop claimed one of my adjustments is seized up) and noticed I have a good deal of rust on my rear subframe. I've attached some pictures. Car is originally from the Chicago area. Do you guys think this is a wire wheel and por15 situation or should I be considering replacing the subframe?
    Thank you for your time!
    Sent from my SM-G986U using Tapatalk
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Buy a gallon of Fluid Film and coat the hell out of it.
    Mar 22 2019
    Clarksville, TN
    Is there any difference between fluid film and por-15? Similar products?
    Dec 28 2006
    Western Maryland
    Quote Originally Posted by jco897j View Post
    Very different products. Por-15 requires a lot of prep and dries to a hard coating. Fluid Film is a lanolin based product that requires little to no prep but will have to occasionally be reapplied, depending upon driving conditions.
    May 10 2015
    Pittsburgh PA
    Personally I would hit that with a wire wheel to knock the rust off as best as possible, blast it with brake clean it up, then coat it in Por-15 to protect it and renew the finish
    Feb 15 2016
    Cambridge,Ontario
    Yeah mine looks that bad too. I was shocked with the poor quality of metal / treatment used under these cars.
    Sent from my SM-G973W using Audizine Forum mobile app
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Veteran Member Three Rings Chillaxin's Avatar
    Mar 28 2018
    Jacksonville FL
    You need to apply a rust converter after removing loose paint and rust. After the rust converter (which is a type of phosphoric acid), then you coat that with paint or undercoating. That will get you the longest-lasting protection.
    Senior Member Three Rings MongoMcG's Avatar
    Apr 15 2022
    B8 A4, C2 Corvette, Austin-Healey 3000 BJ8, SN95 Mustang, 36 Ford hot rod truck, A4 B9 S-line, A3 8V
    Michigan
    POR-15 makes a decent rust converter product called Metal-Prep (formerly Metal Ready), which contains zinc and phosphoric acid. After the acid etches the metal it dries to a zinc-phosphate surface that is decent for coating. You must keep the surface wet with Metal-Prep for 20 minutes or more. Before the rust converter goes on the loose paint must be eliminated and the rust must be de-scaled and minimized (not removed because the product needs the rust to work), and the surface must be de-greased using a product like POR-15's Cleaner Degreaser (formerly Marine Clean) and rinsed with water.
    “The Force is strong with this one.”
    My K04X build thread
    Dec 28 2006
    Western Maryland
    All those suggestions are good, but require a massive amount of work. As I previously mentioned, Fluid Film is a dirt simple approach to stopping and preventing rust.
    Spend a few minutes reading through the Fluid Film FAQ's and see if it might be the right application for your needs. Also review Automotive Applications
