Results 1 to 2 of 2
    Active Member One Ring Genich's Avatar
    Jun 04 2011
    Sacramento/California/USA
    2001 A4 1.8T Quattro 5-speed BIG TURBO PROJECT
    Here's a chance for someone to buy a tastefully modded and an almost finished B5 1.8t big turbo project that only needs a few finishing touches to get on the road!
    -2001 Audi A4 1.8T Quattro
    -5-speed manual
    -137k miles
    -Salvage title
    -VIN # WAUDC68D21A125707
    -Located in Cameron Park, CA (30 miles east of Sacramento)
    -$14000 or best offer
    I bought it at a salvage auction about 8 years ago with a pretty minor damage to front passenger door and fender (unfortunately I can't find the pictures of the damage). It was an easy repair, and I did all the body modifications before getting the car repainted. Goal was to not make the car look overly modded, but still stand out. The repaint is a factory color and is pretty good quality.
    Interior was upgraded to S4 seats and headliner which I bought used and they have a few wrinkles and light scuffs from typical use and age, and a few sagging spots on the headliner. The Navi unit is an older model but still works and has bluetooth and satellite radio. Everything has been thoroughly cleaned and detailed.
    I've done a lot of test fitting the wheels and using the appropriate spacers and lug bolts to get a nice stance. Ride height can be easily adjusted with the ST coilovers. I've sourced a big brake kit using Porsche Boxster calipers at the front and S4 calipers at the rear, as well as bigger rotors.
    As far as power gain, I wanted to build something that's got a good punch yet streetable, which is why I went with the GT2871r turbo kit. With proper tuning it should be able to make up to 450hp or so. IE rods were installed to be able to handle that power. Nearly every seal and gasket on the engine was replaced in the rebuild process, as well as lots of new and upgraded parts. Transmission is a factory 5 speed with a stage 3 clutch and short shifter.
    I've invested a lot of thought and money into this project, there's over $17k in upgrades and new parts, as well as a lot of thought out details that a new owner will appreciate. I spent about 3 years since I bought the car sourcing parts and building, but unfortunately came to a halt about 5 years ago due to other projects, getting married, buying a house, having kids.
    There's not much that still needs to be done, majorly it needs to get tuned. I do have a base file from Eurodyne installed which is as close as it will get from a base map for the mods that are there. The boost and fuel pressure will also need to be adjusted. Engine seems to run fairly smooth but definitely needs to be dialed in. I wanted to learn to tune when I bought the car, but now I don't have time to either learn it or take it to someone who can tune it for me (couldn't find anyone local to do it for me).
    Also when exhaust was installed, it was hanging a bit low to the ground where the cutout was installed. I've since modified the body to make space for the cutout to fit, but have not gotten to getting the exhaust repositioned and the heat shield installed, so that's another thing that needs to be done.
    I have the car registered in my name, it's currently on non-op status. Will definitely NOT pass CA emissions, buyer will need to figure that out. I do have a box full of oem parts to make it "legal" so I can include that with the car. Car is able to start and drive, but due to the tuning issue I wouldn't run it for long, and it will definitely need to be towed to it's new home.
    Here's a list of upgrades, parts, and mods done to the car:
    EXTERIOR
    -S4 front bumper
    -Euro s4 rear bumper
    -S4 rocker panels
    -Cupra R lip
    -Badgeless RS style grille
    -Euro trunk lid
    -Shaved door moldings
    -Euro headlights (Valeo brand)
    -LED taillights
    -Aero wipers
    -Heated blind spot mirrors
    -Mirror covers painted matte gray
    INTERIOR
    -S4 seats (power/heated fully wired)
    -S4 headliner and pillar trim
    -Pioneer Avic Z1 stereo/navi/bluetooth
    -Greddy turbo timer
    -AWE boost gauge
    -Weather floor mats
    -Door handles painted black ( RS4 style)
    -WHEELS
    -Rotiform NUE rims (18x9.5 et35 + spacers)
    -Wheels powdercoated in custom color
    -Achilles tires
    SUSPENSION
    -ST adjustable coilovers
    -Stern engine mounts
    -Stern transmission mounts
    -Stern rear diff mount
    -Stern rear diff carrier mount bushings
    -034 snub mount
    -034 front sway bar end links
    -Neuspeed rear sway bar
    -New replacement front control arms
    -New steering rack ends and boot covers
    -New replacement front wheel bearings
    -New replacement front wheel hubs
    -New replacement front axles
    BRAKES
    -Porsche Boxster front Brembo brake calipers with adapters (new seals)
    -B5 S4 rear brakes calipers with adapters
    -Hawk brake pads
    -Stoptech slotted rotors
    -Stainless steel brake lines
    -New front ABS sensors
    TRANSMISSION
    -Southbend stage 3 clutch
    -ARP flywheel bolts
    -JHM short throw shifter
    -New clutch slave cylinder
    ENGINE/OTHER PERFORMANCE UPGRADES
    -ATP turbo kit - GT2871r turbo
    -Eurodyne tuning software (base file intalled - needs fine tuning)
    -IE rods
    -ATP Turbo downpipe
    -Neuspeed catback exhaust
    -Exhaust cutout (electric switch)
    -Fully custom air intake
    -CTS Turbo front mount intercooler
    -034 Motorsport intake manifold spacer
    -Siemens Deka 630cc fuel injectors
    -Bosch 044 fuel pump (with 034 Motorsport adapter)
    -IE billet fuel rail (with braided lines)
    -ECS adjustable fuel pressure regulator
    -Marshall fuel pressure gauge
    -2.0T coil pack conversion kit
    -NGK Platinum spark plugs
    -Gates timing belt (full belt service kit)
    -ECS lightweight crank pulley
    -IE adjustable cam gear
    -ARP head bolts
    -ARP crank bolt
    -Forge splitter valve
    -Forge boost controller (manual)
    -IE catch can
    -Turbo blanket
    -Silicone hoses
    -New piston rings
    -New oil cooler
    -New oil pump
    -New fuel filter
    -New oil pickup tube
    -New cam shaft tensioner
    -All new seals and gaskets (head, valves, crank, cam, intake, exhaust, etc.)
    -SAI delete
    -SJP delete
    -EVAP delete
    EXTRAS
    -New brake fluid reservoir
    -New coolant reservoir
    -New windshield cown cover
    -R8 oil and coolant caps
    -Independent fog lamp switch mod
    ISSUES
    -Needs software custom tuned
    -Needs fuel pressure, boost controller, and splitter valve adjustment
    -Needs exhaust pipe slightly repositioned, exhaust wrapped, and heat shield installed
    -May need wheel alignment
    -Headliner sagging in some spots
    -Small scratch on rear bumper and rocker panels
    -Will NOT pass CA emissions
    Here are links to my photobucket albums to see full gallery of the car and the parts that were installed:
    Exterior
    https://app.photobucket.com/u/genich...1-31a624b5aa61
    Interior
    https://app.photobucket.com/u/genich...b-c7f69b296608
    Engine bay
    https://app.photobucket.com/u/genich...e-1c5f0d69160b
    Build process
    https://app.photobucket.com/u/genich...7-aa3a05b975a6
    20220123_135422.jpg20220123_135514.jpg20220123_140258.jpg20220123_140339.jpg20220123_141625.jpg20220123_141258.jpg20220123_141940.jpg20220123_142120.jpg20220123_141536.jpg20220612_140827.jpg
    Sent from my SM-N960U1 using Audizine Forum mobile app
    Veteran Member Four Rings Stock B6's Avatar
    May 25 2018
    Noggy B5 S4
    Twin Cities
    Beautiful car, GLWS! My buddy just sold my old big turbo B6 for $12k so I'm betting you can get close to asking!
    Racecar: Nogaro B5 S4
    Daily: C5 Allroad 2.7TQM
    Past: 71R E85 B6
