The next stage of the build has begun after a long break, and this thread is being updated.
Phase II - The Resurrection, begins at post #81
Even after eleven and a half years, 28 tires, one TSB, two brake jobs, one trampoline, 14 oil changes, one already dead deer, one timing chain, three windshields, one daughter and a Jeep in the driveway, one wheel bearing, one battery, one very large bird, one small rodent, and 136,000 miles of a great driving experience - we love this car, my wife and I.
What are we doing to the car, and why would you be interested? A turbo upgrade and supporting mods are literally and figuratively breathing new life into the car. An itemized list is below, but basically we are adding more air, more fuel and some suspension and handling upgrades. We are also pre-emptively replacing known failure points, scrubbing off 11 Michigan winters and changing all of the fluids. We are biting off a lot in one go, so we'll get plenty of information to chew on here. I will be adding tools, tips, and part numbers for just about everything we are doing including the part #'s and torque specs for bolts, and whether they are "one time use" and must be replaced. The factory build did well, so I am obsessively sticking with original torque specs.
Although I am doing everything in one go it'll take a while, so this thread is broken down to smaller, more detailed posts. I note a few hiccups and surprises that are not covered in other threads & videos available online. Don't get me wrong; those posts and videos helped me a lot. I mean a lot a lot. So much so that I'll link to those posts I found most helpful at the appropriate spots in this thread.
There is an awesome thread here for ebay/hybrid/big turbos and another for the 1070X where I am learning a lot.
Tip: Look for links to the detail posts (within this thread) for each of these sections and for some of the line items. On some browser configs, if you are not logged in as an audizine.com member the links will bring you right back here, so I included the post numbers (upper right corner of each post) for manual navigation.
Itemized list of what we're building
First, for reference, here are the relevant codes for the car:
Engine: CAEB (EA888 Gen 2), Gearbox: LRY (0B2), Rear Diff: 0AR (0BC) - this is the final drive for 2011 A4 2.0 with 6sp MT and some 2011 S4's with automatic transmission.
Tuning
Ward performance Tuning (WPT) is creating a custom tune for the car. In progress
Here's a link to post #43 - Lessons learned while taking on an Audi project
Here's a link to post #50 - Let the tuning begin - a guide for the tuning newcomer, by a newcomer
Air Flow
Upgrades and Keepers - from intake to exhaust
- K&N cold air intake (69-9505T) - completed
-Here's a link to post #12 - adding heat shield to K&N's heat shield - CTS Turbo 1070X K04 Hybrid turbocharger (1070X) - completed
-Here's a link to post #13 - replacing the kinked vacuum lines on the turbo
-Here's a link to post #31 - Bench prepping the turbo - transferring components, measuring the waste gate actuator pressures and distances
-Here's a link to post #32 - More turbo bench prep - grinding the turbo for fitment
-Here's a link to post #33 - Fitment issues continued
-Here's a link to post #34 - Prepping the engine bay for a smooth, snag free turbo installation
-Here's a link to post #37 - Turbo and turbo blanket installed
-Here's a link to post #39 - Video - first start, second start and warm up
-Here's a link to post #42 - Waste gate actuator and turbo blanket interference
-Here's a link to post #43 - Reinstalling the turbo blanket so it doesn't interfere with the waste gate actuator arm - CTS Turbo turbocharger blanket for K03 & K04 (CTS-TB-B-03) - completed
-Here's a link to post #43 - Reinstalling the turbo blanket so it doesn't interfere with the waste gate actuator arm - Wagner Tuning Competition front mount intercooler and silicone pipes (200001045KT) - completed, easy install, no detail post, but here's a tip: the stock IC and radiator setup has vertical plastic panels on either side of the radiator core support that keep air passing through the FMIC and radiator; they are important to the car's cooling system as they insure air passes though the FMIC/AC/radiator and not around them, so the plastic panels should be reinstalled after the new FMIC is installed. Trim the lower third of each to fit around the new FMIC inlet and outlet. The trimming of these pieces eliminates their lower mounting point, but the front bumper catches them and holds them in place pretty well.
- CTS Turbo aluminum charge pipe (CTS-IT-267), with port for future water meth injection if needed - completed - easy install once the fender liner is out, no detail post
- ECS silicone hose from charge pipe to T.B. with their stupid logo on it (017621ECS01A) - completed - easy install after trimming the throttle body end of silicone hose 1 13/16" and the charge pipe end of the hose 1 1/4" due to size increase over stock of the IE intake manifold
-Here's a link to post #25 - IE IM install, part 6 of 6, bending the hard fuel line and wrapping up the driver side of the engine - Stock throttle body (original, 06F133062Q) - installed on new intake manifold - completed - easy install, no detail post
- Integrated Engineering Intake Manifold - Black Velocity Stack Cover (IEIMVC1-bk) - completed
-Here's a link to post #15 - IE IM install, part 1 of 6, component transfer
-Here's a link to post #18 - IE IM install, part 2 of 6, making the bracket to mount the vac purge solenoid on the IE IM
-Here's a link to post #20 - IE IM install, part 3 of 6, vacuum block-off and left over parts
-Here's a link to post #16 - IE IM install, part 4 of 6, a home remedy solution to shrink the teflon seals onto the fuel injectors
-Here's a link to post #24 - IE IM install, part 5 of 6, the IE intake manifold is going in the car
-Here's a link to post #25 - IE IM install, part 6 of 6, bending the hard fuel line and wrapping up the driver side of the engine - Integrated Engineering hi-flow catalytic converter/down pipe and mid pipe (IEEXCG1) - completed - easy install, no detail post
- Stock mid-muffler (original, 8K0253409) - stock factory install
- Stock rear muffler (original, 8K0253609) - stock factory install
To keep track of all this air we are installing the P3 V3 digital gauge (3P3AB8X) and P3 analogue boost sensor (P3ABS).
Here's a link to post #29 - installing the P3 gauge and P3 boost sensor
Fuel System
- 034 Motorsports high pressure fuel pump piston upgrade kit (034-106-6052) - completed
-Here's a link to post #6 - fuel pump removal, piston upgrade and re-install - Audi HPFP (stock, new, 06J127025L) - completed
- All else original from factory - stock factory install
-Here's a link to post #16 - a home remedy solution to shrink the teflon seals onto the fuel injectors
To keep an eye on air-fuel ratios and error codes we are installing the P3 V3 digital gauge (3P3AB8X).
Ignition
- APR Upgraded Ignition Coils (MS100208-4KT) - completed - easy install, no detail post
- Iridium Spark Plugs (BKR8EIXKT) - one heat range colder, gapped to .024" - completed - easy install with tool part #S-3858-125, no detail post
To keep an eye on ignition timing and error codes we are installing the P3 V3 digital gauge (3P3AB8X).
Carbon Build-Up Fix & Mitigation
- Walnut blasting the intake ports - completed
-Here's a link to post #4 - walnut shell blasting - ECS Performance baffled oil catch can system (turbo side of breather/PCV) (004136ECS01KT) - completed easy install, but see link for important info
-This kit blocks off the breather to intake manifold port - this is a no-no
-Here's a link to post #59 - Why and how I'm keeping the can and kicking the port blocker
-Here's a link to post #65 - Opening the ECS Catch Can of Worms Increased My Oil Consumption
Suspension & Subframe
Upgrades - back to front
Here's a link to post #7 - suspension and subframe upgrades install
- 034 Motorsports rear diff carrier mount inserts (034-505-2016) - completed
- 034 Motorsports rear diff mount insert (034-505-2019) - completed
- CTS Turbo transmission mount insert (CTS-HW-0150) - completed
- ECS Billet X-brace, to replace rusted but serviceable original (004802LA01AKT4) - completed
- Canyon Run CR-15 front strut tower brace (CR-15) - completed
- Audi lower radiator support braces to replace rusted but serviceable originals (8K0805527A and 8K0805528A) - completed
Preemptive Parts Replacement
The While I'm In There stuff, replacing known failure points and a few other goodies. All are genuine Audi parts, unless noted
- Vehicle battery - 520A (110Ah) (000915105DL) - completed - easy install except for coding the new battery via OBDeleven, no detail post
- Diverter valve (06H145710D, but I used the Pierburg OEM version 7.01830.13.0) - completed - easy install, no detail post
- Engine Oil Dipstick (06J115611L) - completed - easy install, no detail post
- Pressure Control Valve (PCV, breather) Repair Kit contains PCV valve with gasket and 9 bolts (06H103495AKT3KT) - completed - easy install, no detail post
-Note: My car had the oil consumption update per TSB#2027731r8, so this is version 06H103495AK of the PCV. Without the oil consumption update the PCV would be version AH. Also note the oil consumption update included a new front seal and a software upgrade. - Water pump (06H121026DR), Repair kit (06H121026BAKT) - completed
-Here is a link to post #11 - installing the water pump - Vacuum pump gasket (06H103121J) - completed
-Here's a link to post #21 - installing the vacuum pump gasket (aka vacuum pump seal) - Coolant line O-rings (4E0121666 38x4mm, and N90765301 32x4mm) - completed
-Here's a link to post #19 - installing the coolant line O-rings - All splash shield/belly pan hardware - completed
- Serpentine belt (06B903137D) - replacing with ECS Kevlar reinforced, because it's red - completed - easy install, no detail post
- N75 waste gate frequency control valve (06F906283F) because the CTS Turbo 1070X K04 hybrid has a no name thing on it made from chinesium - completed - easy install while the turbo is out of the car. No detail post, but...
-Here's a link to post #13 - fixing the kinked vacuum lines on the turbo
Fluids
Audi Genuine, Aftermarket and Additives Used
Here's a link to post #10 - all fluids
- Engine oil - Liqui Moly Leichtlauf High Tech Engine Oil 5w-40 (2332) - First try, used Castrol until now - Torque new (required) drain plug to 30Nm - completed
- Engine oil additive - Liqui Moly Cera Tec 300 mL (20002) - Same or similar to my dealership service - added every time - completed
- Engine oil additive - Liqui Moly Motor Oil Saver 300 mL (2020) - First try. We'll see if we like/hate it. - completed
- Engine oil filter - Hengst oil filter (Hengst# H14W30, Audi# 06J115403Q) - hand tighten - completed
- Gearbox oil (G055532A2) - Torque drain and fill plugs to 45Nm - completed
- Gearbox oil additive - Liqui Moly MoS2 anti friction additive (2019) - completed
- Rear differential gear oil - 75w90 (G052145S2) - Torque drain and fill plugs to 45Nm - completed - completed
- Rear differential gear oil additive - Liqui Moly MoS2 anti friction additive (2019) - completed
- Coolant - Vaico G13 (Audi# G013A8J1G, Vaico# VA-013) Flushing the G12 - completed
- Coolant additive - Red Line Water Wetter (80204) - completed
- DOT4 brake fluid (B0007501LDSP) - completed
- Power steering fluid - CHF 202 (CHF202) - completed
- Power steering fluid additive - RVS triboceramic (P2RVS) First try. Will not add if testing of the new fluid satisfies - completed
- Turbocharger additive - Liqui Moly Pro-Line turbocharger additive (22074) One time for the new turbo or whenever the turbo is removed and reinstalled - read the detail post for the Fluids section to find out why - completed
Yet to be sourced or determined
Stuff I am still looking at (will edit here when decisions are made)
- Clutch - maybe the South Bend Stage 2 with dual mass flywheel. I have not yet found the shop to do the work.
- Rear main seal - the 034 Motorsports version or that other one that's available.
Stuff we'll do if/when it's forced upon us
- Rods & Pistons - leaning toward IE forged rods and Mahle pistons
- Front Upper Control arms - those bushes have to crap out at some point
- Other suspension bushings and ball joints
- Engine mounts - 034 Motorsports Street/Track density
Tip: Pics used throughout this build thread and more can be viewed full size at my Flickr album page. There are a lot of disassembly photos that are not used in this thread that will be most helpful for re-assembly of components.https://flic.kr/s/aHBqjzZ3nv
Disclaimer: This thread is solely intended to illustrate the parts and procedures I used while working on my car. I make no guarantee of the correctness of the parts and procedures for any other car or for the safety of persons working on any car. I put in a lot of research, but still, use this information at your own risk. I'm just a classic car and hotrod guy who decided to work on my sedan and share what I found.
