Results 1 to 3 of 3
    Active Member One Ring V6Q's Avatar
    Jun 07 2022
    Audi A4 B6 Avant 2.0 FSI
    Eindhoven, Netherlands
    Project B6 S4 custom rear bumper modification for my A4 Avant 3.0 Quattro
    I have an '04 B6 Avant 3.0 Quattro (in the front of both photos) and an '02 B6 Avant 2.0 FSI. They both have the Ebony black paint colour and both have an S-line interior and the S-line lowered suspension (I believe most people would refer to USP instead?). But the exterior of both Avants is totally standard.
    My wife has been using the 3.0 Quattro a lot (she drives 3000 miles every month) but since 2 months she has a brand new Audi A3 8Y Sportback S-tronic TFSI. I used to drive 1500-2000 miles every month myself, but not anymore so both Avants are actually standing still more than they are driving.*Because of that I have more time now to work on the 3.0. Last year I started with modifying an OEM B6 S4 rear bumper for my 3.0. I found it for quite cheap, I think the seller wasn't aware that he was selling an S4 rear bumper. Usually, even here in Europe, they cost hundreds of Euros so I think I was lucky.
    I wanted to make the quite tame looking B6 Avant rear a bit more aggressive. The S4 rear bumper model has this beautiful lower diffuser area, which is ideal for creating a diffuser and that's why I chose it. First I had to draw my design on the computer to visualize the idea in my head. I am not much of a sketch artist. I do have a graphic background, but in a completely different direction. After this, I could start with all the handcrafting. No 3D printer is involved here, everything is done by hand.
    First I had to determine the curvature of the bumper, because my diffuser design involved 4 fins that needed do be glued to it. To create the proper shape of the fins I used a piece of cardboard.
    After I had determined the curvature of the bumper and decided how the shape of the fins should be, it was time to cut the actual shape. For this I always use a material called "foamed PVC", which is a lightweight material. It is strong, especially when layered, yet very easy to bend, shape, cut, grind and sand. It comes in several thicknesses.
    I didn't want to create just simple, flat fins but instead I wanted to make a more 3D shape of it.
    Before I could finish the fin, I first had to check if it actually fitted the bumper and how it would look.
    I was satisfied with it, so I could now finish all four fins by filling the gaps and holes, grinding and sanding.
    I had to determine the exact position of the fins on the diffuser area and also I needed to make sure the fins would be glued on straight, which is not very easy.
    Once the positions had been determined, I could glue the fins.
    Next was a diffuser trim that would surround the diffuser area. For this I had to bend the material in all directions, following the curvature of the bumper.
    I also wanted to add a trim to the exhaust pipes.
    It then ended up looking like this.
    This bumper hasn't been finished yet, there's still a lot of work to be done. Perhaps it's hard to picture how it would look when it is finished. So here's a rear bumper modification I have done before for my wife's old A3 8P, which started with an OEM S-line rear bumper and ended up as a modified bumper with reflectors and a much nicer looking diffuser. It was made in the same way basically.
    I hope you like it. :)
    A4 B6 Avant 3.0 Quattro • A4 B6 Avant 2.0 FSI • A3 8Y Sportback S-tronic TFSI
    Veteran Member Four Rings Gin+'s Avatar
    Apr 16 2015
    CNY Syracuse
    You’ve made that look too easy.
    They're not scared of you. They're scared of what you represent to 'em.
    Jun 07 2022
    Well, it does take a keen eye and some skills I do have to admit. And above all: you need to have quite some patience.
    Sent from my SM-A505FN using Audizine Forum mobile app
