Results 1 to 13 of 13
    Apr 12 2019
    DMV Metro
    Right turn signal/ brake light/ rear light error
    I'm getting an intermittent Rear turn light/ brake light/ rear light error. It shows up randomly but everything is working fine. The signal, brake, and regular lighting are all fine. I checked the fuse in the rear fuse box and that looks good too. It goes automatically after sometime...
    I'm not sure how to even diagnose the issue. Any Pointers?
    https://imgur.com/a/KWA4PDI
    2013 Audi A6 3.0T Prestige...
    Aug 01 2021
    Saratoga, NY
    Mine does that every time we get a good rain storm, short somewhere in the connection.
    Veteran Member Three Rings A665's Avatar
    Oct 26 2019
    Mid-Atlantic
    Common failure point on C7 A6s. I replaced my left inner tail light assembly about a year ago for this general reason.
    Apr 12 2019
    DMV Metro
    So, basically either replace the entire tail assembly or leave it? I looked up and found one for $612, https://www.ecstuning.com/b-genuine-...ht/4g5945094b/
    Do we have to change this entire part?
    Veteran Member Four Rings Valpo A7's Avatar
    Nov 27 2018
    2018 Jeep Wrangler JLU; 2015 Mas Ghibli SQ4; 2005 Gulfstream Motorhome
    Valparaiso, IN
    Check the side marker light. When they go out it gives a rear lamp failure warning.
    Apr 12 2019
    DMV Metro
    Interesting, I'll look into this...
    Aug 09 2014
    1987 Scirocco, 2019 Q7, 2022 Jetta SE 2024 A6
    Connecticut
    Like others said I also replaced the tail light. Issue was moisture related as began was happening when it rained. Eventually progressed to continuous error message. I was able to remove the connector, clean it with some electrical contact cleaner and that did buy me some time... but eventually I replaced it.
    Rockauto had the LED ones from time to time, and I think I FCP Euro had them as well.
    I had posted about this, but was not able to locate it right now. but if you search here you should find more info.
    Matt
    2014 A6 TDI Prestige
    Apr 12 2019
    DMV Metro
    Thanks Matt for your response. Maybe being in the Pacific Northwest with continuous rains may have caused this. I'll definitely look into the connectors, and side markers before I decide to replace something...
    Oct 19 2018
    Fox Island, WA
    Mine does the same thing up here in the pnw. Wierd thing is it's on the other side from the inner tailight that fills up with water... Now how does water even get into the tailight?
    Sent from my SM-N986U using Audizine Forum mobile app
    Sep 16 2020
    West Michigan
    I had replaced both inner tails on my car with a similar fault due to moisture intrusion.
    The Genuine Audi units are made by Valeo, so I simply bought new Valeo units for 1/3 the cost of Genuine. (Approximately $200USD each)
    2012 A6 Prestige - APR single pulley via Fluidampr 189, Injen intake+RS7 airbox, IE HPFP, EPL TCU, JHM HX, 034 motor mounts, Eurocode drivetrain inserts, gutted cats - 034 tunes purchased, not installed.
    Veteran Member Three Rings eurospek's Avatar
    Mar 15 2008
    Chicago
    Who did you buy from for 200 each?
    I’ve been having this problem on and off when I wash the car and I’m careful spraying in that direction, but recently started getting the warning after thunderstorms and the car was parked outside during.
    Oct 26 2019
    Mid-Atlantic
    Quote Originally Posted by eurospek View Post
    RockAuto.com
    Sep 16 2020
    West Michigan
    I bought mine through Autoplicity. They have the outer in stock at $300 each. Inners are currently not in stock.
    Beware of Made in China copies. My original were made in Spain as were my replacements.
