Hello all as I said this is a 2016 A7 Prestige with OEM suspension parts and from the quick test I had a guy do he noticed the front has way less up and down support than the back does and said it's common with the extra weight in the front from the engine and transmission to have those shock absorbers wear out first. I don't do fast driving or racing and only care about comfort or a soft ride. What would you guys who know your stuff recommend me replace the oem shock absorbers to, what brand/model specifically? He said he thinks I should keep the spring and only replace the absorbers in the front but I know a lot of you here are probably more knowledgably than he is.
