Going to preemptively apologize as I don’t know much about how torque splitters work and wasn’t able to find much info about this from a quick Google.
I was told by a tuner shop that when these cars are tuned, only the stock torque can be sent to the rear due to the Haldex system. Sounds kind of odd… Is this true?
I would think this would be more mechanical in nature, as that would imply part of the car’s computers (TCU?) would be able to detect accurate torque and only exert the rated stock torque. Which sounds odd even from the factory because each car makes slightly different torque figures with so many variables at play, especially elevation.
So for example if stock the car has 350 lb-ft:
Front: 175
Rear: 175
Stage 2 450 lb-ft:
Front: 275
Rear: 175
I would also logically think if this was detected and limited by the TCU (or some other computer system? whatever Haldex is?), then it would be possible to modify these limits or change what inputs are read by the system.
Or is this just not right?
