New ordeal again, now it's coolant. Once in temperature, it starts to leak pretty fast which allows only 10 minutes drives before the engine-temp's needle starts to shoot up past 90°C.
At which point I immediatly pull over and let it do a "reverse electric pumping" for 5 minutes and retop with water.
I can't put actual ethylen glycol every 10 minutes because of the cost, so I have a very watered down mix right now just to get home. I had to do 2 hours about 100km using this strategy. I even had to stop on the side of the highway to avoid blowing the head gasket when it got past 110° that was stressful.
Anyway I'm not sure of the source of the problem. Hose, expansion reservoir, head gasket, radiator? No idea.
Maybe relevant: Before the leak got bad, the car started a few months back to exhibit a new behavior: it blows the radiator fans after the engine is cut for up to 5 minutes after parking.
I made a video:
There are drops under the reservoir, and it seems to flow against the metal lines until the back of the car.
Any help appreciated.
