I try my best to offer full discloser (even if bad) and if you have any technical questions please ask.
Replace failed PCV
079-103-542-E Separator (PCV) $431 $323 $291
079-129-717-J Gasket $46 $39 $24 (air guide gasket)
079-129-717-K Gasket $46 $39 $35 (air guide gasket)
N-904-425-01 Clip (hose clamp) $2 $1 $1
N-904-898-01 Clip (hose clamp) $1 $0.50 $0.50
N-904-095-01 Hose Clamp $0.82 $0.36 $0.32
079-145-818 Seal (Throttle Body gasket) $15 $11 $9
079-145-417-B Seal (recirc tube seals) $38 $31 $28
WHT-001-011 Seal ring (water pipe lower seal left) $4 $1 $1
G-12E-050-1G-DSP Coolant $44 $26 $23
Parts $713 Labor $2553 - Total $3266
Replace oil strainer and associated parts
079-115-175-G Strainer $12 $8 $6
079-103-175-C Valve (oil check valve) $130 $90 $68
079-103-161-Q Gasket (crank vent cover gasket) $17 $12 $11
079-145-242 Seal Ring (intercooler brick face seal) $117 $82 $73
079-145-865 Gasket (intercooler brick bottom seal) $112 $78 $60
N-910-568-01 Seal ring (upper oil feed seal) $7 $4 $3
N-903-038-01 Seal ring (oil return sela) $2 $1 $1
WHT-006-901-A Seal ring (lower oil inlet seals) $6 $4 $3
WHT-006-335-A Seal ring (outlet seal) $4 $3 $2
WHT-006-537 Seal ring (water upper inlet seal) $7 $4 $3
WHT-001-011-A Seal ring (Lower inlet water) $2 $1 $1
Parts $532 Labor $630- Total $1162
Grand Total $4428 - discount + tax etc. = $4140
They also did a wheel alignment and calibration of all cameras afterwards.
Above I put Dealer price, MSRP from online and AudiUSApart.com price.
I know full well the dealer prices are a rip, especially considering the PCV has a warranty extension and the screen has an issued recall.
But alas I am tuned, also I'm not going to tackle this as a DIY, I feel it is foolish of me to wait for the recall to be officially released while they have the car apart, they give me a loaner for a week with a free tank of gas and free tolls (whoopee lol) and it included the alignment and camera/acc calibration which I would not be able to do.
I could have saved $435 on parts alone.
Was the alignment and calibration strictly needed, perhaps no, I think I needed it though. Would have saved $600.
Looks like they charged roughly 10 hours labor total. Took them about 3 days to do.
And here is what the screen looks like after 65k miles and mostly Motul Specific 502 or equivalent used every 5k miles.
I would not say clogged, but definitely debris there. Remember it is still wet with oil which will always make such a fine screen look "clogged".
Looks like the same debris as I saw when I cut open the main oil filter (carbon) (I might check later.)
