Hello all, It's my first thread. I can not find any similar info for my situation so I will try to ask here. Try to tell my situation from begining. I just lost my only one key fob, got replaced lock cylinder and got 2 keys with it. Fit it in place, changed transponders in both key fobs and successfully programed immo with VCDS. But now I faced with another problem. I wasn't able to program central locking by key fob, so decided to change comfort/convenience module. From 8E0959433AJ to 8E0959433AS. Successfully programed central lock by key fob, but both the rear doors won't lock now. I have mechanic rear window regulators. Audi a4 b6. Can someone help me? Also Adaptation in channel 61 variants reduction, when i try to test value 1 (+1 rear mechanical window regulators(PR-4R5) installed) it hold that value, but when I try to save it and after that read the channel 61 again to check if it's saved, it show's 0 again.
Thursday,26,May,2022,21:01:01:00009
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64(VirtualBox)
VCDS Version 21.9.0.1 (x64)
Data version: 20210824 DS330.0
www.Ross-Tech.com
VIN: WAUZZZ8E82A126053 License Plate: MYCAR
Mileage: 313360km-194712mi Repair Order: scan
Chassis Type: 8E (8E - Audi A4/S4/RS4 B6/B7 (2001 > 2008))
Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65
67 69 75 76 77
VIN: WAUZZZ8E82A126053 Mileage: 313360km-194712miles
Address 01: Engine Labels: 038-906-019-AVF.lbl
Part No: 038 906 019 FP
Component: 1,9l R4 EDC G000SG 1438
Coding: 00002
Shop #: WSC 63351
VCID: 6ADB77AF167FE0D9FC-4B19
No fault code found.
Readiness: 0 0 X X X
Address 03: ABS Brakes Labels: 8E0-614-517.lbl
Part No: 8E0 614 517
Component: ABS/ESP front 1726
Coding: 04255
Shop #: WSC 12345
VCID: 65C10493FF61CFA1D1-513D
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 K
Component: A4 Klimaautomat 1015
Coding: 00010
Shop #: WSC 63351
VCID: 295948A3D3F92BC135-515B
6 Faults Found:
00797 - Sunlight Photo Sensor (G107)
31-00 - Open or Short to Ground
00601 - Potentiometer On Positioning Motor for Central Flap (G112)
09-00 - Adaptation Limit Surpassed
01274 - Air Flow Flap Positioning Motor (V71)
41-10 - Blocked or No Voltage - Intermittent
01232 - A/C Compressor Regulator Valve (N280)
30-10 - Open or Short to Plus - Intermittent
00819 - High Pressure Sensor (G65)
07-10 - Signal too Low - Intermittent
01593 - Heated Windshield (Z2)
36-00 - Open Circuit
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
Part No: 8E0 907 279 C
Component: int. Lastmodul USA 0203
Coding: 00003
Shop #: WSC 63351
VCID: 326BAFCFFE2F681984-4B33
Address 15: Airbags Labels: 8E0-959-655-84.lbl
Part No: 8E0 959 655
Component: Airbag 8.4E 3001
Coding: 0010602
Shop #: WSC 63351 000 00000
VCID: 74E769D714BB262956-5179
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 Q
Component: Lenksáulenmodul 0701
Coding: 00042
Shop #: WSC 00000
VCID: 4189F0034B89C3810D-4B19
2 Faults Found:
01333 - Door Control Module; Rear Left (J388)
49-00 - No Communications
01334 - Door Control Module; Rear Right (J389)
Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
Part No: 8E0 920 900 G
Component: KOMBI+WEGFAHRS. RB4 D25
Coding: 00101
Shop #: WSC 12345
VCID: 285F4DA7C8F312C92A-515B
WAUZZZ8E82A126053 AUZ6Z0A0248429
2 Faults Found:
Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
Part No: 8E0 951 177
Component: Innenraumueberw. 0504
Coding: 00001
Shop #: WSC 00000
VCID: 6BD572AB1985F9D187-515B
Address 46: Central Conv. Labels:. 8E0-959-433-MAX.clb
Part No: 8E0 959 433 AS
Component: Komfortgerát T01 1210
Coding: 06976
Shop #: WSC 00000
VCID: 020B3F0F0E0F189954-4B33
Subsystem 1 - Part No: 8E1959801B
Component: Tőrsteuer.FS BRM 4.11
Subsystem 2 - Part No: 8E1959802B
Component: Tőrsteuer.BF BRM 0002
Subsystem 3 - Part No: Steuerger
Component: t HL antwortet nicht
Subsystem 4 - Part No: Steuerger
Component: t HR antwortet nicht
3 Faults Found:
01366 - Opened Due to Crash Signal
35-00 - -
End-------------------------(Elapsed Time: 06:57)--------------------------
