I am super stuck with this issue have read all the posts and even had this car at 034 to help a bit with the problem. I randomly lost audio and black screen on the mmi a few months ago. I checked all the fuses and connections I could. I ordered the fiber optic loop off amazon to loop out the amp on the car meanwhile I had the car at 034 Motorsports for some maintenance and had them check all the fuses and power to the MMI they said everything checked out good. Installed the fiberoptic loop and I get the MMI back and full function but no audio. After looking on the forum here I am thinking the B&O amp is the culprit. I send the amp out the Paulison for repair.
Finally this weekend get time to put everything back together and with everything installed correctly I still get a black MMI screen. I did a hard re-start a few times and it will come on for maybe a few seconds and then go off. If I put the loop back in I get everything working besides Audio. Ugggggg super frustrating problem that I just want resolved.
Am I missing some fuses to check? Do I need to get someone to clear a code for me to get this back working? Anything else here I am missing?
Car is a 2011 Avant with the B&O system and RSNAV installed on it. The RSNAV was working great for a month or two then this happened
