Results 1 to 6 of 6
    Junior Member One Ring
    Apr 24 2022
    Rochester, NY
    ISO Part number for Driver Side Undercarriage Cover?
    Struggling to find the Part # for driver side undercarriage cover, when I look up via the name I have provided it gives me much smaller parts in comparison to the images I have seen on Google. Mine is entirely missing and living in a heavy salt state (NY) which also has the worst pot holes, I’d ideally like to have it.
    Image reference
    (B8.5 2016 Audi S5)
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    I believe it is part #4 in this diagram. Clicky click® Part numbers included in link.
    Feb 13 2004
    Silicon Valley, CA
    Great place to look for something like this is GAP, they have drawings you can navigate to find most parts.
    https://www.genuineaudiparts.com/v-2...e--3-0l-v6-gas
    Kevin - Moderator, Audizine
    Jul 16 2018
    Atlanta
    7zap is a good ETKA clone for B8 info.
    https://audi.7zap.com/en/usa/audi+a5...a5co/2016-724/
    body - group 8
    then I did a page search (browser function) for under, and went to the button for https://audi.7zap.com/en/usa/audi+a5.../8/825-825000/
    You see the part has different part numbers for left vs right as well as coupe vs sportback (as the 4-door is a longer wheelbase). Additionally, you see there's different ones for PR codes 1SA and 1SB vs PR codes 1SH and 1SJ. The PR codes are often clear to those that know, but as clear as mud to those that don't. But in this case, which your car might be is not readily evident. A US spec B8.5 allroad was 1SH. My US spec B8.0 avant is 1SA. But luckily, this particular code should be on your PR codes sticker (the sticker only has a subset of all the PR codes for a build). Or take the one you have off and look at which part revision it is, then infer which PR code you have from there.
    One good thing to check is to put the part number and revision you get from 7zap and throw it into a site like Stubek's link to see if it's still a current part rev, or has been superseded. I use parts.audiusa.com for this, but the results sometimes "require interpretation". :-)
    Feb 13 2004
    Silicon Valley, CA
    Oooh. 7zap. I haven’t seen that site but I like it. Thanks!
    Apr 24 2022
    Rochester, NY
    Sorry I haven’t replied to this thread - life happened. But I appreciate all you so much!
