Results 1 to 11 of 11
    Veteran Member Four Rings arjun90's Avatar
    Dec 27 2014
    2013 Audi Q5 3.0T
    How do we code the instrument cluster to show what gear we are in?
    How do we code the instrument cluster to show what gear (M1, 2, 3, 4, 5, 6) we are in?
    Current:
    | Audi Q5 (B8) 2013 (3.0T, Quattro) |
    70,xxx Miles
    | Audi A6 (C6) Avant, 2010 (3.0T, Quattro) |
    182,xxx Miles
    Gone But Not Forgotten:
    | Audi A6 (C5) Avant, 2004 (3.0L, Quattro) |
    221,386 Miles [April 2014 - March 2022]
    New genuine Audi/VW parts for cheap within the US - audiusaoemparts.com
    New genuine Audi/VW parts for cheap if you can afford the wait - oemVWshop
    Veteran Member Four Rings m_haiser's Avatar
    Apr 24 2011
    2012 A6 Prestige, 1998 Jeep Cherokee XJ
    Central Willamette Valley
    My 09 just does. Don't think it's anything I added
    Sent from my SM-A125U using Audizine Forum mobile app
    It's to the point where all the problems just run together in a spider web of disappointment and mush.
    -CELison
    Veteran Member Four Rings Kevin1's Avatar
    Oct 19 2008
    Long Island
    My old 2005 also came with that feature
    19 years and 320,000 miles behind the wheel of an Audi
    2022 A6 55 3.0 Prestige with Luxury Package and Black Optic Sport Package (all options). Daytona Gray Pearl Effect. Sarder Brown Interior. (July 2022 - presesent)
    RIP Audis
    2015 A6 TDI Prestige All Options except B&O - (August 2014 - July 2022) (146,179 miles)
    2005 A6 4.2 Prestige All Options - (February 2005 - August 2014) (141,179 miles)
    Jun 19 2017
    ABQ NM
    Yep, should just be default. The only car we have had that did not do that was my wife's 05 A8.
    Mine - 07 S6 Stock
    Wife's 07 A8L 4.2
    Dec 27 2014
    2013 Audi Q5 3.0T
    Is there any way to show it by default besides being stuck in "D" drive all the time? I do use the paddle shifters every now and then and only then does it show the individual gears
    Current:
    70,xxx Miles
    182,xxx Miles
    Jun 19 2017
    ABQ NM
    Quote Originally Posted by arjun90 View Post
    Which car are you asking about? It should be updating the gear at the end of the "List" after the "s"
    Mine - 07 S6 Stock
    Wife's 07 A8L 4.2
    Senior Member Three Rings akingzkid's Avatar
    Mar 04 2018
    2006 Audi A6 3.2, 2014 Mercedes E350
    Virginia
    I know how to do it. I coded my 2006 A6 to do it. It's so much better than seeing the silly "D". I need to get the info out of a note on my phone. I will post it shortly.
    2013 A6 3.0T Prestige (LED pkg, cold weather pkg, cooled seats, innovation pkg (HUD, top view camera), ACC, sport pkg, 20" rims, HPS short ram intake)
    2006 A6 3.2
    Dec 27 2014
    2013 Audi Q5 3.0T
    Thank you, I also want to restore my door chime lol
    Quote Originally Posted by akingzkid View Post
    Mar 04 2018
    Virginia
    I could not find my notes on how I did it on my C6 but I found how I did it on my C7 (2013). I used VCDS. Not sure if the process is identical but here you go.
    - How to show current gear in display instead of just “D” or “S”. Go to “02 Auto Trans” and then to “Adaptation”. In the top dropdown box select “IDE04111 - Single gear display” and then in the dropdown box beneath it (the “new value” box) select “D on/S on”. Both of these dropdown boxes were originally empty. When I clicked “Do it” it said the old value was “D off/S off” and asked if I wanted to replace it with “D on/S on”. I clicked yes. Then an error came up saying adaptation error and that it was an uninitialized control module etc. The options presented were yes, no and cancel. I selected yes for VCDS to use the default values of 12345/123/12345 instead of “No” for VCDS to try the values currently in the module”. After I did it , it said the controller accepted the values. It now shows D1, D2 and S1, S2 etc.
    2006 A6 3.2
    Mar 04 2018
    Virginia
    Are you talking about the chime for when you don’t have on your seatbelt? I coded mine out using my Vag401 XTool. I don’t know how to do it on this car with my VCDS. But I did use VCDS to turn off the chime on my 2013. Here you go. Not sure if you have this tool.
    This is what I did.
    - Go to Diagnose systems
    - Go to Common systems
    - Go to “17 - Dashboard”
    - Hit enter to go past the next 2 screens
    - Go down to “07 - Code Module”
    - It will ask “ECU Coding: Code Control Unit?”
    - Hit enter
    - There will be a Code at the bottom
    - My original # was 02129263.
    - You change the next to last number to change the seatbelt chime. So I changed the 6 to a 0 to turn it off. So my new code is 02129203.
    - Go through the steps to accept the change and then hit escape to get back to the main screen
    - Turn ignition off and unplug tool
    - I think you can change that digit to a “2” to make it ding 5 times and then not ding again.
    2006 A6 3.2
    Dec 27 2014
    2013 Audi Q5 3.0T
    Thanks, that should do the the trick
