Results 1 to 10 of 10
    Account Terminated Four Rings
    Oct 15 2013
    Close fuel cap warning in dash
    I have this warning. I replaced the gas cap seal a few years ago. Is it just a faulty code or do I need to replace the seal again?
    Veteran Member Four Rings a4audi4fun's Avatar
    Sep 28 2007
    2017 B9 A4 Technik 6 spd manual, S-Line , 2008 B7 2.0T Avant 6MTQS S-Line, Past-2005 B6 A4 3.0 6MTQS
    Vancouver, BC, Canada
    Likely the seal - try smearing around vaseline on it and see if that helps seal it; if not check for codes as you might have to replace the N80; that was the eventual solution when I was getting the Fuel Cap not closed indicator.
    Current:
    2017 B9 A4 Technik, 2.0T, 6 spd manual, S-Line, quattro with Ultra
    2008 B7 A4 Avant, 2.0T, 6MTQS, S-Line, Special Edition
    Past: - 2005 B6 A4 3.0 V6 6MTQS, 1998 B5 A4 2.8 V6 5MTQS
    Oct 15 2013
    Thanks. I have a spare n80 too.
    Oct 15 2013
    Well, I only tightened the cap and the message hasn't come back.
    Mar 04 2019
    Staten Island, NY
    Think it’s a min of 3 clicks when closing gas cap
    You a bounty hunter...Man's got to do something for a living these days......Dying aint much of a livin boy....
    May 09 2012
    Virginia
    The signal is transmitted via CAN to the cluster. In theory it’s possible to have an issue anywhere along the pathway.
    Veteran Member Four Rings Jayz691's Avatar
    Jan 21 2018
    2005 Subaru Legacy GT
    frackville, pa US
    Lol, loose gas cap..
    Sent from my LM-G710VM using Audizine Forum mobile app
    Veteran Member Three Rings Puddin Tane's Avatar
    Jun 22 2020
    Athens, GA
    re: "Close fuel cap warning in dash"
    I've had this problem every summer with my A4, only in the warm months (increased vapor pressure?). So it's definitely caused by the EVAP circuit sensing (or imagining) that the fuel system is venting through the fuel fill? Anybody know what sensor does the "sensing?"
    Sep 28 2007
    Excess pressure probably means the N80 isn't venting the gas tank fumes correctly. The N80 is very accessible at the top of the engine and is a quick replacement.
    Current:
    Oct 15 2013
    I do love the sensitivity and over sensing of the Bosch ecu and sensors. I'd rather have a false alarm than a catastrophic no alarm of a typical NGK ecu system.
