Results 1 to 3 of 3
    Oct 13 2021
    Georgia
    B9.5 RS5 EVAP system pressure sensor.
    So check engine came on this afternoon. Code is P24D8-00 for EVAP system sensor/swith b circuit high.
    Anybody got any insight on this? what to replace and where it is?
    tried clearing code doesn't clear even used VAG software.
    Thanks for any info.
    Senior Member Three Rings ninjamanRS5's Avatar
    Oct 26 2021
    Washington
    Well you can check your gas cap and see if it's properly secured then disconnect the negative terminal of your battery and reset the system. If you aren't qualified to wrench/mess with a car, hit up a tech.
    2021 Audi RS5 Sportback
    Mods: TTE720 Turbochargers, 034 4 Bar MAP, 034 HPFP, Wagner Competition Intercooler/Radiator, CTS Downpipes, AWE Touring Catback Exhaust, APR Intake and Inlet, 034 Stage 3 ECU/TCU Tune, Fuel-It Bluetooth Ethanol Analyzer, 034 Motorsports Lowering Springs, 034 Transmission Insert, 034 Front Strut Brace
    2017 Audi R8 Quattro
    Nov 02 2015
    Orlando, FL
    Had a similar issue, this was the fix for me:
    2018 Audi RS5 Coupe, 034 Motorsport ECU and TCU tune, 034 Motorsport Front Strut Brace, 034 Motorsport Transmission Mount Insert, Kohlefaser Luft-Technik Carbon Intake System, MercRacing Multi-Pass Dual-Core Heat Exchanger, Pierburg CWA100 Water Pump, Bull-X Resonator Delete Pipes, ORT Motorsport HPFP, Maxton V2 Front Splitter, Savini SV-F5 20x10 Wheels, Michelin Pilot Sport 4s 285/30/20 Tires, H&R OE Sport Springs (yet to be installed)
