Cold start idle air control? Started having issues first things I went with I got a code for MAF sensor change that spark plugs coil packs connectors to coils upgraded air filter to K&N but Still in the air box. Haven’t seen or dealt with this issue before ideas and where to go next. Obviously the cold start air control is the number one code pretty straightforward but somebody told me fuel pump maybe I don’t know I postcodes below any help would be awesome thank you
OBDeleven vehicle history log
Date: 2022-05-16 22:15:47
VIN: WAUCFAFCXDN144261
Car:
Year: 2013
Body type: Saloon
Engine: CAEB kW ( hp) l
Mileage: 212456 km
01 Engine
System description: 2.0l R4/4V TF
Software number: 4G0907115F
Software version: 0005
Hardware number: 8K2907115L
Hardware version: H09
Faults:
P261A00 - Coolant Pump "B" Control Circuit/Open
Intermittent
Priority - 2
Malfunction frequency counter - 1
Unlearning counter - 255
km-Mileage - 212344 km
Engine speed - 1290.00 1/min
Normed load value - 18.0 %
Vehicle speed - 0 km/h
Coolant temperature - 11 °C
Intake air temperature - 13 °C
Ambient air pressure - 990 mbar
Voltage terminal 30 - 12.392 V
Dynamic environmental data - 209622128C000009E513380512160662101001BC
date - 2022-04-03 13:24:03
P050A00 - Cold Start Idle Air Control System Performance
Intermittent
Priority - 2
km-Mileage - 212377 km
Engine speed - 898.50 1/min
Normed load value - 42.7 %
Coolant temperature - 22 °C
Intake air temperature - 33 °C
Voltage terminal 30 - 13.358 V
Dynamic environmental data - 209622128C00000AA513380512160C681010040A
date - 2022-04-12 18:47:25
P030300 - Cyl.3
Misfire Detected
Intermittent
Priority - 2
km-Mileage - 212456 km
Engine speed - 793.50 1/min
Normed load value - 14.1 %
Coolant temperature - 36 °C
Intake air temperature - 11 °C
Voltage terminal 30 - 14.630 V
Dynamic environmental data - 209627128C000004F81338051216041F101001CF
date - 2022-04-20 07:10:41
P030100 - Cyl.1
Misfire Detected
Intermittent
Priority - 2
Malfunction frequency counter - 3
km-Mileage - 212410 km
Engine speed - 1211.50 1/min
Normed load value - 9.0 %
Intake air temperature - 22 °C
Voltage terminal 30 - 13.688 V
Dynamic environmental data - 209628128C0000039A133805121603331010013F
date - 2022-04-17 13:14:00
P030000 - Random/Multiple Cylinder
Misfire Detected
Intermittent
Priority - 2
Malfunction frequency counter - 5
Engine speed - 1340.50 1/min
Normed load value - 15.7 %
Coolant temperature - 30 °C
Intake air temperature - 24 °C
Voltage terminal 30 - 13.099 V
Dynamic environmental data - 209628128C000006821338051216057610100134
date - 2022-04-12 18:53:53
P217800 - System too rich off idle, Bank 1
static
Priority - 2
km-Mileage - 212373 km
Engine speed - 1416.00 1/min
Normed load value - 26.7 %
Vehicle speed - 68 km/h
Coolant temperature - 82 °C
Intake air temperature - 30 °C
Voltage terminal 30 - 14.606 V
Dynamic environmental data - 209628105F0010600010610010620014CB07
date - 2022-04-03 14:42:05
P227900 - Intake Air System Leak
Intermittent
Priority - 2
km-Mileage - 212402 km
Engine speed - 798.50 1/min
Normed load value - 12.5 %
Coolant temperature - 78 °C
Intake air temperature - 18 °C
Dynamic environmental data - 209628128C000004DC133805121603AC101001A8
date - 2022-04-17 09:10:37
P030400 - Cyl.4
Misfire Detected
Intermittent
Priority - 2
Engine speed - 764.50 1/min
Normed load value - 10.2 %
Coolant temperature - 81 °C
Voltage terminal 30 - 14.559 V
Dynamic environmental data - 209628128C00000217133805121602FD10100142
P130A00 - Hide cylinder
Intermittent
Priority - 2
Malfunction frequency counter - 2
km-Mileage - 212448 km
Engine speed - 797.00 1/min
Normed load value - 20.0 %
Intake air temperature - 54 °C
Voltage terminal 30 - 14.135 V
Dynamic environmental data - 209628128C000005B8133805121605BB1010026E
date - 2022-04-17 15:26:50
P218700 - System too lean at idle, Bank 1
Intermittent
Priority - 2
Engine speed - 727.50 1/min
Normed load value - 8.6 %
Coolant temperature - 51 °C
Voltage terminal 30 - 14.654 V
Dynamic environmental data - 209622128C000005161338051216028C101000F7
date - 2022-04-03 13:29:52
P030200 - Cyl.2
Misfire Detected
Intermittent
Priority - 2
Malfunction frequency counter - 4
