Results 1 to 18 of 18
    Junior Member One Ring Sidhu's Avatar
    Jul 07 2011
    2014 B8 RS5 Engine
    Looking to purchase a used engine with low km. If there any websites or companies in North America that might have used engines please comment below. Thank you
    Veteran Member Four Rings hahnmgh63's Avatar
    Jan 10 2008
    Roy, WA
    Here is my experience. Bought a '13 RS5 in great condition but with a seized engine. Bought an Ebay 26k mile (Carfax verified mileage) engine. Installed and it failed (Rod bearing) within 300mi. Car had been wrecked 2yrs earlier on the East Coast and the Ebay seller/Dismantler I bought if from was in Sacramento, CA. Internals and oil analysis looks like the engine was stored poorly and got moisture/water in it over the 2yr period it sat. So this time around I bought a whole wrecked, but running car. 27k miles and had is shipped from a Copart auction in Ohio to one close to me. I was able to start it and drive it right up on my trailer. Sent an oil analysis off right away to Blackstone as an extra check and it came back with flying colors. Now it is ready to go into my car.
    I'd suggest for you to check Copart and IAAI insurance auctions and consider getting a whole car if you have room. Ebay engines for from $8k to $12k, I paid $11k for the car and now I have spare parts and parts to sell like a good transmission with 27k than I can probably get $2500 for plus other parts to recoup much of my costs. Good luck.
    BTW, what happened to the engine from your car?
    2003 RS6 (6Spd)
    2013 RS5 (Headers, Aluminum DSG Flywheel,JHM Stg2, etc...)
    2013 S5 (034 Stg2 & TCU)
    1974 911 (3.6ltr)
    2006 CTTS
    944T
    Senior Member Three Rings S5boxster's Avatar
    Sep 14 2016
    986 boxster
    East Brunswick NJ
    Quote Originally Posted by hahnmgh63 View Post
    Here my experience. Bought a '13 RS5 in great condition but with a seized engine. Bought an Ebay 26k mile (Carfax verified mileage) engine. Installed and it failed (Rod bearing) within 300mi. Car had been wrecked 2yrs earlier on the East Coast and the Ebay seller/Dismantler I bought if from was in Sacramento, CA. Internals and oil analysis looks like the engine was stored poorly and got moisture/water in it over the 2yr period it sat. So this time around I bought a whole wrecked, but running car. 27k miles and had is shipped from a Copart auction in Ohio to one close to me. I was able to start it and drive it right up on my trailer. Sent an oil analysis off right away to Blackstone as an extra check and it came back with flying colors. Now it is ready to go into my car.
    Are engine rebuild/overhaul more expensive than a used engine at 11k-13k
    I had a b8 s5 v8 4.2L I know it’s the not the same as rs5, but I did hear the cylinder block for all th 4.2l are same but the cylinder heads are the difference
    Sidhu
    Question for you, if it’s just rod bearing/ how much more would a engine overhaul be ? With new timing Chain tensioners, rod/main bearings, new. piston rings ?
    I’m asking out of curiosity.
    I thought that would be cheaper than whole engine replaced.
    Jan 10 2008
    Roy, WA
    RS5 Engine block is diffferent from the S5 Block, they share almost no parts. RS5 engine block was developed from the Audi/Lamborghini V10 block but basically cutting off two cylinders. They share pistons, rods, main & rod bearings and bolts. I contacted a lot of Audi places and couldn't find anyone interested in N. America of rebuilding a RS5 Block. There are many places in Europe that do but then they had the same engine in both the RS4 & RS5 starting back in 2010 to 2015 so a lot more engines over in Europe.
    2003 RS6 (6Spd)
    1974 911 (3.6ltr)
    2006 CTTS
    944T
    Jul 07 2011
    Quote Originally Posted by S5boxster View Post
    Sidhu
    Its more of a gamble to rebuild engine. They wont know the exact issue thats causing the seizure til they pull the engine out and take it apart. At that point damage could be minor or major. Its big question mark. I think find a motor with low km is the best bet.
    Oct 30 2018
    BC, Canada
    I found these on ebay.
    https://www.ebay.com/itm/32484270964..._redirect=true
    https://www.ebay.ca/itm/224830552131...sAAOSwt7ZXpN1n
    (This one apparently ships from Germany, not sure about compatibility )
    Jan 10 2008
    Roy, WA
    boneyxy, that first motor has over 107k miles on it already. $11k (incl shipping) is a lot to pay for a motor with that many miles. At least the second one has 89k Kilos/55k miles, but the remarks do say "Does not ship to the United States", Canada may be a different factor. I did let Sidhu know that I was able to buy a running and driveable but wrecked 27k mile car for $11.5k U.S. And now I have a lot of RS5 parts for spare and to sell to recoup some of my costs. Not practical necessary for everyone as I have a lift in my shop and live on acreage and do all my own work.
    2003 RS6 (6Spd)
    1974 911 (3.6ltr)
    2006 CTTS
    944T
    Jan 10 2008
    Roy, WA
    26k, says starts. Might want to keep an eye on it. Have it shipped to your mechanic, take any parts you want as spares, sell the rest or the car as a whole. https://www.iaai.com/VehicleDetail/33264296~US
    42k miles runs & drives https://www.copart.com/lot/57987411/...rs5-mi-detroit
    Whereabouts in Canada? I'm picking Northern Tier lower mileage cars so shipping will be less but East, Central or West Coast?
    2003 RS6 (6Spd)
    1974 911 (3.6ltr)
    2006 CTTS
    944T
    Jul 07 2011
    West Coast of Canada in BC. I found one I think Ill shoot you a message.
    Established Member Two Rings Jeffreykins's Avatar
    Oct 14 2019
    '14 Mini, '92 MB 300e, '01 Escape, '14 Ram, '15 Genesis, '04 Baja, '16 Focus, '17+'18 Fiestas,
    Alaska
    Came out of the shadows to say, Mark is the guy to listen to for just about anything here. Can't go wrong with his advice and this advice is no exception! Keep up the good work sir. This community thanks you.
    Jan 10 2008
    Roy, WA
    Thanks Jeff. How is the car doing up there in the great North?
    2003 RS6 (6Spd)
    1974 911 (3.6ltr)
    2006 CTTS
    944T
    Oct 14 2019
    Alaska
    It's been performing really well here, winter was great, but now I'm right in the middle of an apparent catastrophic internal steering rack failure at 56k miles. So, just as we're finally getting the weather for fast (ish) convertibles, it's laid up in the garage. We'll see how it plays out!
    Jan 10 2008
    Roy, WA
    Sorry to hear about your Steering rack. 7.2hrs to swap it out seems to be pretty high. I'm no Audi dealer and I can probably do it in 3~4 at the most. I believe most any A4, S4, A5, S5, steering rack from a B8.5 should work as long as if you have Dynamic Steering it needs to be a Dynamic rack and if you don't get a non-Dynamic rack.
    2003 RS6 (6Spd)
    1974 911 (3.6ltr)
    2006 CTTS
    944T
    Jan 10 2008
    Roy, WA
    https://www.iaai.com/VehicleDetail/33444570~US
    Portland, OR with 44k miles Says water damage which makes me a little nervous but says run & drive and it looks like the electronics in the dash work ok. Auction date not assigned yet.
    2003 RS6 (6Spd)
    1974 911 (3.6ltr)
    2006 CTTS
    944T
    Oct 14 2019
    Alaska
    Haha brother, you know if somehow I came up with the scratch for that RS5 I'd just drive that instead! Looks to be in way better shape than mine. I ebayed a water damaged rack for $425, super fingers crossed that it works. Seems iffy but pretty much everything I do is.
    Established Member Two Rings LifetimeAudi's Avatar
    Nov 30 2020
    Durham, NC
    We have a couple RS5 4.2L in stock. Give us a call 919-536-9557.
    Veteran Member Four Rings Ape Factory's Avatar
    Jun 24 2017
    RS5/Infiniti QX70S stormtrooper/Jeep Wrangler Rubicon 10th Anniversary
    San Antonio, TX
    Another option overseas, rebuilt. With the Euro and dollar almost equal, it's not a bad price for a fully refurbished engine.
    https://www.vankronenburg.nl/audi-rs...lSM-_rIvoAGXXg
    Instagram: redmist5 Youtube; https://tinyurl.com/redmistvideos
    2013 Audi RS5 Misano Red-Klassen ID M10/JHM Tune/AWE Exhaust/Eventuri Intake/Bilstein PSS10/H&R Sways/STERN/CR-15//ECS SS Brake Lines/Rear Diff Bushing/ECS rear diff inserts, front end links/034 Motorsports subframe inserts & Rear End Links/Tranny insert/E-code head, tail lights/Maxton splitter/Red Trim Start Button/black emblems/VCDS.
    Jan 10 2008
    Roy, WA
    He ended up purchasing a used engine and had it installed and running, just working out a few other bugs but sounds like it's sucessful and back on the road.
    2003 RS6 (6Spd)
    1974 911 (3.6ltr)
    2006 CTTS
    944T
