hi everyone,
did a classic oil change (even though I have a pump, wanted to swap the plug out for a magnetic one) and put the car on ramps, removed bottom panel and drained out the oil.
Now I bought an OEM dipstick (yellow handle) instead of relying on the MMI but changing the oil in my driveway, obviously my driveway isn't level and when I put in the 6L in there, I could barely register a reading on the dipstick so I ended up adding another litre+ or so and got the dipstick right about middle maybe towards max.
The MMI eventually reset itself after a few drives and it said full.
However it bothered me because I know not supposed to overfill this and given that I had the car on ramps and the drain plug towards the front of the oil pan that I:
- may not have gotten all of the oil out
- maybe the incline was impacting the dipstick reading?
I estimated that I probably put in about 7.5L of oil into the engine, and so I decided to pump out roughly 1.5L or just under that to keep me around 6L as all of the capacity in the manual and what I googled showed me that it's 6.2L capacity.
Now here's my problem:
I backed my car into my driveway which of course is at an angle and let it sit overnight and checked the oil and it was a max maybe a tad over, but I thought that was fine given again, car wasn't level and the dipstick measures from the front of the oil pan. So fast forward to just now after taking it for a drive to run some errands and I park forward into the driveway (i.e. uphill) and I check the oil and it's barely registering mid on the dipstick.
So my question is:
- How much oil does this 3.2L supposed to take?
- does parking the car on completely level road to check oil level make that much of a difference?
