Results 1 to 21 of 21
    Junior Member Two Rings
    Jan 30 2019
    Houston/TX
    Train Horn Install A4 B8 (incognito)
    Audi A4 B8 Train Horn Install (my first build thread post let me know if you see something or need additional info)
    Alright guys, this thread is my official installation guide for a train horn on our Audi A4s. I would like to thank Michaels and Lowes for the excessive use of their parking lot, lmao, but for real no joke finding a good place to do work. Below is a set of items you will need depending on your train horn purchase.
    Train Horn Installed: I went with Vixen Train horns Model: VXO8315/3118B. (Heads up, though customer service was great, I had to go back and forth with them on the quality of their tanks. The first two they sent me which they claimed to have gone through quality control prior to shipping had leaks in them, obvious leaks, which just makes a frustrating situation. Who buys something and wants to wait, and wait again to finally be able to install a working product.
    Anyone looking to sponsor more builds hit me up at [email protected]
    Upcoming projects open for sponsorship:
    CTS Boss 500 Kit (with Air intake)
    Eurodyne Maestro Tuning package software and hardware
    Wheel Spacers 5-10mm
    Front lower adjustable control arms
    Adjustable shocks
    Red coil packs
    PA system
    19 inch rims
    Current Installs:
    GFB DV+
    CTS IC
    GFE Magnum Pro-dry Air filter
    CTS catch Can
    Racechip GTS
    Tools: (may Have missed some sorry)
    Car Jack (if not intending to pull of bumper)
    Drill
    Variety of Steel/titanium drill bits
    Wrenches
    Deep sockets wrench 13-17 m
    Wire cutters
    Electrical Tape
    Fuse taps Fuses
    Kill switch
    It all started at Michaels with my trusty Rhino Ramps. I was originally trying to find a place to mount the horns in the engine bay as you will see but that quickly came unreasonable due to the excess heat of the engine and lack of room.
    Long story Short you won't really need the rhino ramps if you do it the way I list below.
    1.) With the hood open, when looking into the engine bay, you can see by the windshield and brake fluid reservoirs there is a black cover with a little battery symbol on it. Remove the entire piece by removing the two plastic screws (flat head screwdriver).
    2.) I mounted the horns on preinstalled studs located within that bay (one of the many shown with a green arrow) between the cabin and engine as you can see for the two smaller horns. For the larger horn with the solenoid, I had to install it by drilling a hole through the engine bay through the firewall material to the little bay (green arrow). (I Utilized the same size nuts and bolts that came with the horn but with longer bolts for the large horn being I installed the horns separately.)
    ***prior to mounting the horns, I would fit at least one of the tube ends into the horn for ease later*****
    The tubing supplied is ¼ in OD tubing which slips right into the respective fittings. I ended up buying upgraded tubing that could withstand higher amounts of heat and pressure as the first tube used wilted enough to block the air. I did the local connections first on the horns and then installed
    My entire goal was to mount the entire system, so it is not visible to the naked eye even when looking at the location. Being an A4, not the S4, we have an extra cut-out location of where the second muffler would be. It’s covered by a little plastic cover which can easily be removed. This is the location I mounted my train horn compressor and tank. (add red arrow to rear pic of where install occurred)
    Picture of the wheel well without cover with compressor and tank installed.
    The Muffler well with the cover on. It protrudes out just a little so some modifications/cuts had to be made to the plastic covering.
    I proceeded to mount the Tank and the compressors. I originally was using a car jack and just lifting the passenger rear side enough to for me to work under, but long story short just remove the bumper.
    3.) Remove the car's rear bumper for easy access and plenty of workspaces. Youtube the process it is super easy, takes like 5-10 minutes tops, and makes the job so much easier.
    5.) After the bumper was removed, I emptied the trunk and removed the contents of the wheel well to expose the top of the emptied wheel well.
    6.) Drill holes and space out the tank and compressor
    a. Be careful if you plan to install in the same location as there are many electrical components that you do not want to F with.
    The Inside of the luggage fuse box compartment where the bolts support the hanging compressor: note the wires were connected after securing it towards the end of the build.
    7.) Mount the compressor
    a. Due to the spacing available the entire process was not recorded or very well photographed. But looking at the location and if you’re looking to mount there like me here are some notes.
    b. The compressor will be free hanging (due to a bar on the underside next to the blue highlight) so use spacers to keep a firm connection. (Red arrow Showing Free hanging, So I have a bolt from the top secured with a washer, going through the hole I drilled within the luggage compartment fuse box area, secured with a washer then a spacer, then a washer prior to pulling the bolt through the compressor, but and finally a bolt. Maybe overkill but is secured it tightly and removed the unwanted space I had.)
    c. Save enough space out from the side of the car (the outer-side) so you can work on all 4 screws. I mounted it to close to the outer side and the underlip made it impossible to secure the one bolt hence only using three bolts. *** red Circle of area where I lacked space***
    8.) Mounting the tank
    a. I mounted the tank to the underside, on the side, of the wheel well. note the battery and wiring location pre-drilling
    b. Tank use video to reference location: 20220318_193844 (13 seconds to 18)
    Picture from Topside of the wheel well
    Tank from underside mounted on the side of the wheel well (location depicted in red)
    Attachment 270599
    Tank and compressor installed in the muffler hub.
    Attachment 270600Attachment 270601
    After installing the tank and the compressor I went ahead and did the electronics. I used a multimeter to evaluate the various fuses on the driver side and luggage fuse boxes. On my car the fuses are active whether the car was on or off, so I installed a kill switch for the compressor (aftermarket buy). For install I would just follow the diagram provided with the kit, it was easy and made sense. The final connections were the hoses which I had to buy additional length for to make it from the tank in the back to the horns in the front.
    From the tank outlet I choose, I connected the ¼ OD hose , and pulled along car follow path in red.
    Attachment 270602
    Pulling from the center I pulled the tubing toward the outside to go along the out fender.
    Attachment 270603
    Into the fender underside
    Attachment 270604
    Out the fender protection into the inside wheel well cover passenger side.
    Attachment 270605Attachment 270606
    Out of the wheel inside plastic cover into the engine bay compartment
    Attachment 270607
    From there you should be able to see the hoses and pull them to the solenoid horn, which will then supply the remaining horns with air upon pressing the button.
    Electronics you will have to figure out what works best for your car and provides you the 12V needed (connection wise I used the provided diagram from the instructions). The horns were simple I connected them to the driver-side fuse box with a fuse tap 10-amp fuse provided. I pulled them from the outer compartment to the cabin by going through the driver-side firewall. (YouTube it there are a ton of videos and it’s very easy.)
    Red arrow shows the grounding point.
    Attachment 270608
    The connections in the back were even easier, again following the wiring manual diagram provided, and with additional wiring, I connected the underside compressor to the luggage compartment fuse box by pulling the wires through a grommet. (red arrow)
    Attachment 270609
    I circled the grounding point I used. And the fuse tap I placed a red box around it.
    I connected all these to the kill switch and shit there you go.
    Attachment 270610Attachment 270611
    Feb 13 2004
    Silicon Valley, CA
    For the pictures, you need to host them online and link them the way you did for a couple that show up.
    Kevin - Moderator, Audizine
    Feb 15 2016
    Cambridge,Ontario
    i imagine this mod to be only slightly less irritating than the guy who puts the crackle tune on his car.
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Senior Member Three Rings A4B8 2.0tfsi's Avatar
    Nov 02 2017
    Sweden
    Lmao
    2012 A4 B8 Avant 6MT F23L Custom Tune 3" 200 cell DP Sachs Performance Clutch
    Veteran Member Four Rings MyDimeIsUp's Avatar
    Dec 04 2019
    West Chester, PA
    I like crackle tunes, only on downshifts though. Not too big on crackles when letting off gas.
    2020 BMW M340i xDrive - Mineral Grey
    2012 Audi A6 3.0T Prestige - 034 Stage 1 ECU and TCU | CTS Turbo Intake | 034 Street Density Motor Mounts w/ JHM Trans Insert | ECS X-Pipe
    2013 Audi allroad - RIP
    2007 Toyota corolla
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    I can't help but think of the safety aspect of this mod. The sound of a train horn could very well cause an overreaction from other drivers and cause an unnecessary accident.
    Feb 15 2016
    Cambridge,Ontario
    I would definitely need to be wearing depends for the type of accident I would have.
    Sent from my Pixel 6 using Audizine Forum mobile app
    1976 Yamaha XS 360
    Feb 13 2004
    Silicon Valley, CA
    Or maybe give an old guy a heart attack
    Dec 28 2006
    Western Maryland
    LOL!
    Veteran Member Four Rings bakedziti's Avatar
    Oct 23 2014
    Buffalo, NY
    No tuning or mod developing company in their right mind would sponsor someone with such a questionable critical thinking process…almost can’t believe you tried to solicit sponsorships with this post.
    1999 A4 Avant | Cactus
    2001 S4 | Silver | 6MT
    2021 Porsche Macan Turbo | Carrara White
    Sold: °2014 S4 | MGM | 6MT | ABG | ACC | ADS | AFS | ASA | B&O | MMI | Sport Diff | 034 DP 57/187 | 034 Adjustable UCAs, Toe Arms, Front + Rear Endlinks | 034 LCAs | 034 Strut & Engine Mounts | 034 Trans Mount + Insert | AWE Touring + Res DPs | Bilstein PSS10 | CR15 | G5-r | H&R Sways | Merc HX | P3 | Ringer S3+ Clutch & FW | ECS AK
    °2011 A4 | 6MT
    Feb 15 2016
    Cambridge,Ontario
    Quote Originally Posted by bakedziti View Post
    So he is asking for someone to pay for his mods ? I don't get this " sponsorship" at all.
    Can I get a sponsor to pay for my back brakes ? They need changing
    1976 Yamaha XS 360
    Oct 23 2014
    Buffalo, NY
    Quote Originally Posted by Ark88 View Post
    Adjustable shocks
    Red coil packs
    PA system
    19 inch rims
    Yeah, it’s a bit ridiculous.
    °2011 A4 | 6MT
    Aug 30 2018
    embarrassing modification. Agreed with the above, it aligns with the same type of person who puts the obnoxious crackle tunes. Nobody thinks youre cool, everybody is actually laughing at you.
    Also looking for sponsors for a new 911 carerra S. am I doing it right?
    2019 Audi Q5 - 28k; Arctic White; Black Optic
    2003 Mercedes ML350 - 166k; Gray
    Feb 13 2004
    Silicon Valley, CA
    Remember to keep it civil everyone. Just because you don’t like it doesn’t mean it’s bad. OP did what he wanted and from the looks of it did it very well.
    Established Member Two Rings Liberty0rDe4th's Avatar
    Mar 28 2022
    usa
    It's actually illegal in many areas to use the horn on a public road. Not to mention making railroad employees pee themselves. I've had many a mini heart attack when some douche canoe blows one while I'm working. "Just saying"
    Sent from my Pixel 6 Pro using Audizine Forum mobile app
    Feb 15 2016
    Cambridge,Ontario
    Quote Originally Posted by Stubek View Post
    Agreed, It is not for me and I would consider it an annoyance, but will admit im well past 50 and could be in the grumpy old man territory..
    I'm sure some people love crackle tunes and loud horns or they wouldn't make them.
    1976 Yamaha XS 360
    Jan 30 2019
    Houston/TX
    Appreciate the information. It's weird bc I uploaded them all in the same manner, while some started to display properly others would revert to the link style display which you see above. I will give it another go and add some more details.
    Jan 30 2019
    Houston/TX
    Is the max # of pictures you can upload ten?
    Feb 13 2004
    Silicon Valley, CA
    Here is the info
    NEW ACCOUNT / LURKER ACCOUNT: 0 posts (can only post in the New Member Welcome Forum and Help Forum)
    PM Space: 0 messages
    Gallery Space: 2 Megabytes (MB)
    Attachment Space: 0 Megabytes (MB)
    REGISTERED MEMBER: achieved at 1 day AND 1 post
    PM Space: 4 messages (includes both inbox and outbox)
    Gallery Space: 2 MB
    Attachment Space: 2 MB
    ACTIVE MEMBER: achieved at 4 days AND at least 2 posts
    PM Space: 100 messages
    Gallery Space: 4 MB
    Attachment Space: 5 MB
    JUNIOR MEMBER: achieved at 30 days AND at least 10 posts
    PM Space: 200 messages
    Gallery Space: 6 MB
    Attachment Space: 10 MB
    ESTABLISHED MEMBER: achieved at 180 days AND at least 50 posts
    PM Space: 300 messages
    Gallery Space: 8 MB
    Attachment Space: 20 MB
    SENIOR MEMBER: achieved at 2 years AND at least 200 posts
    PM Space: 500 messages
    Gallery Space: 10 MB
    Attachment Space: 40 MB
    VETERAN MEMBER: achieved at 4 years AND at least 400 posts
    Access to the "OG AZ Forum"
    PM Space: 1000 messages
    Gallery Space: 20 MB
    Attachment Space: 50 MB
    * 2 or more Infraction points limits account to Registered Member level
    Feb 15 2016
    Cambridge,Ontario
    wow i didn't know any of this , i really should read more .. now i have to go find this OG AZ forum, i wonder if there are snacks ?
    1976 Yamaha XS 360
    Jan 23 2023
    Miami
    I know my reply is a bit late, but I wanted to thank you for sharing your train horn installation adventure on your Audi A4 B8. Kudos for your perseverance and detailed explanation. It's super helpful for anyone looking to embark on a similar journey. Speaking of horns, I'm all about adding some variety to life, and I've stumbled upon an awesome collection of drill train horns at bosshorn.com. They're not just for car installations; I find these to be a fantastic attention-grabbing tool. Plus, they add an element of surprise to holidays, parties and other outdoor events that's hard to beat. So, if you're looking for a way to make a grand entrance or simply want to liven up a celebration, these horns are a blast!
