Originally Posted by
mxrz
I don't have to own both on the RS5 to understand physics and how brakes work on a car. Audi would be a bunch of dumb amateurs if they made a version of the RS5 with brakes that can't overcome the real limiting factors; abs and tire traction. They aren't, and they haven't. Both the steel brakes and carbon ceramic brakes produce enough friction to engage abs. You would have to purposefully abuse the braking system to reach a point where the slight thermal capacity advantage of the carbon rotors starts making a noticeable difference. Then again, under such condition, like at the track, these brakes are garbage... go ask the 911 GT3 guys what they run at the track. Steel brakes. These aren't carbon-carbon rotors like racecars have, these are made for the street, to look pretty and make less brake dust, they don't actually have the performance pedigree of racing carbon brakes, they're made from totally different compounds. It's for show.
Your anecdotal evidence is just you not really understanding the difference you're experiencing. If you'd done an actual distance test, you would know it's nonsense. It's the same old tired BBK are better, argument. Brembo still has a disclaimer on their website, basically saying any kind of braking upgrade kit doesn't make the car stop faster because the components in question (rotors, pads, calipers) are not the liming factor.
Well I have owned both, each for about a year
My commute is the same
And I definitely have a lot more confidence with the ceramics than the steel ones
I don't have to stand on the brakes as much when I need to come to a sudden stop
And believe it or not, I couldn't care less what the gt3 guys run at the track
So you're saying if they had "performance pedigree" then the laws of physics would change ?
According to you, if both the steel and ceramic have enough power to engage the abs
Surely if these were made with different compounds, as you stated, it would also have no effect?
You're contradicting yourself
Most of the times I have seen people say ceramics aren't worth it on this forum
It's usually people who don't have them
Never seen someone who had them, that didn't think they are worth it
