Results 1 to 12 of 12
    Jan 01 2012
    2004 A4 Avant
    CO
    Fault code 00473 after rear brake job
    Looking for some help on things to troubleshoot after doing a rear brake job as I don’t have much time these days with a kid. Did my rear brakes last weekend following rosstech’s youtube video on using VCDS to do the rear brakes. Drove to work two days last week and discovered on Wednesday that both rear brakes were hot and you could smell them so it appears that the pads are dragging. After getting home later in the day I did a quick run through with VCDS to open the e brake and close them again to see if something went wrong the first time but it didn’t help. Over the weekend I pulled the calipers, checked everything over and ran through the sequence again opening/ closing the ebtake and compressing the piston again. Double checked that the calipers were moving freely on the slider pins (cleaned and regressed during initial brake job) and everything is good there. There were no fault codes on the parking brake module either time, but when running through it again on Saturday I noticed the ABS module had code 00473. Researching the code online has lead to quite a few threads with this issue but no real fix other than one guy saying he needed to replace the wiring to both EPB motors. Everything g seems to work fine, car gives no warning like the EPB is on while driving, EPB functions properly, but rotors and pads are still getting very hot during driving. Anybody ever dealt with this code and what was the fix?
    | 2004 A4 Avant | Gloss Dark Grey |
    | 2.7t K04 swap | 034 RSB | Apikol snub | 17z BBK |Vogtland GT1 Coilovers | Moog adj. UCA's | Peeler reps |
    | 2011 A4 Avant | Brilliant Black | 6MT swap | APR S2 | APR Downpipe | Vogtland Coilovers | RSE's | 034 Sway/tranny mount | Q5 brakes |
    Jul 16 2018
    Atlanta
    Post the actual complete DTC from VCDS. Maybe people remember what an 00473 is, maybe they don't. Plus 00473 is a component identifier, not the actual fault subcode, which should be in the DTC.
    If you had it in the air, I'd say spin the tire and see if it goes around a few times after you let go. My rears will go around a few times, while my fronts might make it one time around.
    Can't think of anything offhand that would be a common problem after doing the rears correctly (ie, using tool to release/engage EPB motors).
    Established Member Two Rings A4fuzz's Avatar
    Jan 13 2017
    2019 Audi RS5 Sportback / '21 Acura TLX SH-AWD Advance
    Ohio
    I'm just going to throw some thoughts out there, I'm no expert. If the parking brake works, it must be communicating fine. If there is an issue, it could be corrosion on the connectors or maybe a bent pin if you disconnected the plugs. I've also been told that doing this procedure without a battery tender can cause damage to the module. Its very sensitive to having correct voltage. Maybe the pads are defective or incorrect? This just doesn't sound like an electrical or mechanical problem.
    2015 A4 Premium Plus ~ Sport Plus ~ Black Optics ~ APR K04 ~ APR Stage II 93/E85 ~ APR Downpipe ~ APR FMIC ~ APR Carbonio intake ~ R8 Coils ~ 034 Billet Drivetrain Mount Inserts ~ 034 RSB and Links ~ 034 X-Brace ~ Canyon Run CR-15 Strut Brace ~ S4 Front and Rear Brake Upgrade ~ Drilled & Slotted Powerstop Rotors ~ ECS Stainless Steel Lines
    Jan 01 2012
    2004 A4 Avant
    CO
    Quote Originally Posted by Smac770 View Post
    Ill post a pic of it or the scan itself after work but there was nothing more than fault code 00473 in there (http://wiki.ross-tech.com/wiki/index.php/00473)
    Quote Originally Posted by A4fuzz View Post
    never touched the electrical connectors, audi manual says states specifically not to disconnect them during pad and rotor replacement. car was also hooked up to a battery charger the whole time during any work.
    Feb 15 2016
    Cambridge,Ontario
    so what is " did my rear brakes " ?
    pads ?
    pads and rotors ?
    pads rotors and a fluid flush ?
    did you rebuild calipers ?
    after what you did did you bed the brakes ?
    i think its always helpful to be descriptive on what you did when looking for help.
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Jul 16 2018
    Atlanta
    Please no pics of logs. Just copy/paste the log text full here. You can wrap it in code tags if you want.
    Jan 01 2012
    2004 A4 Avant
    CO
    so what is " did my rear bakes " ?
    pads ?
    pads and rotors ?
    sorry, wrote this at 5:30am while getting ready for work. i did new pads and rotors and that's it. i usually don't bed rear pads for a daily driver unless i did front and rears at the same time.
    here is the full scan of the car:
    Code:
    Monday,09,May,2022,16:26:16:54601
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
    VCDS Version: 22.3.1.1 (x64)
    Data version: 20220401 DS337.0
    www.Ross-Tech.com
    VIN: WAUWFAFL1BA087871   License Plate: B8 AFTER BRAKES 20220509
    Mileage: 176930km-109939mi   Repair Order:
    Chassis Type: FL-AU48 (8T0)
    Scan: 01 03 05 08 09 15 16 17 19 2E 42 46 47 52 53 55 56 62 72 77
    VIN: WAUWFAFL1BA087871   Mileage: 176930km-109939miles
    01-Engine -- Status: OK 0000
    03-ABS Brakes -- Status: Malfunction 0010
    04-Steering Angle -- Status: OK 0000
    05-Acc/Start Auth. -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    2E-Media Player 3 -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    53-Parking Brake -- Status: OK 0000
    55-Headlight Range -- Status: OK 0000
    56-Radio -- Status: Malfunction 0010
    62-Door, Rear Left -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    77-Telephone -- Status: OK 0000
    Address 01: Engine (0-----CAEB)       Labels:| 06H-907-115-CAB.clb
       Part No SW: 8K2 907 115 AG    HW: 8K2 907 115 D
       Component: 2.0l R4/4V TF H19 0002
       Revision: E1H19---    CVN: 29BA8F83
       Coding: 010C010A180F0160
       Shop #: WSC 40319 001 1048576
       ASAM Dataset: EV_ECM20TFS0118K2907115AG 001002
       ROD: EV_ECM20TFS0118K2907115AG.rod
       VCID: 74E7972ADF6E662FDE-8020
       VINID: 9D196759159C05244020720704B3FC6428
    No fault code found.
    Readiness: 0110 0101
    Address 03: ABS Brakes (J104)       Labels:. 8K0-907-379-V1.clb
       Part No SW: 8K0 907 379 BJ    HW: 8K0 907 379 BJ
       Component: ESP8 quattro  H04 0060
       Revision: --------    Serial number: --------------
       Coding: 070D18
       Shop #: WSC 06335 123 12345
       VCID: 020BC1F29DDA589FDC-8056
    1 Fault Found:
    00473 - Control Module for Elect. Park/Hand Brake (J540)
                013 - Check DTC Memory - Intermittent
                 Freeze Frame:
                        Fault Status: 00101101
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 230
                        Mileage: 176915 km
                        Time Indication: 0
                        Date: 2022.05.07
                        Time: 10:44:55
                 Freeze Frame:
                        Hex Value: 0x0000
                        Hex Value: 0x00A2
                        Hex Value: 0x0032
                        Hex Value: 0x0297
                        Hex Value: 0x00FF
    Address 05: Acc/Start Auth. (J393)       Labels:. 8K0-907-064-05.clb
       Part No SW: 8K0 907 064 CG    HW: 8K0 907 064 CG
       Component: BCM2 2.0      H05 0434
       Revision: 00002001
       Coding: 0B0200
       VCID: 77FDA026C6180D37FB-8022
       Subsystem 1 - Part No SW: 8T0 959 754 A    HW: 8T0 959 754 A
       Component: FBSAUDIB8 IDG  H50 0071
       Serial number: 0810000117298021
       Subsystem 2 - Part No SW: 8K0 905 852 D    HW: 8K0 905 852 D
       Component: J764 ELV MLB  H37 0042
       Serial number: 2310000059186010
    Address 08: Auto HVAC (J255)       Labels:. 8Tx-820-043-3Z.clb
       Part No SW: 8T1 820 043 AQ    HW: 8T1 820 043 AQ
       Component: KLIMA 3 ZONEN H08 0180
       Revision: C1000000    Serial number: 01241120100623
       Coding: 64002000
       Shop #: WSC 06335 000 00000
       VCID: 000FCBFA93D64A8FCA-8054
    Address 09: Cent. Elect. (J519)       Labels:. 8K0-907-063.clb
       Part No SW: 8K0 907 063 P    HW: 8K0 907 063 P
       Component: BCM1 1.0      H30 0392
       Revision: 10030001    Serial number: 00000000721261
       Coding: 26001015063CAF010000080300003D0D0F1C060802010161000000
       Shop #: WSC 11868 002 104857
       VCID: 3C777F0ABFBEEE6FD6-8068
       Subsystem 1 - Part No SW: 8K1 955 119 A    HW: 8T1 955 119   Labels: 1KX-955-119.CLB
       Component: WWS 251110  H06 0070
       Serial number: SWF10110256074
       Coding: 00FD11
       Subsystem 2 - Part No SW: 8K0 955 559     HW: 8K0 955 559   Labels: 8K0-955-559.CLB
       Component: RLS  H04 0003
       Serial number: 11165062
       Coding: 025028
       Subsystem 3 - Part No SW: 8K0 941 531 AL    HW: 8K0 941 531 AL
       Component: E1 - LDS  H08 0090
       Serial number: 00000000001611100597
       Subsystem 4 - Part No SW: 8K0 907 410 C    HW: 8K0 907 410 C
       Component: HOMELINK  H01 0010
    Address 15: Airbags (J234)       Labels:| 8K0-959-655.clb
       Part No SW: 8K0 959 655 K    HW: 8K0 959 655 K
       Component: AirbagVW-AU10 H41 0610
       Serial number: 003GLD0GVX59
       Coding: 303837354230303030304A55304C384B3053
       ASAM Dataset: EV_AirbaECUVWAUDI010 003010
       ROD: EV_AirbaECUVWAUDI010_003_AU48.rod
       VCID: 45811AEEC474AFA7B9-8010
       Seat occupied recognition:
       Subsystem 1 - Part No SW: 8K0 959 339 C    HW: 8K0 959 339 C
       Component: BF-Gewichtss.  H02 0040
       Serial number: 5810000R1000001U66
       Crash sensor for side airbag: driver side:
       Serial number: 6334MSME58703A1FM
       Front Passenger's Side Airbag Crash Sensor:
       Serial number: 6344MSME5964757FW
       Rear Side Airbag Crash Sensor (on driver's side):
       Serial number: 6352QSME7C6A2038P
       Passenger side rear thorax airbag crash sensor:
       Serial number: 6362QSME307754026
       Crash sensor for front airbag: driver side:
       Serial number: 63732SME1B7A2522$
       Crash sensor for front airbag: front passenger side:
       Serial number: 63832SME69761B1A8
    Address 16: Steering wheel (J527)       Labels:. 8K0-953-568.clb
       Part No SW: 8R0 953 568 K    HW: 8R0 953 568 K
       Component: Lenks.Modul   H07 0156
       Revision: 00000000    Serial number: 20101126000733
       Coding: 000017
       VCID: 499916DEE06C4BC75D-801C
       Component: E221 - MFL  H02 0010
    Address 17: Instruments (J285)       Labels:. 8T0-920-xxx-17.clb
       Part No SW: 8K0 920 950 H    HW: 8K0 920 950 H
       Component: KOMBIINSTR.   H20 0258
       Revision: 00200000    Serial number: EIL71JTCA
       Coding: 831F11000300D705020000
       VCID: 3467572A97EE262F1E-8060
    Address 19: CAN Gateway (J533)       Labels:. 8T0-907-468.clb
       Part No SW: 8T0 907 468 AB    HW: 8T0 907 468 H
       Component: GW-BEM 5CAN   H06 0117
       Revision: GB800053    Serial number: 5300G10B168056
       Coding: 00C303
       VCID: 0109CEFE98DC4387C5-8054
       Subsystem 1 - Part No SW: 8K0 915 181 E    HW: 8K0 915 181 E
       Component: J367-BDM  H07 0170
       Serial number: 100083FB181110
    Address 2E: Media Player 3 (R199)       Labels:. 8T0-035-785.clb
       Part No SW: 8T0 035 785 A    HW: 8T0 035 785
       Component: SG ext.Player H08 0290
       Revision: 00000000
       Coding: 020302
       VCID: 3979661EB08CDB47CD-806C
    Address 42: Door Elect, Driver (J386)       Labels:. 8K0-959-793.clb
       Part No SW: 8K0 959 793 M    HW: 8K0 959 793 M
       Component: TSG FA        H12 0357
       Revision:             Serial number: 0000011743766
       Coding: 011C03204000410001
       VCID: 4A9B29D2E56A40DF54-801E
    Address 46: Central Conv. (J393)       Labels:. 8K0-907-064-46.clb
       Revision: 00002001    Serial number: 0137828948
       Coding: 0126063A20BA445480B0023200000000
       Subsystem 1 - Part No SW: 8K0 959 719     HW: 8K0 959 719
       Component: GTO BF  H06 0050
       Serial number: 00000000000000329397
       Subsystem 2 - Part No: 1K0 951 605 C
       Component: LIN BACKUP HO  H05 1501
       Subsystem 3 - Part No SW: 8K0 959 591 A    HW: 8K0 959 591
       Component: J245 PS133  H07 0041
       Subsystem 4 - Part No SW: 8K0 959 591 A    HW: 8K0 959 591
       Component: J394 PS229  H07 0041
    Address 47: Sound System (J525)       Labels:. 8T0-035-223-ASC.clb
       Part No SW: 8R0 035 223 F    HW: 8R0 035 223 E
       Component: DSP STD       H11 0440
       Revision: 00000000    Serial number: 00000000000001
       Coding: 0203010102
       VCID: 2F6D58467EC805F763-807A
    Address 52: Door Elect, Pass. (J387)       Labels:. 8K0-959-792.clb
       Part No SW: 8K0 959 792 M    HW: 8K0 959 792 M
       Component: TSG BF        H12 0357
       Revision:             Serial number: 0000110632186
    Address 53: Parking Brake (J540)       Labels: 8K0-907-801-V1.clb
       Part No SW: 8K0 907 801 H    HW: 8K0 907 801 H
       Component: EPB Audi B8   H09 0100
       Revision: 00000003    Serial number: 10000000667419
       Shop #: WSC 00000 000 00000
    Address 55: Headlight Range        Labels: 8K0-907-357.clb
       Part No: 8K5 907 357 B
       Component: Dynamische LWR  H02 0010
       Revision: 00000001    Serial number:
       Coding: 0000004
       VCID: 3979661E708CDB47CD-806C
    Address 56: Radio (J503)       Labels:. 8Tx-035-1xx-56.clb
       Part No SW: 8T1 035 186 R    HW: 8T1 035 186 R
       Component: Con3 Sirius   H06 0351
       Revision: 00000009    Serial number: AUZ5Z6J1501003
       Coding: 04020002010285004359070803
       VCID: 46831DE2F172A4BFB0-8012
       Subsystem 1 - Part No SW: 8T0 919 603 F    HW: 8T0 919 603 F
       Component: Display
    1 Fault Found:
    02635 - Tuner Not Enabled/Activated
                000 - -
                 Freeze Frame:
                        Fault Status: 01100000
                        Fault Priority: 7
                        Fault Frequency: 1
                        Reset counter: 190
                        Mileage: 176915 km
                        Time Indication: 0
                        Date: 2022.05.07
                        Time: 10:44:15
    Address 62: Door, Rear Left (J388)       Labels:. 8K0-959-795.clb
       Part No SW: 8K0 959 795 F    HW: 8K0 959 795 F
       Component: TSG HL        H11 0357
       Revision:             Serial number: 0000110549303
       Coding: 010C03204000210001
       VCID: 45811AEECC74AFA7B9-8010
    Address 72: Door, Rear Right (J389)       Labels:. 8K0-959-795.clb
       Component: TSG HR        H11 0357
       Revision:             Serial number: 0000110549300
    Address 77: Telephone        Labels: 8P0-862-335.lbl
       Part No SW: 8T0 862 336 E    HW: 8T0 862 336 E
       Component: FSE_256x BT     H42 0650
       Revision: 00000000    Serial number: 00000005100645
       Coding: 0010370
       VCID: 3D71720E64A4E767E1-8068
    End-------------------------(Elapsed Time: 03:26)--------------------------
    Jul 16 2018
    Atlanta
    There's no fault code for the J540. Clear DTCs again and see if anything comes back. The ABS module is odd sometimes when clearing DTCs; you have to do it two or three times to make it realize there's no more issues.
    But do that, don't touch the epb for a few days, scan again, see if something comes back on its own. If not, then activate and release the epb and scan for codes before turning engine off. Some things go away when you engine off. So scan live. If it's clean at that point, and it should be, there you go. If not, then come back with that new scan.
    Jan 01 2012
    2004 A4 Avant
    CO
    I’m aware of that and had been trying with no luck. Well, if I didn’t have much of a problem on my hands before I certainly do now. After I posted that scan I was looking through the ABS and parking brake module and I accidentally clicked into basic settings. I was in a rush cause I had to get my son up from his nap and feed him. Since you can’t back out from the “put battery on charger” warning I just hit ok thinking I’m not doing anything and just going to hit “done,go back” once I get in. Well, that seemed to be enough to piss it off cause now I have a parking brake malfunction flashing on the dash and codes in the brake module. Probably need a new module now. Anyone know if that module has CP on it or can I easily swap a new one in myself? Charging the battery now and hoping I can somehow reverse these codes by clearing them and getting the battery fully charged but it’s highly unlikely. That still doesn’t take care of the original code in the ABS module though. Still looking for input on that.
    Veteran Member Four Rings Gunnark100's Avatar
    Oct 21 2012
    Earth...
    Quote Originally Posted by jjvwg View Post
    From memory, should be cp free module.
    Retrofits: FL taillights / MMI 3G & 3G+(Street view incl.)/ Color Cluster & FL S5 Cluster/ BiXenon/ ADS Lite
    Other: ECU Tune/ VCDS Tweaks/ FL Gearknob/ Soundproofing/ Interior 6D Carbon Wrap/ Rieger Rep Front Bumper Valance/ Basic sound(8) upgrade to "ASS"(9+1) + B/O Sub(in sidepanel)/Tweeters + Activsub/ Efficiency Prog via Cluster & Gateway flash/ Sideskirts/ Window Tint/ Wsp Peeler reps/ License plate & Interior leds
    Jul 16 2018
    Atlanta
    Yeah, people have picked up a used one and swapped it in easy enough. It sits in the front of the right rear cargo hold, behind the right cover. The black box with EPB in the letters on it.
    Jan 01 2012
    2004 A4 Avant
    CO
    Well if there’s no CP then that’s great, 1 min fix once I have a new one in hand. Time to find a local part out I guess. Posted in the Ross tech forums as well to see if there’s any way to salvage this one.
