Today I have a built motor for sale from my project car. For full clarity, I picked up this car as a non runner with the intent to fix and resell. After solving a few issues and getting the car running, we noticed the turbos had damage to the seals they were china ko4s so not surprised lol. I’ve decided to part out the setup and swap a stock engine with BW ko4s back into the car and will sell the car at a later date(message for info). The motor itself is fine 150psi all cylinders and I can perform a leak down test for the buyer if needed. The engine has less than 2k miles and was only ran on a break-in file. I have receipts and lots of pictures documenting the build! Heres whats done to it:
105k late model block, hot tanked and honed
Je stock bore pistons with new rings
Srm rods with new bearings
Arp studs
New factory oil pump
All new seals
Fresh paint and powder coat on most components
New cam tensioners
New valve seals and guides
Balanced rotating assembly and polished crank
Looking for $5500 plus ship with all accessories and if you want the turbos to rebuild id leave those and the inlets. Have lots of other stage 3 parts from the build also.
