For those who feel that the factory B&O system with the subwoofer in the spare tire well sounds poor...
I'd kind of accidentally caught that the subwoofer may have been wired out of phase from the factory browsing threads about my car, which I picked up used last month. I'm an audio geek who has made a career in high end audio and custom integration and I've got a reasonably keen ear. Not that it took that to realize the system as it came from the factory under-performs, objectively speaking.
So this morning, I decided to see if the subwoofer indeed was wired out of phase from the factory. The answer is a resounding YES.
My experiment was simple. I fired up some music in the car and listened to it the way it came from the factory. I tried dialing the "fader" all the way to the front and then all the way to the back. When I moved it back, there was more bass. So, I removed the sub. Easy - two nuts and the hand "knob," then unclip the connector on the top of the sub. Box is out. Five minutes. Fired up the soldering iron, removed the woofer from the box and reversed the wires on each voice coil of the factory sub. I used a desoldering bulb to clean the terminals up which made it easier to put back together. The only minor challenge was getting the wires right so they can run through the channel under the woofer frame and so that the woofer fits back over the pins and screw holes. It'll really only go back one way. Took me 15 minutes.
Tested again. Again I can say unequivocally - there's way more bass. Now the car sounds like it has a premium factory audio system.
The simple science here is that the subwoofer being wired out of phase causes it to cancel bass in a critical range in the audio spectrum. The speakers in the rear of the car don't make much, if any bass so setting the fader to the back reduced the cancellation. However, the speakers in the front do make bass. Concensus is that they play down to around 50-55Hz. That's well in to the mid-low bass region of the audio spectrum. I suspect the factory sub covers from around 100Hz and starts to roll off ~30Hz (with the help of a lot of cabin gain). So mid-bass drivers in the front of the car overlap the sub in a critical frequency range. Wired backwards, they fight or cancel each other causing the weak bass we all hear. But after reversing the phase, they're now reinforcing each other. Net result, I was able to turn both the bass and subwoofer settings way down. I still have way more bass than I did before and the system doesn't have to work as hard. So it has pretty solid bass and plays much more loudly. Again, at a level one should expect from a premium car's premium audio system.
I did also add some "fill" or batting loosely tucked around the subwoofer driver in the enclosure. I had some from an old JL sub I have taken apart (for repair) so I stole the batting/insulation from it. If you want, you can probably get this from Parts Express.
I'm not saying this is better than replacing/relocating. That can unlock a whole other level of potential and is an apples to oranges comparison. But this was easy and for many, I suspect will make them completely happy with the factory system.
I'm happy to answer any questions anyone may have.
