Results 1 to 24 of 24
    Veteran Member Three Rings skhan91's Avatar
    Nov 13 2015
    B7 RS4, B7 A4 Avant
    Air suspension lowering options - OBD11 vs. Suspension Links
    Hi all,
    Any feedback or opinions on lowering the adjustable air suspension through OBD11 vs. Suspension Links?
    Curious to hear the benefits / cons of both methods
    Feb 03 2018
    Castle Rock, CO
    I have used the links on other cars with similar set ups. I have never been one to want a huge drop, so the links are a very cheap and very effective route for me. I dropped 1/2"(13mm). That was enough for my desires and the roads around here. Only issue was time. I got access to a 4 post lift for those cars and did a lot of measuring........Once installed, though, never an issue.
    Nov 13 2015
    B7 RS4, B7 A4 Avant
    Quote Originally Posted by WhiteDiamond View Post
    Thanks for the input, was curious thought how come you didnt just lower the car with OBD11 or VCDS? That method doesnt require any hardware and is essentially free given you have access to a VCDS tool
    Feb 03 2018
    Castle Rock, CO
    For me, it was simply a fact of daily driver and no real interest to invest in additional means of tuning/programming and such.
    Nov 22 2017
    Elk grove, ca
    I dropped my S6 1" with links yesterday. Took less than an hour.
    2014 S6
    Roc Euro intake
    RS7 inlets
    Pinnacle Performance RS7+ turbos
    MERC heat exchanger w/cwa100
    SRM LPFL w/ethanol sensor
    DS1
    Leistune ECU/TCU
    Current PB 11.02@127
    Jul 27 2013
    indianapolis/indiana
    another option is vagcom I have lowered both my s7 and rs7.
    https://www.audizine.com/forum/showt...-list-and-help
    2003 RS6 Apr stage 1 and tiptronic, Apr divertors, Clear bra, Yellow konis SOLD
    2014 S7 Audi exclusive edition 1, Havana black metallic exterior, Havana brown interior, APR stage 1 ECU/TCU, Total Loss Wreck
    2016 RS7 Stage 2, Mythos Black Metallic, SRM/DS1
    2025 RS6 Daytona Grey Pearl, executive package, carbon package, alcantra package, soft close doors, B&O, res delete
    Senior Member Four Rings THCarpenter's Avatar
    Jun 26 2021
    C7.5 S6 Prestige
    East Coast
    Quote Originally Posted by skhan91 View Post
    you have a maximum of 17mm lowering with OBD11 or VCDS options before you run into the physical limits of the headlight leveler.
    by replacing the connection with lowering links, you change the geometry and dont run into the issue of ACC or headlight level soft errors where you have to restart the car.
    that green leveler arm has an upper and lower limit. When you change the settings to lower with the stock links, it doesnt account for the hard limit upper and lower calibrations, and will give up the code.
    if you change out the height of the rod, then you can keep the geometry and not incur the soft faults.
    I absolutely hated it when I lost CC before I did the links
    2016 S6 Mythos Black / B&O, Cold Weather, Drivers Assistance, Black Optics
    2016 S6 Mythos Black / Sport, Cold Weather, Drivers Assistance, Black Optics, Night Vision
    "How to spend a shitload of money and still be slow, the THCarpenter story." - sepheroth86
    Senior Member Three Rings jsilas's Avatar
    Dec 29 2015
    2016 S6, 2021 SQ5, 2016 R1M, 2004 R1
    WA, PNW
    I chose VCDS/OBD11 lowering over links for the simplicity of altering the ride height with software instead of having to get underneath the car each time.
    If you're considering options, I'd strongly urge you to look into the CETE module. That's what I have now, and it's excellent in that it is constantly variable using the CETE app, allows greater range of lowering (including a "Show Mode") at the push of a button, and leaves no fault codes.
    2016 S6 | Mythos / Black | Prestige | Sport | Carbon | Black Optic | Bang & Olufsen | Driver Assistance | OEM RS7 Turbos | APR Stage III ECU/TCU | CoD delete | APR DPs | SRM Intakes | CETE AVC | CETE ASC V2 | H&R Sway Bars | VIM | CarPlay | Opti-Coat Pro+ | XPEL Ultimate PPF | XPEL ceramic tint
    Veteran Member Four Rings Audibellybutton's Avatar
    Jun 28 2019
    California
    I slammed the shit out of mine in vcds. a lil lower than the max recommended lower and its been fine for about 20k miles so far. no sign of issue at all. also adjusts to the different drive modes ie its higher in comfort etc and i can raise it at will. No regrets, of course you can do this with links too but i already had vcds so it was pretty much a free mod
    C7 Audi A7 Prestige 3.0t (RIP) - Dual Pulley E40 , Turtle TCU , Ported Blower, Meth, Porsche 997 TB, Merc Racing Heat Exchanger, CWA-100, RKX Silicone Intake hose, RS7 Airbox, RS7 LPFP, JHM 207 pulley,SRM Driveshaft Upgrade, H&R Springs, 034 Drivetrain inserts, Vossen VFS2, RS7 Steering Wheel, Autotech HPFP
    C7 Audi S6 Prestige 4.0t (Current) - ZF8 Swap, E85 tune W/ FE STG2 Turbos, WMI, Merc Racing HX, EMP Coolant Pump,GFB DV+,LPFP upgrade, ECS Inlets, TS Gates, Exhaust
    IG:@stolens6
    Jan 31 2009
    2016 RS7-P
    There's a setting in VCDS about headlight leveling when the car is too low, you'll know it's on the low side during start up the headlights don't do the vertical range check.
    Jun 28 2019
    California
    Quote Originally Posted by widebodyfx View Post
    you are probably right about that actually. I have aftermarket headlights on my S6 they dont do the leveling Im having separate issues with those as well. so prob shouldn't lower as much as I did if you have oem headlights.
    IG:@stolens6
    Veteran Member Four Rings hunter_killer's Avatar
    Mar 25 2020
    Mandan, North Dakota
    So if a guy goes 10-15mm lower than factory is it really going to mess with ACC? Aside from Travis mentioning it, I’ve seen a few others say the same problem, but nobody said what the limit is for VCDS in terms of ACC working properly.
    2013 Quartz Gray S6: APR Stage 1 and CTS intakes.
    Gone: 2013 S4 Stage 2. RIP.
    Veteran Member Four Rings Alabama's Avatar
    Apr 19 2020
    C7 S6
    Birmingham Alabama
    Quote Originally Posted by hunter_killer View Post
    The person who authored the AZ document "Audi C7 VCDS Tweaks" wrote "Note that maximum Audi-approved drop is 17mm from what I've gathered." In my experience doing this, I did not run into an "Audi limit", rather I ran into a VCDS limit. VCDS would only accept a maximum change in number; anything above that and I would get an error in VCDS. I set the numbers to the maximum that VCDS would allow and succeeded in lowering the car about 1.5 cm. Since then I have had no issue with ACC or any other system due to the lowering.
    2014 CPO S6, SunTek PPF (applied by CGS Vinyl), BlackVue dashcam (installed by Radio Active), Hawk Brake Pads/Zimmermann Rotors/Goodridge SS Brake Lines, H&R sway bars, Alu Kreuz, 034 Drivetrain Mount Inserts, SRM Driveshaft Carrier (mechanical/maintenance by Franklin Automotive)
    Jan 31 2009
    2016 RS7-P
    I had VCDS lowering plus H&R or Cete module when I noticed the headlight start-up wasn't doing the usual process. ACC, hard for me to provide too much input my old S6 had the RS6 style bumper with the alignment done at Audi afterwards it was still sensitive and disabled sometimes. My RS7 is not that low, my TDI is decently low and neither of them have ever given me fits about ACC but they are thankfully not on OE air.
    Mar 25 2020
    Sounds good. Thanks guys for the responses. One of tasks tonight was lowering my car some and I have a medium size trip this weekend that I would like to use cruise control on.
    Dec 29 2015
    WA, PNW
    I'm pretty low via CETE module and I have no issues whatsoever with ACC.
    Jun 28 2019
    California
    For what its worth, my ACC works fine as well. I am at about a 20mm drop. may raise it up a bit. although aesthetically I would go lower If i could
    IG:@stolens6
    Junior Member Two Rings
    Nov 21 2014
    Dearborn mi
    What's the code for vcds? It'd removed from all the diys for getting authorization
    Sent from my LE2117 using Audizine Forum mobile app
    Jul 27 2013
    I have mine lowered a max to 412mm, vcds would not accept anything more. I have since raised it to 400 for winter and it sits at 405 with some rubbing on bumps on the rear in dynamic. Security code is 20103.
    One big change is step 6, set reference level not start up to reference level. All the codes for acc and adaptive headlights clear.
    Mar 25 2020
    Lowered the car this morning with OBD11. So far no quirks with anything
    Nov 13 2015
    B7 RS4, B7 A4 Avant
    Quote Originally Posted by dab View Post
    Could you elaborate on this? is there a difference? I am seeing various instructions saying it should be "Start up to reference level". Also, in my OBD11 app, I dont even see an option for "Set Reference Level". Only "Start up to reference level" and "Start up to reference level (Production).
    - - - Updated - - -
    Did you use "Set Reference Level" or " Start up to Reference Level" for step 7 here:
    Mar 25 2020
    - - - Updated - - -
    I can’t remember what I did so I can’t truly answer your question. I followed ignitiontube’s YT video on using obd11 for lowering the car. I do have to raise mine back up for winter.
    Sent from the howitzer using Audizine Forum
    Established Member Two Rings 1BadTundra's Avatar
    May 01 2019
    PA
    Sorry to resurrect this, but I think I fuct up bad.
    I tried to lower my car via OBDeleven today and there was no step for "Delete calibration for level control", so I did the rest of the steps, and it accepted them, but even with the new values, the car isn't any lower.
    No I have a yellow icon and message for the air system Malfunction. I cannot clear it. The code is "Level control system", and the small print says "Axle Load Definition Not Performed". Can someone please tell me how to correct this? I dont want to go to the dealer.
    Veteran Member Three Rings Botbasher's Avatar
    Jul 26 2018
    2014 S6 "Elsa" - Mk 6 JSW - Scratch Built Lotus 7 Replica
    Humidity, NC
    Quote Originally Posted by 1BadTundra View Post
    Did you hit the button that said "Reset All Adaptations."? If you did, then yes... you are dealer bound! Several others have done the same and all ended at the dealer. It seems that there is no way to "insert" values with anything other than ODIS.
    I've had various suspension faults pop up during adaptations and several of them were when the suspension became loaded between the parking brake and trans brake. I always release the parking brake now, which allows the wheels to move and have had no issues during various adaptations.
    Could always try a battery reset and see if the module comes back to normal and resets itself. Always surprises me at the problems that simple tool fixes!
    Good Luck with it!
    KS
