Results 1 to 24 of 24
    Established Member Two Rings CTquattro21's Avatar
    Jan 07 2018
    Rear subframe rust
    Just wanted to post an fyi for everyone that encounters salted roads in winter. I have a ‘15 SQ5 with ~65k miles. I saw some rust while putting on my summers. I know there’s usually some surface rust but felt this was a little worse than that.
    Had a frame guy take a look and he confirmed that it was more than surface rust. So I decided to just replace the whole thing. Just had the new one installed and this is what was under the plastic panels on the bottom of the subframe.
    Had the new one coated and the plastic panels removed.
    Veteran Member Three Rings kt883's Avatar
    Nov 10 2010
    Stoney Creek
    cant hurt to replace it but I think you're years away from seeing any real issues form that sort of rust. Pretty standards for any car in the rust belt
    Currently
    2015 Audi Q5 3.0TDI S-Line, Malone stage 2 with Deletes
    Previous:
    -2013 Audi S4 3.0T S-Tronic Teknik
    -2010 Audi S5 4.2L 6MT
    -2008 Audi TT 3.2L S-Tronic
    -2007 Audi A4 3.2L S-Line 6MT
    Jan 07 2018
    Quote Originally Posted by kt883 View Post
    You do realize the large hole in the second picture is supposed to be solid metal right? This is more than surface rust. There is material missing. I agree a failure wasn’t imminent but my family rides in this vehicle so why wait. Again just an fyi.
    Jul 31 2020
    2014 Ford Fiesta SE and 2017 Honda Civic LX
    Phoenix AZ
    When I bought my ‘14 TDI, I had a DEF leak right after that. They repaired it under warranty. Right after that, I discovered that my rear left subframe was badly rusted. It was not as bad as yours, but bad nonetheless. I pulled the plastic rock guard, wire wheeled it, and sprayed it down with POR 15. That was two years ago. It has been stable since then, but it is definitely on my monitoring list. I live in Phoenix, but I bought the car from the Midwest, so I don’t know if the rust was there when I bought it or the DEF spraying the entire underside of my car caused it. I do know those rock guards hold an unnecessary amount of moisture in place up against the metal.
    Veteran Member Four Rings RPMtech147's Avatar
    Apr 05 2014
    Texas
    That's pretty minimal. I'll be cutting the control arms out of my A3...cuz rust.
    B6 S4, B8 A4, 8P A3, and something, something.
    Jan 07 2018
    Quote Originally Posted by pdnation View Post
    I was thinking wire wheel and coat with POR15 at first. But the frame guy confirmed I was beyond that and wanted to start cutting out and replacing sections. Thinking there was more under that plastic I just replaced the whole thing. Like you said that plastic is perfect for allowing salt and moisture in and keeping it there and hidden from sight.
    Jan 07 2018
    Quote Originally Posted by RPMtech147 View Post
    That sucks. Yeah mine wasn’t about to fail but the clock was ticking.
    Feb 12 2008
    Michigan
    wow, ive never seen an Audi frame look that bad and I am in the salt belt too
    Jul 31 2020
    Phoenix AZ
    Just out of curiosity, how much was it to have it replaced?
    Jan 07 2018
    Quote Originally Posted by Fast4esT View Post
    That pic with the hole was under a plastic panel that Audi put on the lower half of the subframe. The plastic is a bad idea by Audi and the reason I made the post.
    Jan 07 2018
    Rear subframe rust
    My mechanic did the replacement in about 6.5 hours which came out to just over $800 plus tax. I got the new frame off eBay for $288 plus $125 shipping from California.Image1652137610.504952.jpgIMG_2894.JPG
    Jul 31 2020
    Phoenix AZ
    Yeah, I do a lot of work on mine, but from the looks of it, I would gladly pay someone $800 in labor to do that job.
    Jan 07 2018
    Rear subframe rust
    My thoughts exactly
    Veteran Member Four Rings arjun90's Avatar
    Dec 27 2014
    2013 Audi Q5 3.0T
    I'm in the Northeast as well but my 2013 Q5 only has surface rust on the rear subframe and rarely goes outside anytime it snows. Por-15 / penetrating oils go a long way but only works well when used at the earliest. I always thought these SUV's were a little more immune to rust versus the wagons. Looking forward to tackling the pinch bolt soon
    Current:
    | Audi Q5 (B8) 2013 (3.0T, Quattro) |
    70,xxx Miles
    | Audi A6 (C6) Avant, 2010 (3.0T, Quattro) |
    182,xxx Miles
    Gone But Not Forgotten:
    | Audi A6 (C5) Avant, 2004 (3.0L, Quattro) |
    221,386 Miles [April 2014 - March 2022]
    New genuine Audi/VW parts for cheap within the US - audiusaoemparts.com
    New genuine Audi/VW parts for cheap if you can afford the wait - oemVWshop
    Feb 15 2016
    Cambridge,Ontario
    just so you guys dont feel all alone
    your A4 cousins are feeling the same pain ..
    2014 ..
    25 year old tremclad and a dollar store brush to the rescue.
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Senior Member Three Rings lumberwood's Avatar
    Apr 06 2016
    Hamilton, ON
    2014 ..
    Ew! Nice work
    Jun 06 2014
    Washington, D.C.
    Thanks to those who have posted here already. It's good to know I'm not alone. I have a '14 SQ5 at 120k miles and I need to replace my rear subframe crossmember due to rust.
    I'm hoping to find a used replacement rather than buying a new part from Audi. Does anyone know whether there are other models in the Audi family (e.g., '14 Audi A8) or VAG family (e.g., '14 Porsche Macan) that use the same rear subframe and can be used as direct replacement? I guess i'm not even sure if Q5 (2.0T) or Q5 (3.0T) are direct replacements? Thanks in advance for any guidance.
    B8 S4 6MT | GIAC Stage II | Milltek Non-Resonated | Hotchkis Sway Bars | ECS Intake | Roc-Euro Short Shifter | Eurocode Alu Kreuz | 034 Transmission Mount | 034 Rear Diff. Mount | RS4 Grille | CR-15 Brace | P3 Gauge | USP SS Clutch Line | ECS Rear Carrier Mounts | 034 Subframe mounts | ECS Street Shield | Moog Endlinks | MercRacing HX | B12 Pro Kit
    B8.5 SQ5 | 034 Stage II | MercRacing HX | RKX Transmission Mount | P3 Gauge
    Oct 20 2021
    Bulgaria
    Mine is rusty as well. In the future I will have to change it.
    Junior Member Two Rings Fizzhole's Avatar
    Aug 10 2020
    Outdoor gear
    Capital Region/ NY
    Quick question about this, but a little back story first. 2014 Q5 3.0 here and have been hearing weird pops and creaks for the past 6+ months. While i was under the car the other day I noticed pretty much the same situation you have here. I guess my question is, did you have and creaks or noises coming from the subframe areas at any point? I have noticed that if my approach is at any sort of an angle i sometimes get a pop and I usually have creaks when initially accelerating. Seems like its coming from the "mid to rear" area driver side. Thoughts?
    Also, i am in very upstate NY with 118k on the clock. All the bushings "seem" to look good and I find myself exhausted from searching.
    Jan 07 2018
    Quote Originally Posted by SchreibCity View Post
    Definitely find a used one. I found one on eBay for $440 shipped. A new one was something like $1300. I’m not sure about compatibility with other models but I believe all the SQ5/Q5’s of that generation have the same sub frame.
    Jan 07 2018
    Quote Originally Posted by Fizzhole View Post
    I’ve had pops and occasional clunks since I installed diff and drivetrain inserts. I also have subframe inserts among other mods. I also have a pop just after I move the car and just before coming to a stop. The entire car has been inspected more than once and no one can find the reason for the pop. But, none of my sounds are from the rusty sub frame. I still have them all after the subframe was replaced.
    Aug 10 2020
    Outdoor gear
    Capital Region/ NY
    Quote Originally Posted by CTquattro21 View Post
    Good to know.... I guess, lol.
    I did notice the sounds beginning around the same time I was installing inserts and RSB. It would stand to reason then that the inserts may be shifting around under load. Glad to hear that the sounds probably aren't from a failing sub frame though. Gonna slide under tomorrow and get a better look, brush some rust and see how bad it REALLY is. Hopefully its just superficial.
    Thanks for the input!
    Jun 06 2014
    Washington, D.C.
    Thanks! Managed to track down a cheap local replacement from a Q5 3.0T on car-part dot com. Haven't swapped it out yet.
    Jan 07 2018
    If you still have the plastic covers over the bottom part of the subframe try to get a peak under them if you can. That’s where the worst of it was for me. They seem designed perfectly for catching salt and holding it there to achieve maximum rot. Not sure what Audi was thinking there. I had them removed from my replacement sub frame.
