Results 1 to 39 of 39
    Senior Member Two Rings Tom Sawyer's Avatar
    Apr 01 2007
    TN
    B9 SQ5 Dashcam - Fitcamx Install and impressions
    Fairly new SQ5 owner (B9 2020) and wanted to share a nice OEM like Dashcam solution that I recently picked up. I had a typical stick on dashcam in the S4 with hardwiring and was pretty excited to find something that looks factory for the B9 platform.
    Install took around 15 minutes tops and the kit came with nice trim tools that made the job easy and took away any worry about dinking up the plastic. For anyone interested, here is their website: https://fitcamx.com/ Easy ordering process and they will reach out to get your exact model/year to verify fitment. It was cheaper to order it directly from them than buy on Amazon, but it does take a little longer to get of course.
    Things to note if you decide to grab one: Be sure to pop the large top panel off first. past that, either of the other pieces can come right off, but I went from large forward and it was a piece of cake. I went ahead and pulled out both of the wire connectors but if you have small enough fingers you could probably just pull the top one which is where the camera taps into.
    As far as functionality, it broadcasts a private WiFi network (which you can change the name of once you get it set up the first time). App is straightforward and does allow you to view the camera feed live. You will most likely need to turn off 'use cellular data' for the app to view the stream. Camera supports g-force sensor locking of files to prevent overwrite and also a parking mode to start recording when a force is sensed. Have not tested that out yet. Did come with a 64gb micro SD card, but I swapped that out with a 128Gb Samsung durable card I used in my S4.
    Video quality is sharp, clear, and vibrant. I'll try to upload a clip to YT and update this tread when I have that posted.
    Pictures attached for your perusal, hope this is helpful and for sure I would recommend this... the clean look is really worth it and they do have a front + rear option as well. I went for front only as I'll probably pick up a cheap standalone unit for the rear to keep the wire running requirements to a minimum.
    2020 SQ5 Prestige, Quantum Gray, S Package, Nappa, BO, DA
    Gone but not forgotten: 2000 B5 S4, 2004 B6 S4, 2003 RS6, 2016 S4 P+ DSG
    Jun 14 2012
    PDX
    Wow, that's super clean. How's the recorded resolution look? Is power supply plug and play?
    VFF109 21x10 et30 | DWS06 295/35r21 | AWE touring resonated | AWE Intercooler | RocEuro | Cete | 034 Trans Mount | EPL stage 2 ECU/TCU | Feynlab Self Heal Ceramic | OEM black out badging
    Apr 01 2007
    TN
    Quote Originally Posted by subaruski View Post
    Recorded resolution is 4K and looks great, plenty of detail for a dashcam. Sure is, no extra wires, 100% plug and play. They even did a nice job wrapping the wires in typical felt/cloth wrap to avoid rattles.
    Mar 13 2018
    I’ve sent them an email to see what they have for my 2021 A6…
    Apr 08 2011
    '21 SQ5 & '16 Golf R
    NoVA
    Oh nice! I’ve seen this and have been wondering how it is. Thanks for sharing!
    They offer a rear camera option as well. I wonder how that install is.
    iain
    Apr 01 2007
    TN
    YouTube Video Example
    My pleasure! Good question; from what I saw on a RAV4 setup, it was just another connector in the main camera harness that plugged the rear camera. Could vary on our platform of course.
    As promised, here's a quick 1m clip from the cam. I've got it set to split at 1 minute per file but that can be adjusted of course. I stripped out the audio as I had music playing that I'm sure YouTube would have flagged.
    Apr 08 2011
    NoVA
    It looks like the rear camera is a universal camera that has to tap into a fuse panel.
    EDIT: Actually for the integrated, vehicle-specific options it is only the single wire.
    iain
    Apr 08 2011
    NoVA
    Do you mind getting some night video as well?
    iain
    Senior Member Three Rings A4_n00b's Avatar
    May 27 2007
    Pittsburgh, Pa.
    Very cool. I’ve been looking for something that’s a clean install and is fairly OEM looking like this.
    Thanks for posting the pics and write up.
    Current:
    2022 Audi S3, 2023 Audi SQ5
    Retired:
    2003 Audi A4 3.0, 2004 Audi allroad 4.2, 2004 VW Jetta, 2008 VW Jetta Wolfsburg, 2010 Audi S4, 2012 VW GTI, 2014 Audi S4, 2015 VW GTI PP, 2016 VW Tiguan R-Line 4MO, 2018 Audi S3, 2018 Audi SQ5
    Apr 01 2007
    TN
    Happy to... I'm settled in for the evening but I'll try to hop out tomorrow after dark. I'm curious to see how it does at night as well.
    Apr 08 2011
    NoVA
    I shot them an email with pics of the mirrors in both of our cars. My wife’s VW isn’t listed (surprising given VW sells 100s of millions of Golfs worldwide) but she has a rain sensor so they likely have a fit and just don’t have it listed.
    iain
    Mar 29 2021
    State College, PA
    Just to let everyone know, at night you can’t see license plates due to reflection from headlights. This is a concern that was brought up many times.
    There is also plenty of YouTube videos about it as well.
    Veteran Member Four Rings DiscoDan's Avatar
    Sep 07 2018
    Colorado
    Anyone know the frame rate for the 4k front camera? The 2k front camera as well?
    Both are using the same processor, but no where is the sensor listed that's being used.
    ALso the site lists the "resolution" as "2160P (4k)" -- 4k is 4096x2160 pixels; and a 16:9 format is 3840x2160 pixels which is not 4k, that's actually called UltraHD. Clarification on the true "resolution" of the camera would also be worthwhile to know.
    True 4k, or the lower UltraHD, with a low frame rate (less than 30 fps) would be sub-par regardless of the resolution of the sensor (which is not listed).
    2020 SQ5 - Prestige | Quantum Gray | 034 Stage 1
    Apr 08 2011
    NoVA
    Quote Originally Posted by DiscoDan View Post
    Does it really even matter if it’s “true” 4k though? Neither your insurance company or the cops are going to find a 4k display to watch the footage if it comes to that.
    The 1440p video the OP posted to YouTube is more than clear enough for insurance or accident purposes. /shrug
    The price is also really good and it seamlessly integrates into the mirror mount. That’s a big bonus for me personally.
    iain
    Apr 08 2011
    NoVA
    I ordered the front and rear cameras for my car, "4k"/1080p. For $250 we'll see how it goes. If they're fine I'll order another set for my wife's Golf R. Even though her car has a rain sensor it still needs to get power from the fuse panel for the rear camera so the install is little more involved.
    iain
    Apr 01 2007
    TN
    That's awesome, looking forward to hearing how the dual cam setup goes. I didn't get a chance to get some night footage l/n but will hopefully this evening.
    Sep 07 2018
    Colorado
    No, I'm mostly interested in the fps at whatever the resolution is. I've generally always stuck with BlackVue or Thinkware cameras due to the higher quality and publishing of all hardware used. I'm open to this because I like the clean OEM-like look, but wish the seller/manufacturer would put up the specs that other reputable manufacturers post.
    Apr 01 2007
    TN
    Here is a quick night clip... YT is still rendering the HD (as of 7:15 AM CST) so it may be another 30m or so before the full resolution is online.
    Jul 14 2009
    Pasadena
    https://www.audizine.com/forum/showt...hlight=dashcam started a thread a while back with a competitor oem fit cam. still working flawlessly.
    IG: @matthewee
    Veteran Member Three Rings JayCar's Avatar
    Dec 13 2015
    2023 Tesla Model Y Performance, 2022 MINI Cooper S Countryman, Specialized Tarmac SL4 Sport :-)
    Houston, TX
    Daytime video looks good, night time video isn't great. Over saturation with lighting makes most things unreadable. Maybe they'll have a firmware update for it. Otherwise, nice product.
    2014 SQ5/Monsoon Gray
    Go: APR Stage 2+ w/ SC pulley, Airbox mod w/ aFe hi-flow filter
    Ride: H&R Street Performance Coils, RS6 reps in Gunmetal 21x9.5 w/ Michelin PSS 285/35/21
    Look: P3 vent gauge, HID fogs, E-code heads and tails, Many VCDS mods
    Rebuild Thread
    Apr 08 2011
    NoVA
    Do NOT buy this camera. In the middle of the installation it literally caught on fucking fire.
    The cabin was filled with smoke and burning electrical smell.
    iain
    Mar 23 2019
    New York
    12V connection, or 5v stepdown?
    2018 S6 Premium+
    2021 SQ5 Prestige
    2006 S4 Cab (gone)
    Apr 01 2007
    TN
    Wow, sorry to hear this happened! Definitely have had no issues with mine pre or post install. Spots for the wires to sit was not a problem, but only have the front cam version so definitely not as much going on. I don't recognize that block where it burned either. I'm sure they will give you a full refund, their CS was good ordering wise.
    Mar 29 2021
    State College, PA
    Is that the front or rear? Mine should arrive tomorrow.
    Apr 08 2011
    NoVA
    Quote Originally Posted by NewYorkS6 View Post
    Neither, it's the wiring harness that connects to the factory connectors.
    Quote Originally Posted by Tom Sawyer View Post
    Wow, sorry to hear this happened! Definitely have had no issues with mine pre or post install. Spots for the wires to sit were not a problem, but only have the front cam version so definitely not as much going on. I don't recognize that block where it burned either. I'm sure they will give you a full refund, their CS seemed to be pretty good ordering wise.
    I was finding the opposite, maybe because I had the second wire for the rear camera but there was no room for both cables. It was 10lb of shit in a 5lb bag.
    Quote Originally Posted by turbo_911 View Post
    Front, it's the wiring harness that connects to the factory connections.
    iain
    Mar 29 2021
    State College, PA
    Oh boy.
    The moment you turned on the car it started smoking? Just wanted to make sure I’ll watch out for that as well.
    Apr 08 2011
    NoVA
    Oh boy.
    No, it had actually been installed and had power off and on for about 10 minutes. I was re-attaching the OE plastic trim pieces around the the mirror base.
    iain
    Jul 14 2009
    Pasadena
    stick with the one i already reviewed. see above link. no issues since install.
    IG: @matthewee
    Apr 08 2011
    NoVA
    Quote Originally Posted by itsmatt33 View Post
    Doesn’t that one need to connect to the OBD2 port? No thanks.
    iain
    Jul 14 2009
    Pasadena
    per my thread that manufacturer also has a hard wire kit.
    IG: @matthewee
    Veteran Member Four Rings Chris.green's Avatar
    Aug 09 2017
    Atlantic Canada
    I have that camera, and just hardwired it by cutting off the obd2 connection
    2020 SQ5 | Glacier White Metallic
    BC Forged TD03 | CETE Lowering Module | Forge DV
    034 Transmission Insert | CTS Turbo Inlet
    AWE Coldfront | RocEuro Intake | 034 Strut brace
    IG: chrisssgreenwood
    Mar 29 2021
    State College, PA
    So, I just installed mine and mine doesn’t have the same wiring harness. I did get the front camera only. It had two plugs and that’s all.
    The one thing I don’t like is how it looks from outside, the plastic sticks out past the blacked out glass. See pic. Also in the video you fully see heads-up display. Not sure if I’m fan of it, seems to be pointing too much down?
    Junior Member Two Rings
    Feb 21 2020
    OP, now thats its been a year, hows the camera been working out for you?
    Apr 01 2007
    TN
    Time flies! Cam has been excellent and I have had to pull footage for an incident (witnessed, not involved thankfully), still no complaints other than less than stellar performance at night. Beyond that, unless something new is out there, this is still probably the best OEM look solution.
    Mar 29 2021
    State College, PA
    Same here, has been workin great for SQ5 and Q7 no issues. I am using Samsung 128GB SD card as the provided 64GB failed after a month of usage. Also one of them had problem with recording but after contacting manufacturing and doing firmware update, it's been working great.
    Veteran Member Three Rings scottyuk's Avatar
    Sep 20 2006
    Essex, UK
    Any interfence with DAB radio? I see many posts for dash cams in general where they have issues.
    - - - Updated - - -
    Interference
    Mar 10 2021
    MA
    Is there a difference between that one and this one?
    Other than maybe the one you buy from that place comes from America? It looks like the same unit as the Black AD03 Rain sensor model from Aliexpress for 60 bucks less.
    Regards,
    2022 SQ5
    CTS Intercooler, Downpipe
    Jackal / M2 Full custom ECU and TCU
    Diamond Audio Subwoofer + 20'' LightBar
    Custom PCV system + Mishimoto catch can
    ABT HAS, ECS Skid Plate, Roc Euro Intake, DashCam
    034 Trans Insert, Turbo inlet, Sway Bars, Strut Brace, HPFP
    Chrome Delete + CF Mirror Caps / Wide Angle Mirrors, Mud flaps
    Mar 29 2021
    State College, PA
    Quote Originally Posted by Local View Post
    Regards,
    Probably no difference, all made in china and probably by the same company, just depends who sells it. With fitcamx you get actual support and they reply pretty quick, and if something doesn't work, they can send you updated firmware where from that other website, idk if there will be any support at all?
    Apr 08 2011
    NoVA
    While my experience with the FitCamX wasn’t great, their support was really good and they took care of my issue quickly.
    iain
