Originally Posted by
KamA4
I think Ill likely just run a catback. I had planned on going ECS downpipe + res removal but decided while I’m under there I might as well replace the whole thing. I think I’d just be left wanting more sound out of just a downpipe and res removal. I’ll probably go for the AWE track exhaust which imo still isn’t crazy loud based on the videos I’ve seen, and also because its drastically cheaper. I’ve got a local shop that will bring one in for $1250 CAD + tax and no shipping cost. Now I’m just debating whether to grab a test pipe or HFC at the same time to avoid getting under the car twice.
AWE Track and a modified cat is going to be extremely loud and
will induce drone. I wouldn't recommend the Track exhaust for this reason.
The AWE Touring exhaust does a great job at keeping the same volume while having little to no drone, at all. AWE's mufflers (Touring and SwitchPath) use an ideology called the Helmholtz resonance, basically the mufflers will reflect the same drone-y frequency inside to cancel out the drone and just have
clean noise. I have a comparable exhaust on another car that used to have straight pipes, but now has Helmholtz resonanators, and it is the same volume but without the boom and drone of a straight pipe exhaust. For this reason, I would recommend the Touring setup with any modified cat, especially test pipes.
A4B7Avant
You could also gut your stock cat. Real easy to do.
Considering cat thefts are on the rise, at least in Houston, I would keep the stock cat untouched. Cats are practically gold at this point and keeping the stock cat intact would be more valuable and efficient. The <$200 test pipe at that point is a no-brainer to me.
